The Disappearing Soda Prank
About: I love crafts, technology and anything to do with inventing!
This Is a fun prank you can play on any soda drinkers. The main idea is that when your friend opens up a can of soda there is nothing inside. This prank is very simple and only takes a few minutes.
Step 1: Supplies
For this instructable you will need a hammer, a sewing needle, a soda can (full) and a glass
Step 2: Making the Hole
The first step is to tilt the can upside down and begin to hammer the needle into the bottom. This will make the hole which you will be pouring the liquid out of. Be careful when you remove the needle though, a fountain of liquid make come spurting out.
Step 3: Draining the Soda
Now pour the soda into the glass, you may want to do this over a sink because it is prone to spilling.
Step 4: Finished!
That's it! Now all you need to do is place the can back in the fridge and wait for your friend to come along!
    • Pocket Sized Contest
    • Leather Challenge
      Leather Challenge
    • Trash to Treasure
      Trash to Treasure
    12 Discussions
    bird123457joey99
    Reply 6 years ago on Step 4
    I can see where you are coming from. If you are concerned then you could add salty water through a syringe, then they would have a real surprise!
    bajabluebird123457
    Reply 6 years ago on Introduction
    That's what I was thinking. JB weld could be used to close the hole and it wouldn't leak. >;-D
    MR.Geo
    If I were pulling this prank, fizzy lemonade would be my substitute of choice for cola. This would seriously mess up my flatmate. So confusable when he has a hangover.
    Mr_o_uk
    Instead of 1 hole in the middle, If you put 2 holes, one at either edge, it will be a lot easier to get the liquid out as air will go in one hole with the liquid coming out the other.
    bird123457zews
    Depends on which glue you are using, I tried this again and I chose a silicone sealant I bought at the dollar store.
    zewsbird123457
    i tried epoxy(epoxy fix's everything right) but it still didn't stick for long. when i put it in the fridge dew drops formed on it and loosened the glue.
    bird123457zews
    If you are having problems I highly recommend a marine sealant, these glues are made to be super strong!
    przem
    Simple yet funny - I like it!
    You can refill the empty can (using syringe and thin needle) with salty/acid water. It will provide proper weight of can and an (unpleasant) surprise after first draught. The hole can be sealed with hot glue, wax or sth. similar.
    Best regards and keep pranking!
    P.
