The Ultimate Wire Soldering Guide for Beginners
19,767
359
22
About: Car enthusiast YouTuber creating helpful tutorial videos on both repairs and customizations. Be sure to hit that SUBSCRIBE or FOLLOW button!
Video tutorial on how to properly solder wire. There are different types of soldering tools you can purchase, the first is a soldering iron which I am using here, next there is a soldering gun, and finally a soldering station. There are two different types of solder used in electronic soldering. Rosin core solder does have the chemical to clean the connection which is rosin and is a just when soldering wiring or electronics. Rosin is the flux. Do not use an acid based flux such as what is found in plumbing applications as this will cause the connection to corrode and eventually fail. Lead solder tends to be a little easier to work with, has a lower melting point but is hazardous to both your health and the environment. Due to the change in environmental regulations, lead free solder is becoming more common. It does have a higher melting point, but it about to withstand higher heat applications and is more environmentally friendly.
Tools/Supplies Needed:
  • solder iron
  • solder
  • wire strippers
  • safety glasses
  • contact cleaner or rubbing alcohol
  • toothbrush
  • wire
  • pliers
  • knife
Supplies:
Step 1: Getting Started
Always clean the soldering iron’s tip before and after usage. This is done by heating the tip, then rubbing it on a wet sponge. If this isn’t done, this will cause heat transfer problems along with introducing impurities into the soldered joint.
Once the tip has been cleaned, now we must tin it. This helps prolong the life and promotes heat transfer to the connection.
Do not cut a length of solder, simply unroll a couple feet so we have plenty to work with. Cutting the length can be wasteful, whatever we don’t use can be rolled up.
Clean wire is extremely important as this can cause adhesion issues. If the wire was corroded, it’s best to cut that back and find a clean section to work with. Stranded wire can be especially hard to clean than compared to solid wire. Rosin flux can be used besides Rosin core solder to maximize cleaning, contact cleaner can also be used or rubbing alcohol with a toothbrush. The rosin core in the solder will also clean a connection if it’s not overly dirty. When the connection is heated, the rosin will eventually burn off.
Step 2: Connection #1
Similar type of technique compared to a Western Union Splice. Strip the insulation back roughly 3/4” of an inch, spread the strands of wire, then insert the strands into each other. Continue to twists the strands around each end, somewhat interlocking the connection. Now solder the joint, ensure the soldering iron is hot, the tip is tinned and then apply it to the connection. Wait a moment until the wire is hot enough and then apply the solder. Do not apply an excessive amount of solder and ensure you do not damage the existing insulation.
Step 3: Connection #2
The Western Union Splice, also known as the Lineman’s Splice is an extremely strong connection, sometimes stronger than the wire itself when done correctly. Strip the insulation the wire back about a 3/4” of an inch and then twist the strands of wire together. Cross each exposed wire about 90 degrees and twist around the opposite end. We are looking for about five times of wrap, if required use pliers to push the tip of the wire down so it doesn’t create a sharp edge which can cause issues such as poking through the insulation. Ensure the tip of the soldering iron is hot, apply it to the joint, allow it to heat up, and then apply the solder.
Step 4: Connection #3
A "T" or Tap splice connection which is intended to attach a new wire to an existing length of wire without cutting into it. Strip the section of wire you want to intercept, here I am using a knife, but be careful not to cut existing strands of wire. Remove about a 3/4” of an inch of insulation back on both pieces of wire. If you are working with solid wire, intercept the new wire at 90 degrees and then wrap it tightly around the existing wire. If you are working with stranded wire, the wire can be separated into two sections if you desire, but isn’t required. First wrap going in the opposite direction once, then go back and continue to wrap the other way. Depending which way the wire will be running will depend on it’s orientation, you’re looking at about five times of wrap. Use pliers to push the tip of the wire down so it doesn’t create a sharp edge which can cause issues such as poking through the insulation. Make sure the tip of the soldering iron is tinned, heat up the joint and then apply solder to the connection.
