The Ultimate FM Transmitter (Long Range Spybug)
934,390
4,327
600
About: Hi I'm Angelo! I am a college student taking my engineering majors in BS-EE/ BS-ECE at the DLSU. I use my course as an inspiration for making my current projects! I've been posting projects here ever since I...
Have you ever wanted to broadcast your own radio station within your neighborhood? Ever get curious on where people get those "Surveillance Bugs" from spy and action movies? This small and simple FM transmitter is the toy that geeks have always wanted.
FM transmitters can be complicated to build, that's why I'm teaching you how to make a foolproof FM transmitter. There's no need to buy kits, this tutorial includes the PCB layout and the schematics. It has a range of up to 1/4 mile or more. It's great for room monitoring, baby listening and nature research.
My Experience:
FM transmitters remind me of my early years in electronics. When I was 8, I came across Art Swan's FM transmitter circuit. At the time I had no idea of where I'm supposed to buy the parts, so I recycled mine out of junk. I guess the biggest struggle that you're going to face is finding a trimmer capacitor. I'll give some tips on the last step of this instructable. In a nutshell, I highly recommend this project for everyone and also those who are still new in electronics.
>>>>>>>WARNING: You may experience nostalgia! :D<<<<<<<
Technical Specifications:
- 1/4 Mile Radius Range
-Powered By A 9V Battery
- Lasts For Several Days
- Adjustable 87-108MHz
Please Watch: Celebrating the 1st episode of my new YouTube channel! It's my first time to document a project with videography. I hope you guys enjoy the vid! Please leave a comment below, I would appreciate some advise regarding the video.
Disclaimer: This project is for educational purposes only and is not intended to air/ interfere with present radio channels. Neither site nor I, am liable for careless actions. Please check for the legality before attempting the project within your area. As long as
Step 1: Gather the Parts
All of these are available on any branch of RadioShack! :)
______________________________
MISC:
- Copper Clad PCB/ Perfboard
- Solid Gauge # 18 Wire
- Electret Microphone
- ¼" Bolt
Transistors:
- 2N3904 General NPN Transistor (2x)
Capacitors:
- 15pF or 40pF Trimmer Capacitor
- 100nF Ceramic Capacitor (2x)
- 10nF Ceramic Capacitor
- 4pF Ceramic Capacitor
Resistors:
- 1M Ohm ¼w Resistor
- 100K Ohm ¼w Resistor
- 10K Ohm ¼w Resistor (3x)
- 1K Ohm ¼w Resistor
- 100 Ohm ¼w Resistor
Tools:
- A Pair Of Pliers
- Soldering Iron
- Hot Glue Gun
Step 2: PCB & Schematics
I designed a compact PCB layout for Art Swan's miniature FM transmitter circuit using Fritzing. Use this step as your reference for the assembly.
About The Circuit: These is the exact description of Art Swan, the circuit's Author, "This miniature transmitter is easy to construct and can be picked up on any standard FM receiver. It has a range of up to 1/4 mile or more. It's great for room monitoring, baby listening and nature research"
Download Link:https://docs.google.com/file/d/0BwP5mrDBOvNYaHFnME...
Step 3: Print the PCB Layout
Download the PDF file then print it with your printer's standard setting then cut the printed layout. Be careful when cutting, the tip of my thumb got sliced by the sharp cutter blade.
_________________
Download Link: https://drive.google.com/file/d/0BwP5mrDBOvNYaHFn...
Step 4: Develop the PCB
I'm using something what's called presensitized PCB fabrication, it's different from the toner transfer method. If you're not familiar with presensitized PCBs, better go with the toner transfer method.
Presensitized PCBs: I expose mine directly to a 10W fluorescent lamp for 5:20 minutes then use a dilute solution of Sodium Hydroxide to develop the exposed PCB.
Here's a separate tutorial for the PCB fabrication:
Step 5: Etch the PCB
Pour Ferric Chloride on a plastic tray then start to etch the PCB.
Step 6: Clean the PCB
Use a swab and Acetone to remove the photo-positive layer/ toner.
Step 7: Solder the Components
Use step #2 as your reference. Solder the smaller parts first. Start with the resistors, the capacitors, the transistors, the coil, the antenna then the 9V cattery clip.
Step 8: Construct the Coil
Strip a solid gauge #18 wire. Use a 1/4" bolt then turn the wire 7-8 times.
Step 9: Adding the Antenna
Solder a hook-up wire to the antenna pin, it's located on the 2nd transistor's collector pin. Use a maximum of 8 inches an a minimum of 5 inches.
Step 10: Recycle a Battery Clip
The key to this compact transmitter is the ingenious battery clip.You can get one by dismantling an scrap 9v battery.
Step 11: Glue Them Together
Apply a generous blob of hot glue to hold the clip and the transmitter circuit together.
Step 12: Breadboard Version
Recently, people have been asking me if it's possible to make this project without having to fabricate a PCB. The answer is yes. In fact I built my first FM transmitter on a perfboard. I guess some are new to this, no worries I'm here to teach you.
The answer to this is a "Perfboard/ Prototype board. It's a PCB designed for prototyping circuits. There are three types of perfboards, the one that suits our needs is the dot matrix version. If you're new to this, make magazine has handy YouTube tutorial.
Step 13: Tune the Transmitter
Turn on your radio then tune it to your desired channel frequency. You'll get more range from the vacant channels. Don't touch the coil, just turn the trimmer capacitor until you hear a feedback from the radio.
Step 14: Q&A - Tips & Tricks
Where Can I Buy The Parts?
If you live in the US, all the parts that I've used are available from Radioshack. You don't believe me? The parts from my first non-recycled transmitter came from RadioShack, Long Island, NY branch.
Any Alternatives For The Trimmer Capacitor?
