The Introduction of LM2596 Step Down Power Module DC-DC Converter
97,193
70
28
About: www.ICStation.com is a top store of electronic, which specializes in all kinds of IC products, such IC accessories, Module, Robots, Development Board, Transistor, Capacitor and so on. We're located in She...
ICStation Team share this LM2596 Step Down Power Module with you in details. We will introduce the features,scope of application,diagram,and testing results.We use the digital storage oscilloscope to test the module and show you the actual testing results with pictures.You will have a full understanding of this module.
Features
1.With voltage meter display;voltage meter error of ±0.1V;the range among 0~40V. (note: to ensure the voltage meter accuracy, please make sure that the input voltage is 4.2V or more).
2.Voltage meter can be closed by long pressing button(minimum power loss).
3.The range of input voltage is 4.2~40V and output voltage is1.25V~37V ,which are continuously adjustable.(The input voltage must 1V higher than output voltage)
4.Maximum output current can be as high as 3A,but normal and stable working current is2A.
5.Use 150KHZ internal oscillation frequency,which is belong to the second generation of switch voltage regulator with low consumption and high efficiency.
Where to use:
1.experiment teaching
2.temporarily set up power supply in the outdoor
3.car(audio, electric fan)power supply
What is special:
LM2596 Step Down Power Module design based on XL2596 as main control chip,attached digital tube to display voltage at that time to highlight smart function. What’more, schottky diode provides protection of reverse connection.
What components and tools do you need to do the test:
Copper Wire
Copper Cylinder
Nut
Pin Header
Screw Driver
Power Connector
Supplies:
Step 1: Function Introduction
Step 2: Diagram
Step 3: Testing Results:Input Voltage 4.5V
Because the starting voltage is 4.2V, when testing you should set the input voltage 4.5V and the output voltage 1.4V. ICStation Team test it on the digital oscilloscope and the result shows that the actual testing of the product is in accordance with the description.
Step 4: Testing Results:Input Voltage 30V
Because the maximum voltage is 33V,when testing you should set the input voltage 30V and the output voltage 28.6V.The actual measured data is lower than set data of around 0.6V.This may be caused by the output voltage is close to the input voltage or poor power supply accuracy.
In general, the performance of LM2596 Step Down Power Module is very good.You had better set the output voltage 3~4V lower than the input voltage, then the testing results will be more stable.
Thank you for your visiting! Please feel free to share us your comments. :)
Should you meet any problem, please feel free to contact us.
ICStation Team
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    28 Discussions
    ShilpaS23
    Question 5 months ago
    Sir, I want testing procedures with what load circuit is tested and also what is design procedure for dis circuit
    Non_techie
    Question 1 year ago on Step 1
    Hi I have a 15 volt battery pack with 4-5amps output can I use this step down transformer to step down the volatage to 5volts 1 amps to charge 18650 battery using TP4056 module.
    photaichin_749
    2 years ago
    Question: would it be possible to modify the output voltage adjustment from a small screw to a regular sized potentiometer where I can put a big knob on it to turn by hand?
    Heyupphotaichin_749
    Reply 1 year ago
    Hi, did you find your answer? If not just to let you know that you can swap the small trim pot for a lager variable resistor.... :)
    funinmoney
    2 years ago
    Do these buck converters use any current if the output is not connected? Thanks..
    JensT14funinmoney
    Reply 2 years ago
    Yes, most of it is burned by the LED that is often integrated into these modules. Destroy the LED and it should go down to a few micro amp.
    beerygaz
    2 years ago
    I thought this circuit was supposed to produce a constant output V irrespective of the input V (as long as input is higher than output). I connect 12V and tune to 3.3 and when I switch the input to 5V my output drops to 2.8V.
    JensT14beerygaz
    Reply 2 years ago
    The dropout voltage can be up to 2V, depending on load and temperature, i.e. you need a minimum of 5.3V for a 3.3V output. Use a regulator or module with a lower droput voltage to convert from 5V to 3.3V.
    HillelP
    3 years ago
    Any Help!!?? I connected it to a solar panel with a 19 volt output (I put the wires from the solar panel on the input side of the buck). The input drops to 2.4 volts and the output is 0. I tried turning the pot and nothing. I then tried it with a solar panel that output 6 volts. Same thing.
    marcelo.benitez1HillelP
    Reply 3 years ago
    what is the power of your panel? I have a 10watts andsucessfully charging a pack of 4 18650 batteries with 16 volts... be carefull to the regulation procedure..you need to press the right button moderately (neither short, nor long press)..read setp 1in this tutorial..... minimun srop down voltaje is 1 volt..so you will always have 1 volt less than input...
    chiskas2marcelo.benitez1
    Reply 2 years ago
    Hi HilleIP,
    I had exactly the same problem and then I found this information (
    for solar chargers. A step down converter like this can work with a good powerfull solar panel in a very sunny day. If you cannot have that you would need to try a MPPT Solar Buck regulator (see this guy and his excellent videos
    Hope it helps!
    S_Yash
    3 years ago
    I did a contuinity test at the input terminals. Initially there is a small beep for half of a second. Can anyone explain this ?
    TomB222S_Yash
    Reply 3 years ago
    The input capacitor when discharged acts as a short circuit until it charges. Since the ohms function on a multimeter uses a small amount of current the "capacitor short circuit" will cause the beep. As the cap charges there is no more current flowing thru the capacitor and the beep ends.
    jimdooris
    3 years ago
    It sounds like the current output of your Solar Panel is insufficient to drive the module. It may require a group of panels in parallel to provide sufficient current.
    svarma7jimdooris
    Reply 3 years ago
    is there anything else to do instead of connecting bunch of panels??
    JimD80svarma7
    Reply 3 years ago
    You could add a rechargeable battery in parallel with the solar array, The battery would make up the difference in current the array cannot supply. However this would mean that some times during the daylight hours you would have to shut off the unit so the solar array could recharge the battery
    VidalC1
    3 years ago
    Cual es su rango máximo de voltaje, deseo poner en el IN=54Vdc y el OUT= 24VDC a 3A sera que sirve...
    marcelo.benitez1VidalC1
    Reply 3 years ago
    nooo..es demasiado!...el maximo es 33volts..y se recomienda no pasar de 30 volts..
    You should be able to get one off amazon, ebay, etc. read the number off it. Should be IN1508 or similar designation