Step 5: ​Connection #4
A rat tail soldered joint which is used to connect two pieces of wire side by side. Strip the insulation the wire back roughly 3/4” of an inch again, place both wires side by side and then twist together. We are looking for about five times of wrap. Then apply solder to the connection.
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    22 Discussions
    Mousepotato01
    1 year ago
    you did stranded wire but what about solid core wire or hook up wire as it may be called as well. Is there such a thing as a NASA solder joint where the wire is twisted in a bi directional twist at mid point??? I have seen many instructables and became curious of this question as it stated it was the most secure joint preventing any breakage from vibrations as in normal solder joints??? The pages were redirected as so many links do and I was taken to a different link when I seen this tip calling it NASA approved solder joint.
    4DIYersMousepotato01
    Reply 1 year ago
    Same principle applies to solid core wire as well. Actually solid core wire is much easier to use these soldering joints and you can get the wire formed nicer unlike the stranded wire which can separate. I've heard of the NASA joint and I believe that is referred to the Western Union Splice.
    Mystique1508
    2 years ago
    Excellent Tutorial & something that I will definitely be using, to help me in the very near future, as I branch out with my product lines I hand make, for my home business "Punkin B4 Midnite"!! Thank you soooooo much!!! :)
    38ren
    2 years ago
    Just what I needed! Been looking for a tutorial that goes in depth to teach me to solder for an electronics project, thanks so much
    -38ren
    4DIYers38ren
    Reply 2 years ago
    Excellent to hear and thank you :)
    dimm0k
    2 years ago
    is the soldering iron "damaged" if it's been used many times without cleaning?
    4DIYersdimm0k
    Reply 2 years ago
    It can be if used for an extremely long period of time.
    eladberry
    2 years ago
    A very nice instructable. I learned about a few things that I was doing wrong! I will put these into practice next time I do any soldering.
    4DIYerseladberry
    Reply 2 years ago
    Awesome to hear and thank you :)
    4DIYers
    Reply 2 years ago
    Thank you :) I does clean a very light amount, certainly not enough to apply on wires which were exposed to the exterior elements for a longer period of time. If the wires are badly corroded or oxidized, then obviously an alternative method is needed.
    batvette
    2 years ago
    You do not need to tin wire you are splicing together in fact it makes the joints as you show much more difficult.
    Also one can do these with an open flame like a lighter or torch in a pinch. Its not the preferred mervlb
    4DIYersbatvette
    Reply 2 years ago
    I didn't say tinning the wires, I was simply referring to the tip. I normally like to stay away from the open flame option as that can overheat the wire causing damage, or damaging the insulation.
    David the R
    2 years ago
    In an emergency I use Tabasco sauce for cleaning stranded wires. By emergency I mean a wire that cannot be cut any shorter and something you need to fix now, like a connection on your old jalopy 100 miles from home. Warm the wire a little, put the Tabasco hot sauce on it, and wait a minute or two. It will clean it right down to the shiny copper. Rinse it completely to keep the sauce from eating it away.
    If you'd like to see how it works, take and old dirty penny and run it under hot water. Drip a couple of drops of hot sauce on one side, wait a minute and rinse it. Shiny metal.
    Put a tabasco sauce pouch in your emergency tool box where it won't get crushed.
    4DIYersDavid the R
    Reply 2 years ago
    Awesome tip! Isn't there a vinegar is Tabasco sauce? I would think that's what does the cleaning.
    sphederArkykat
    Reply 2 years ago
    Good stuff. Great review of techniques. Any suggestions on cleaning/preparing older oxidized wire? I would like repair old radios.
    David the Rspheder
    Reply 2 years ago
    Tabasco sauce works. Warm the metal, put it on and leave it for a minute or two. Be sure to rinse it thoroughly to avoid corrosion.
    4DIYersspheder
    Reply 2 years ago
    Thank you :) Some contact cleaners will remove oxidization. Deoxit also makes various kits for such things.
