The Movable Hanging Herb Garden
12,066
653
6
About: Desktop Support Technician by day ... Occasional hired gun rock drummer by night ... DIY home improvement enthusiast on weekends - maker of whatever I can imagine in between it all. I'm also a professional l...
I have a strong desire to have a flourishing garden with lettuce, carrots, strawberries, a plethora of herbs, money, and maybe a few types of peppers.  I also have a garden located in a corner with minimal sun contact, a short attention span, and a blacker than black thumb.
I needed a system that could be moved to different locations, say if I needed more sun ... or less sun.  I wanted it to be affordable (cheap) and built by me.
A length of 4" PVC pipe and a bunch of 4" caps should do the trick.  I already had PVC cement and bailing twine.
Step 1: Cut Sections in Half
First , cut the PVC pipe into sections on a miter saw.  Mine are around 36", but you do whatever works for your space.  Then, set up a fence on a bandsaw and cut these sections in half.  I wouldn't use a tablesaw because the PVC will close in and pinch the blade, which is a recipe for kickback.  You could use a hand saw or a jig saw I suppose.
Step 2: Glue on the Caps
Glue on the end caps using PVC cement and a few clamps.
Step 3: Drill Some Drainage Holes
Pop a couple holes in the bottom so water can drain out.  I used a drill press, but a hand drill would work.  A nail and hammer might even work if you aren't Thor.
Step 4: Hang 'em Up and Fill 'em With Dirt
Drill a hole in the top of each cap, run through twine and make a knot.  I made them different lengths so I could stack three on one post.  I also had some scrap burlap that I put in the bottom before I filled them up with dirt, which was just to help keep the dirt from washing out of or clogging the drainage holes.
You probably want to put Herbs in your hangers, but I saw something shiny and had to go check it out, so I never got around to it.
    • Organization Contest
    • Paper Contest
      Paper Contest
    • Weaving Challenge
      Weaving Challenge
    6 Discussions
    mr_photo
    3 years ago
    Hmm could do this for indoor herb garden and hang under window?
    ggrookett
    4 years ago
    Wow pretty cool was wanting one of these for last last year wish I would of seen this sooner. Thanks for posting this going to try it in spring to get my garden started.
    cfsunlet
    5 years ago on Introduction
    I love it! Was also thinking you could paint them to match your décor, such as a copper metallic. Great idea!
