The Swedish Killevipp Or: Dessert Goes Supernova
4,608
89
19
About: Mostly harmless
Let me introduce the "Killevipp" (pronounced something like chillewhip )
sweet and tasty goodness from Sweden.
under a coat of soft chocolate buttercream waits a hard shell of meringue for your spoon
to break through to the delicious whipped cream that's been captured inside.
sooooooo goooooood!
If you're into counting calories - this one is not for you - sorry :( !
but hey: it's gluten free!
Step 1: Ingredient List
for 2 big ones (really big)
the meringues:
2 eggwhites
80g sugar (2,8 oz)
3 drips vinegar
chocolate buttercream:
50g butter (1,8 oz)
25g confectioners sugar (0,9 oz)
1,5 to 2 tbs cocoa
cream filling:
150g heavy cream (5,2 oz)
1 tsp vanillasugar
for decorating:
cocoa
chocolate shavings
Step 2: Mix the Meringue
If you are a master meringue maker you don't ave to read the upper part, otherwise go on for a few good tips to success :o)
The golden rule of meringue making is, that all of your equipment must be absolutely clean and grease-free, otherwise it will be much more difficult to achieve the stiff and glossy foam.
when you're seperating the eggs, be careful not to drop any yolk into your whites.
the vinegar helps the meringue to get crispier on the outside - only a few drops needed.
whisk vinegar and eggwhites with a hand mixer until it forms "soft peaks"
then add the sugar in spoonfuls while whipping until you reach stiff peaks
by now it should be glossy and stable.
Step 3: Make a Pastry Bag
if you already have a super clean, 100% grease free pastry bag, you can skip this step.
or take a freezer bag and cut out a small corner with sharp scissors
If you have a piping tip, use a round tip with 8mm (0,3 ") diameter - if not you'll be fine with a small hole in the corner
fill the freezer-pastry bag with your meringue batter
PREHEAT YOUR OVEN TO 125ºC 257ºF
Step 4: Meringue Domes
In case you ignored me in the previous step: PREHEAT YOUR OVEN TO 125ºC / 257ºF
take a baking sheet covered with parchment paper
use your improvised pastry bag and pipe 4 domes
to do so, pipe a circle with a diameter of 7 to 8cm. (3")
then pipe a slightly smaller circle on top of it and go on, until the dome is closed.
don't worry if the dome collapses, just fill it up.
Now take a spoon and try to get the surface smooth, without killing your domes :) - it's not that hard, just be gentle...
Bake the meringue domes at 125ºC / 257ºF
for 60minutes - they will become hard and light during the baking time.
Step 5: Hollow Out
lower the heat in your oven to 90ºC / 194ºF
take your baked meringue domes and hollow them out with a spoon.
be gentle and don't break them :) ( if you break them it will be still delicious but not as impressive anymore...)
the inside might still be a little spongy and easy to remove.
turn the domes upside down and
bake another 60 minutes at 90ºC / 194ºF until they are all dry.
let the domes get cool slowly in the turned off oven.
Step 6: Chocolate Buttercream and Whipped Cream Filling
we're getting closer to the final result and yumminess!
soft chocolate buttercream:
mix the soft butter with confectioners sugar until smooth and light yellow.
add the cocoa and mix until evenly brown.
whipped cream filling:
whip the heavy cream and the vanillasugar until very stiff - don't overdo or you'll get butter ;)
Step 7: Fill the Meringue Bomb and Cover With Buttercream
place on dome upside down into a cup or a cupcake paperform ( I liked the cup better :) )
if neccesary secure it with some buttercream at the bottom.
fill generously with whipped cream - make the filling quite high, that also the upper half will be filled.
cover the upper half with the chocolate buttercream use a butterknife for that
place on the lower half to complete the cream filled meringue ball.
cover the edges with buttercream.
almost done!
Step 8: Decorate
sift some cocoa on top of the balls
decorate with chocolate shavings or melted chocolate.
and now the step everyone waited -more or less patient- for:
SERVE IT!
