The "LEDPOD" - 4-in-1 Photography Panel
2,374
12
5
About: -----------------------------------------------------------------16 year old, sick with a deadly disease called DIY-itis!-----------------------------------------------------------------Hi FTC! My I'bles con...
I can't really explain this crazy project that took me a couple months, but shortly it is a:
Tripod for a phone
A dimmable L.E.D flashlight (L.E.D strips i bought from eBay for really cheap)
Phone charger
Storage container
It can be plugged directly into a car to be used in dark areas
In the fourth picture you can see there is a round component, it is a retractable wire i took apart from a vacuum cleaner and it connects to the power adapter (1.5 amps output)
And yes, everything work on 12 Volts,which means i can also connect it to a car battery...
If you want to see more of these kinds of projects make sure to check out my instructables page and subscribe :)
Step 1:
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    5 Discussions
    salomon1996
    3 years ago on Introduction
    That is one interesting contraption! :) Do you have any pictures you could share where you used the light to light the subject? Very curious on the effect you will get from it!
    Yonatan24salomon1996
    Reply 3 years ago on Introduction
    Thanks, I started using the ledpod (and the LED-timate flashlight, .if you've seen it) to light up the pictures I take on my white background for my Instructables projects but I noticed that the best pictures are simply with the camera flash, I guess the external lighting ruins the colors.
    Other than that, I use It a lot as for lighting for projects, my room when I want it to have only a bit of light, for outside, and more
    Yonatan24electric guy
    Reply 3 years ago
    Nope!
    I made the LEDPOD many months before I found out about Instructables, So I don't have any instructions :(
    Basically, Everything is mounted onto a Tripod, And connected in series to a 12V power supply
