The Complete Smart Home
100,137
317
30
About: Electronics is a Hobby
This project can turn on and off the simple 6A loads like ceiling fans and lights depending upon the relay ratings.
Up to 16 loads can be switched on and off from any phones with Android, iOS, Java, Windows or anything web based. Android have app for it.
Loads can also be switched on and off from manual switches which are two way wired.
In case for switching HV appliances like AC, Refrigerator a contactor to be used.
Step 1: Parts
Here I have used the DPDT relay where SPDT relay is sufficient.
First and foremost, working on 230V is dangerous have a certified Electrician for all wiring purposes.
1. Wifi Router with Ethernet port + Adapter + Patch Cord
2. Ethernet Relay Board RCD1610-RJ45 Link (This board has inbuilt wifi so external router is not necessary)
3. 1 x 2A MCB (here I used 10A MCB)
4. 1 x 16A MCB
5. 16 x SPDT Relay base rail mounting type
6. 16 x SPDT 24VDC Relay
7. 9 x Terminal Connectors (depends upon wiring)
8. 222 Wago Connectors (depends upon wiring)
9. 12V 2A Adapter for powering Relay Board
10. 24V 3A Adapter for powering external relays
11. 2 x wiring channels
12. 2 x DIN rail
13. 16 x SPDT switches (Optional for fail safe mechanism)
Step 2: Schematic
Here I have shown only one control, rest 15 controls are copy of the circuit.
AC Hot line is routed via a 16A MCB.
Load can be switched either ways via a normal switch or through the RCD board with wifi router. This is simple two way switching.
THE RATING OF THE RELAYS IN RCD BOARD ARE ENOUGH TO DRIVE THE 6A 230V LOAD. JUST IN ORDER NOT TO HAVE 230VAC TO THE BOARD I HAVE INCLUDED THE EXTERNAL RELAYS WHICH TAKES THE 230VAC AND ALSO FOR EASY REPLACEMENT OF RELAYS IN FUTURE. THE COIL VOLTAGE OF RELAYS ARE CONTROLLED BY THE RCD BOARD WHICH IS 24VDC.
Point A is branched to 16 230VAC and connected to the common terminal of external relay
Point B is branched to 16 +24VDC and connected from common of rcd board relay and coil A1 of the external relay
Point C is branched to 16 -24VDC and looped together and connected to NO of rcd board relay and coil A2 of the external relay
All three adapters and powered through a 2A MCB
Other end of the load is connected to a common Neutral of 230VAC.
Step 3: Surface Preparation
As my initial plan was not to have the blue panel to be placed, so removed some wall blocks to place the blue panel
Step 4: Initial Wiring and Testing
Here I have used a optional SPDT switches for failsafe and testing purposes.
wiring came complicated which led to removal of some optional items.
Step 5: Panel Assembling
This is completely your self idea to design custom panel
DC wiring, Router connections, Adapter wiring are done within the panel board, later AC wiring and two way connections are done after placing the panel board inside the enclosure.
Step 6: Panel Wiring
Panel wiring I have used some 2 way, 3 way and 5 way wago 222 connectors.
Since on 230VAC using tapes and joints is not reliable
Make sure all metal boards are earthed properly.
Step 7: Adding Wifi Router
Since the board uses Ethernet, it should be connected to the Router
Added new board in the Parts list have inbuilt wifi module which does not require router
Router to be placed in a central area where loads can be switched with enough wifi signal.
If RCD 1610 Board is used follow below steps
1. Connect the patch cord to the rcd board and other end to one of the router lan port
2. Power on the rcd board and wifi router
3. By default rcd board has ip 192.168.1.25 and port 80 and access code 123456
4. Now ping 192.168.1.25 from your computer and confirm reply
5. If failed turn off the firewall
6. Once wifi connected it will have limited connectivity only
7. Once ping is successfull open browser to http://192.168.1.25/web
8. Enter the access code 123456
9. 1 to 16 relays can be switched from here
Step 8: Android and Windows App
Android and Windows apps are available for RCD1610 board.
