The Ultimate Prop Weapon
2,723
68
6
About: I enjoy building things and being creative.
This Halloween I was on a tighter budget, I tossed this costume together for about 20$. The focus of this instructable is the weapon. I did a few sketches and came up with what I think is the ultimate slasher movie type weapon! I made it a bit oversized for dramatic effect!
Supplies:
Step 1: Sketch and Cut
On 1/4" poplar, I roughed out my design, I used a scroll saw to cut two blade sides out of 1/8" MDF and scales/ handle out of 1/4" alder.
Step 2: Glue, Clamp and Sand
I used high strength wood glue to adhere the wood parts together, clamping them in place. After the piece cured I cut and sanded the profile smooth and marked a center line for the blade. I then sanded and filed the slope into the blade, rounded the handle and formed the rear spike. I added notches and wear marks in the blade to give it that heavily used and custom made look.
Step 3: Prep and Paint
I used some body filler to touch up some gaps in the blade area, I then taped off the handle area, primed and painted the blade areas. I used a combination of crumpled news paper and sponge brush to achieve the random rust pattern on the blade. I then mixed different colors of red and layered them on the different areas of the weapon. I then stained the handle, added the brass pins and wrapped the handle with aged leather. I fixed the leather in place with high heat hot glue.
Step 4: Final Thoughts
I'm really happy with the way this turned out, super creepy and really inexpensive. I have entered this project in to a few contests, if you enjoy my work please vote! thank you for looking!
    • Classroom Science Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    6 Discussions
    DaMidas
    3 years ago
    If you were walking in a cornfield and you turned around and saw that mask disappear into the corn, that would be terrifying!! PLEEEASE make the mask.
    gibbergiest
    3 years ago
    Have you posted an instructable for the mask? If not, you should.
    desertsnipergibbergiest
    Reply 3 years ago
    I have debated making another mask, I did the first one kinda fast and there was a lot of trial and error. I was not sure how it was going to turn out so I did not document the process properly. if enough people ask then I will, thanks for the input!
    inthedesertdesertsniper
    Reply 3 years ago
    Very nice. The mask and blade go together perfectly. But really I wanted the mask instructable more than the blade.