Note: if you serve it directly, the meringue will be hard and crisp.
if you make the Killevipp 2-3 hours ahead the meringue inside will soften and dissolve a little, but will still have that "break through feeling" - it's up to you what you like better,
Step 9: Break Through an Enjoy!
Now dive into the swedish ocean of sugar rush!
I like the Killevipp better when served directly after filling:
- knock a hole into the meringue shell and break through to the cream.
soooooooo goooooood!
and I'm pretty sure: as bad it is for your teeth and hips, as good it is for your soul :)
( PS: my teeth and hips are fine :D )
Sweet Treats Challenge
First Prize in the
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    • Jewelry Challenge
      Jewelry Challenge
    19 Discussions
    beaskywalk
    13 days ago on Step 7
    I have been searching for the name & recipe of this for ages. Had it some 20 years ago in gammelstad Luleå (it was much smaller though) and had given up hope.
    Mimikrybeaskywalk
    Reply 5 days ago
    I'm happy to help :)
    yeah mine turned out quite big - but nothing wrong with that ;)
    Mimikryjessyratfink
    Reply 8 weeks ago
    Thank you!
    I guess you could make 3 instead of 2 with the recipes amount … question is only WHY should you?
    Arizona2014
    8 weeks ago
    Yumm. I make something very similar, but use tempered chocoate for the shell. I also add a teaspoon of raspberry coulis in the middle of the cream layer to keep it from being overly sweet.
    MimikryArizona2014
    Reply 8 weeks ago
    that sounds good too - Life's too short to stay away from sweets...
    … or maybe sugar kills you in the long term, hmm I guess we will never know!
    IvliaB
    2 months ago
    Sounds lovely but, why oh why, ruin delicious meringue and cream with chocolate? Simple meringue ballks filled with cream, maybe flavoured with a drop of liqueur, and held together with the merest hint of the buttercream as a glue, again possibly flavoured with the same liqueur as before. But chocolate, (shudders) ruined.
    MimikryIvliaB
    Reply 8 weeks ago
    I'm SHOCKED! - your not into chocolate?!?
    - well more for me and other chocolate lovers!
    You may try your version of the Killevipp and let us know about the result :)
    Ninzerbean
    2 months ago on Step 9
    Wonderful - this makes 2 right? You are making them in 4 halves. Thank you for sharing and for your sense of humor.
    MimikryNinzerbean
    Reply 8 weeks ago
    exactly! - four halves make two bombastic ones :)
    - it's not easy to be humorous in another language but I do my very best!
    enjoy!
    AllenInks
    2 months ago
    You have an upper half and a lower half of the domes, but no step cutting them in half that I saw.
    It seems that this step: "take your baked meringue domes and hollow them out with a spoon." should read as
    "take your baked meringue domes, cut them in half horizontally with a serrated knife, and hollow them out with a spoon."
    KarenP177AllenInks
    Reply 8 weeks ago
    I think they were piped as domes, not spheres. Think of an old straw beehive. Once they have been baked hard on the outside, you pick it up and scrape off excess from the inside to make them thinner. A dome is half a sphere or ball. You put two domes together to make a sphere. I was going by the pictures. I went back and read the directions very carefully, it still made sense. I think you just got the terminology a little confused. Happens to me too; I have to translate everything into pictures in my head, so I just skim the words and follow the pictures. ;)
    MillerIAllenInks
    Reply 2 months ago
    No, the domes are made one at a time. A dome is one half of a sphere or ball. How would you make and bake a ball of meringue anyway?
    No cutting required. Once the domes are hard, you put one upside down and overfill it with buttercream. Then one right-side up onto the mound of buttercream that will fill the void to make the ball.
    MimikryMillerI
    Reply 2 months ago
    well explained - thank you!
    Prfesser
    2 months ago
    That looks absolutely FABULOUS! Yet another dessert for me to try...
    MimikryPrfesser
    Reply 2 months ago
    you won't get dissappointed :) Let me know, when you tried it!
    thanks for your comment!