LINKS ARE DOWN MAIL ME FOR APP AND DATASHEETS.
System is double secure
1. Secure the wifi router with authentication password
2. Change the access code for login to the webpage for controlling relays
Step 9: Notes
Upon successful router addition remember to add the below code to maintain power off memory which provides memory function, when the function is turned on, the relay state is saved when there is a power failure.
This prevents change over of relay making some load to toggle its power state.
Just copy paste this to the address bar on a successful ping of 192.168.1.25
http://192.168.1.25/cfg/other?ac=123456&rb=1
ANOTHER IMPORTANT NOTE IS THAT THIS TYPE OF SWITCHING IS TWO WAY SO THE STATE OF RELAY SPECIFIED CAN BE DIFFERENT FROM ACTUAL IF BOTH MANUAL SWITCH AND WIFI BASED SWITCHING IS USED.
- Apologize for the low quality video.
I am currently working on a Addon board which can feedback the load status through wifi. Any doubts feel free to mail me at
kua201@gmail.com
-Kumaran
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
30 Discussions
MassMattD
11 months ago
Hi kumaran....
I've already read your project, this is very helpful. I just purchased the same module as you used in the project, the module is working well via PC. I want to control it by using Android. But I didn't get the application from the seller. I tried to access the link U've share but it's no longer exist. Could you helpme to give the other link so I can download it. Or may I have the apk copy from you?
Thanks.
kumaran512MassMattD
Reply 5 months ago
Post your mail id, will drop a mail with apk, datasheet.
kumaran512MassMattD
Reply 11 months ago
Hi Matt,
I am currently out of town, will update links once am back home. Thanks for pointing out. Good luck with your project.
DennisS190
1 year ago
Can you please tell me the brands of the din rail mount and the relay you are using along with the amp rating?
kumaran512DennisS190
Reply 1 year ago
Board relays and second extra relays are both 10A. Din rail mounted items are local retail purchase.
ashwini.gunjal
1 year ago
hello Sir, I study your project. I have one query. when my manual switch is off then I am not able on the light using the mobile app. so always need to take precaution to turn on my manual switch on. one more query some reason LAN internet not working then how do I control all light?
kumaran512ashwini.gunjal
Reply 1 year ago
You can control loads with both manual switches and also through mobile app provided relay and manual switches are wired as staircase wiring. FYI there is no internet involved here, switching is through LAN only.
jwLORAN
1 year ago
It would be cool instructables had a deal with newegg or other retailer where they could put a bundle deal of the parts to do these projects for a quick buy.
kumaran512tallejos001
Reply 2 years ago
I am working on a low cost version with enhanced features, will post once done
Hasayen
2 years ago
will I be able to control the lights from the wall switch also ?? or just using the smart phone to control them ? Thanks
kumaran512Hasayen
Reply 2 years ago
Both wall switch and wifi can be used for switching
billbillt
3 years ago
This is a wonderful projrct, sir!... May I ask where you purchased the enclosure? as pictured.. I can find no info on it... Thanks!
kumaran512billbillt
Reply 3 years ago
I have ordered the above box in a fabrication shop with my own dimensions for my wiring design. It is 1.5mm mild steel sheet fabricated, then powder coated by the fabricator.
billbilltkumaran512
Reply 3 years ago
That you so much for your help with this... The blue powder coating looked like the cabinet was made from some type of dense polystyrene when zoomed in on... Your kind reply cleared this up for me... I now know what direction to take...
billbillt
3 years ago
Could you give any details about the panel box you are using?.. I can't seem to find anything like it... I would like to duplicate your project exactly...
Thanks!
kumaran512billbillt
Reply 3 years ago
Panel box is purely fabricated to suit your design..
billbilltkumaran512
Reply 3 years ago
Thanks for the reply.. I was talking about the blue electrical box itself.. Not the components... I can't seem to be able to find one made from polymer like you have...THANKS!
sathya32
3 years ago
Great work Mr. Kumaran.
Keep posting.