Most likely, you'll find one from a scrap transistor radios however you can replace it with a 20pF ceramic capacitor then rely on the coil's adjustment for compensation. Trimmer caps are color coded, only use the Red, Green or Yellow. I used the yellow since it covers a wider range.
Which Wire Should I Use?
Only use solid wires that has a thickness of 18 - 22 gauge. When I was still a novice hobbyist, I was worried about the strict selection of parts. Don't worry too much, eventually you'll learn to improvise when parts are not available.
Why Does The Frequency Change After Tuning?
Let's admit it, tuning the radio is a bloody challenge! If you use a metal screw driver to tune the trimmer cap, chances are you'll end up having a different frequency broadcast the moment you lift the screw driver. This is why non conductive screw drivers are recommended.
Where Can I Find A Non-Conductive Screwdriver?
You'll easily find one from a PC repair shop, or maybe form a hardware store. If you really can't find one, the famous Little Bits kit comes with it.
Is It Possible To Connect A 3.5mm Audio Jack?
Yes, it's possible! All you need to do is to link the common ground then solder a 1K ohm resistor each channel (L & R) forming a junction. Now solder a wire from the junction to U1's collector pin (refer to the schematic). You can now connect your MP3 player! I'll post an additional step regarding this mod.
Can I Hook This On A 12v Car Battery?
This project would still operate at voltages between 7v-14v, so yeah it's compatible. If you want to stay safe and prevent the circuit from burning, solder a 10 ohm resistor in series with the FM transmitter and 12v battery.
Is This Legal?
As long as you don't use it to spy on others and not use a long & huge antenna then yes, it's legal. Just don't use it near an airport. For more info, pleas read the FCC Rules.
Step 15: Don't Forget to Leave a Comment [Stay Tuned]
Please don't forget leave a comment below. Thank you!
Schedule:
2nd Week - DIY Pocket Spudgun
3rd Week - Homebrew Continuous Tazer
4th Week - Crystal Radio
5th Week - Solar Car (School Investigatory Project)
Battery Powered Contest
Finalist in the
37 People Made This Project!
  • Paper Contest
    Paper Contest
  • Pocket Sized Contest
  • Organization Contest
600 Discussions
scohen461
Question 2 days ago
If you wanted to upgrade the range, how would you go about doing that? Also, how do you add a 3.5mm headphone jack?
OyekolaA
4 weeks ago
Hi house,can i have the surecircuit diagram of 25miles fm transmmitters
AnkitR75
Question 2 months ago
I mack the ckt bord and put up the aĺl component but this ckt is not working fm radio
hguebeli
4 months ago on Step 15
This is so funny ! When I was in Highscool at age of 14 (year of 1968, 50years ago!) my friend and i made exactly those transmitters with at that time very sophisticated silicon transistors 2N3904 and placed it inside an empty 9V battery case. For transmitting you only had to connect the "transmitterbattery" and a real 9V battery together. Worked fine !
PrinceS94
Question 5 months ago
3pf - 18pf Variable Capacitor - Trimmer
Will it work
d3x
5 months ago
Cannot get a hold of 4pF ceramic cap, will 3.9pF work?
Hamsath
Question 7 months ago on Step 14
I have a 3 pin trimmer capacitor....!!how can i connect it???
If you don't mind,can you send me the circuit design with 3 pin trimmer capacitor please!!!
1 answer
mark49czHamsath
Answer 6 months ago
If there are 3 pins on your capacitor, two of them should look the same. Connect those together and solder as pin 1. the remaining pin should be the 2nd one. Hope it helps
KevinW182
Question 10 months ago
If I modified the design to replace the coil with an inductive charging circuit, and the electret mic with a data source, and other misc tweaks, could this be used to wirelessly charge things like an inductive charger that works over a large distance, or transmit data?
Links:
http://www.nutsvolts.com/magazine/article/august2013_Bates
Jeet7
Question 11 months ago on Step 9
What is the gauge of antenna wire?
Jeet7
Question 11 months ago on Step 13
Can I use anything else instead of the 40pf trimmer capacitor?
I can't find it.
Please give me the solution for this.
jiteshchoudhary999
Question 12 months ago on Step 15
Why its not working properly
When i tuned radio i listen sound at its suitable frequency but it was not clear and well..very poor quality sound and its range was too short ..what changes should i do in the transmitter circuit to get clear sound like other chanels...plzz tell me
1 answer
Eric Tjiteshchoudhary999
Answer 11 months ago
1. If a transmitter and receiver are in the same room feedback can cause poor sound.
2. Poor quality solder joints.
3. Too much heat when soldering can damage transistors or microphone.
4. Component placement: microphone and coils or trimmer capacitor not at opposite ends of the project.
5.you tuned your transmitter to an occupied frequency. Tune your radio to a station that doesn't receive a signal. Then tune the transmitter to match.
KevinH294
12 months ago
Hi! Nice project.
One question: I need the smallest range i can get when i'm transmitting with this mini fm transmitter. If i don't solder the antenna to the circuit, could i get that?
Thanks!!
Mohammed Yasar
Question 1 year ago
I'm sorry but your listed capacitors and circuit diagram capacitors are different I think, so can you help me?, Thanks​
Amirul AsyrafR1
Question 1 year ago
Hi can I replace the microphone with the audio jack as the input to be connected to the smartphone? and one more question, if I set the freq to the specific frequency such as 99mhz, can the trimmer capacitor find that frequency?
átháwàít
1 year ago
from where i can get 40pf trimmer capacitor ?? is there any chance of getting from radios or RC cards??
UtkarshVermaátháwàít
Reply 1 year ago
They're almost a rarity nowadays. Don't worry about the variable capacitor and use a common ceramic capacitor with similar value in its place. If you want to change the frequency, adjust the coil length using tweezers.
