The Ultimate in USB Drive Protection
8,926
81
8
About: I like building things and breaking things and fixing things. I also like pie
It's a solid wooden box that holds a USB stick. It is 4x4x10cm big plus the locks. the locks are a combination lock on top, and a chain that wraps around for a padlock to attach to.
Step 1: Tools and Materials
Materials;
One cheap bicycle lock (Combo),
One 4x4cm piece of wood, at least 10cm long,
One USB drive
Nails
Tools:
Wood saw,
Scalpel
Sharpie
Drill and 25mm bit
Step 2: Prepare the Lock
Cut the plastic coating off it. remove the chain.
Step 3: Wood
Cut a piece 10cm long, and then cut 2cm off the end of it. Drill a hole as long as the USB stick into the larger piece. insert the USB stick to check.
Step 4: Locks
Put two nails through the slots at each end of the combo lock piece. You may need to space it so the dials can turn, so I used five spring washers. nail it into the wood to one side so it does not interfere with the compartment. Put the end that slides out on the smaller piece, the lid and the body of the lock on the piece with the compartment. look at the photos. I also added two nails as runners so the lid would not twist.
Step 5: Encryption
Make a password protected folder on the USB drive by following instructions here. or else just google it.
Step 6: Feel Secure
No longer worry about leaving your sensitive files on your desk, feel secure knowing that they are locked away securely. You can take this device wherever you go, or just leave it at home. Security is here.
Vote for me please!
Trasky
    • Faux-Real Contest
      Faux-Real Contest
    • Build a Tool Contest
    • Paper Contest
      Paper Contest
    8 Discussions
    3366carlos
    1 year ago
    awesome, creative.
    bhardy6
    4 years ago
    Gents please, this device is meant as a DETERRENT. I mean really, who's gonna snatch THAT up and walk away without being noticed??? Lol.....that being said Lad, I would have left some bike chain for a wee bit of the rattle. But I think you did a SMASHING GOOD JOB!!! Well done!!!
    landoh
    4 years ago
    a chisel and hammer would split that open in a couple seconds. use metal
    stinkytoad
    4 years ago
    Great to see such a practical solution to a common problem, very inventive well done. :)
    i agree for practicality, but for quirkeyness i think the wood looks pretty cool though i can see a some thick pieces of iron that would also be cool !
