The Morse Translator With Arduino
5,537
78
15
What it does:
It translates your morse code into English words!
With this Morse Translator you can improve your morsing skills. Imagen,if the zombie apocalypse will happen, this will be the only way to communicate. Start practicing now!!
... or just have fun morsing ;)
About the morse code:
Characters in morse code consist of a series of dots (short beeps) and dashes (long beeps).
The duration of a dot is the basic unit of time.
To begin with, the variable is set to a value of 1000 ms, which is good if you're just starting to learn morse code. The following rules hold: The duration of a dash is three times the duration of a dot (default 1000ms) The gap between dashes and dots within a character is the duration of a dot.The gap between characters is three times the duration of a dot (i.e., the duration of a dash)The gap between words is seven times the duration of a dot.
Components
  • 1x Arduino Uno
  • 1x Breadboard
  • 1x Potentiometer 10k Ω
  • 1x Button
  • 1x Speaker (Piezo Buzzer)
  • 1x LCD (Hitachi HD44780 compatible)
  • 1x Resistor 220 Ω
  • M-M / M-F Jumper cables
Step 1: Connecting Parts
Connect the parts according to the fritzing sketch.
Step 2: Code and Usage
Upload the source code to your Arduino.
You can change the duration of a dot in the source code by changing the value of the variable dotDuration.
In order to make it easier for beginners, the morse code translator tolerates certain deviations of the actual duration of dots, dashes and gaps.
The tolerance can be modifies by changing the value of the variable tolerance in the source code (the default is 500 ms).
- Happy morsing!
Make Noise Challenge
Runner Up in the
  • Remix Contest
    Remix Contest
  • Warm and Fuzzy Contest
  • Faux-Real Contest
    Faux-Real Contest
15 Discussions
RafaG16
4 months ago
It doesn't work. The buzzer works so well but the lcd only shows squares, any letter. Can you help me? I used arduino IDE and all connections are fine. My lcd works in other projects using the same library.
AmirM98RafaG16
Reply 4 months ago
change the contrast with the pot
ra.giraldo1260
1 year ago
Hello, I can't seem to make the LCD display the characters. Could you help me??
blubflubifyra.giraldo1260
Reply 1 year ago
I am having the same issue, It will make the noise but the screen stays blank.
Fred_RK
2 years ago
Thaaaank you so much for all the votes :)
<3
Fred_RKTommasoP8
Reply 2 years ago
Maybe, try to press the button faster.
Have look at the morse code table.
Hope it works for you.
Have fun!
amal_asaad35
2 years ago
there is an error in code
what is that mean
Morse:13: error: expected unqualified-id before '\x6574'
Morse.ino: In function 'char readCharacter()':
Morse:127: error: 'alphabet' was not declared in this scope
Morse:132: error: 'alphabet' was not declared in this scope
help please :)
Fred_RKamal_asaad35
Reply 2 years ago
Hellooo,
Uff that's a good question.
Which platform did you use?
Have you perform any changes in the code?
Have you used the Arduino IDE?
Have you opened the file in Notepad and changed the encoding?
I just tested the code without any issues.
I use: Arduino IDE + Arduino Uno
Maybe download the file again, and open it directly in the Arduino IDE.
Let me know if that worked out :)
rexty37
2 years ago
Hello and thank you for the assembly.
Question: I have an I2C LCD display
Four pins, how to plug
And what changes in the code?
Happy New Year 2017
Fred_RKrexty37
Reply 2 years ago
Hi rexty37,
How to plug the display depends on which display do you have :)
What you have to do anyway:
Include the library of your LCD display to the code and replace "LiquidCrystal lcd(12, 11, 5, 4, 3, 2);" in the code
Hope it worked :)
Best regards and happy new Year 2k17
Fred
Anirudh Ralhan
2 years ago
Cool. Definitely making this as i'm really interested in Morse code. Well explained and easy instructable. Voted :)
Swansong
2 years ago
That's really fun! :)
