Knex Freek Semi Auto ( K.F.S.A )
13,182
19
343
About: Hi im kevin! i make stuff =] Kthanksbye =D
It is a true semi automatic gun. Pulling the trigger pulls
back the ram and fires the shot.
Range is 30ft with 2 new #64 rubberbands. (potential range of 50ft)
If you put more than 2 bands on, you will get more range.
This gun shoots as far as you are strong.You can put on as many bands as you want, it wil just take more effort to pull the trigger.
PLEASE SUBSCRIBE!!!!! JUST PRESS THE BUTTON!!!!!
YOU KNOW YOU WANT TO!!!!!!!!! ITS EASY!!!!!!!!!!!!!!!!!!
Step 1: Warning
 This is a highly advanced gun, it takes alot of skill to build and use it, unless you are a knexer. And you know who you are. TO sum it up, this gun is more advanced than other guns and it is not recommended for newer builders or even moderate builders. This is an advanced gun.
Step 2: The Turret
 This is how to make the K.F.S.A turret and holder.
Step 3: The Gun
 This is how to make the pistol version of the K.F.S.A
Step 4: The Auto Turner
 THIS IS OPTIONAL!!!!!
This auto turns the trigger.
It doesnt work amazingly :( you can use a motor if you want :)
Step 5: Adding Stuff
 add this stuff
Step 6: Firing!
Put a bunch of bands on!!! For you first shot ever, get a piece of ammo, load it, then pull back the trigger and manually twist the turret. Have fun!
If you want to use the stop mech:
pull the trigger until you hear a click, take your finger off the trigger and the hammer should stay cocked back :) than pull the trigger when you want!
DO NOT PUT ALOT OF FORCE ON THE TURRET! THE BAND THAT YOU USE FOR THE TURRET SHOULD ONLY BE BARELY STRONG ENOUGH TO TURN THE TURRET!! THATS IT!!!!
MORE FORCE ON HE TURRET MEANS MESSED UP SHOTS AND  BAD RANGE!!
Step 7: Stuff
 this is stuff
    • Pie Contest
      Pie Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    343 Discussions
