The Easiest Way to Solder Wires Together
5,990
121
16
Soldering wires together is a part of almost any electronics project. While most soldering will occur using a "helping Hand" Or a "Third Hand", I find that most of my wire soldering go much easier and quicker with this tool i made instead of a helping hand. This helper tool is mobile, not constrained as a helping hand (comes in very useful when your soldering off work bench, in the car or everywhere else...).
In the following steps, i'll explain what went into consideration when building this tool.
Here's what you need:
  • Soldering iron
  • Solder wire
  • Solder paste
  • 2 X small alligator clips (3cm long)
  • 2cm length piece of wire, 1~1.5mm diameter. (i got mine from a toy car i stripped. Use your scavenging skills...)
  • Metal ruler
  • 220 grit sandpaper
Step 1: Preperation:
First, be aware that soldering anything requires a clean surface, and in our case, this means sanding the parts to be soldered.
To get a proper joint that will hold you'll need to sand the clip and the piece of wire. Make sure to clean with alcohol or acetone so no residue is left.
Step 2:
Attache the two alligator clips on the metal ruler making sure you space them apart 2cm. The metal ruler will make sure the clips are aligned and leveled.
Step 3:
Place the piece of wire on the back end of the alligator clip about 2~3mm from the edge. You can hold it in place with another alligator while you are soldering it.
Place solder paste on both sides and solder the wire to the alligator with ample solder so it will cover the wire and bond seamlessly.
This part is a bit tricky if you are a novice in the world of soldering, the key here is to sand, clean properly, apply enough heat and let the solder flow. If it doesn't go right, clean and start over.
Step 4: Finished Tool:
Step 5: How to Use:
After the tool cooled down we can test it.
As you can see, my example consist of 2 wire cable, which I've soldered the first one, flipped it over and soldered the second.
The 2cm gap i chose comes from the wire gauge i usually use in my projects. You can widen the gap but i suggest don't go over 3cm.
I hope this tool will bring anyone who uses it great help as much as it gave me.
Thanks!
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    16 Discussions
    KenT62
    2 years ago
    I liked the idea, but was concerned it might be sufficiently rigid. I took a small piece of heavy copper wire, e.g. 12 gauge, and bent it to form the three sides of a rectangle. I found the alligator clips that have a tubular end, instead of yours with the bendable prongs. I inserted the ends of the wire into the tube ends, and then soldered. I then wrapped with some red silicone tape, to make it easy to find. The result is very rigid.
    RubberduckyKenT62
    Reply 1 year ago
    Very nicely done Sir!
    taking my idea and making it a bit different and even easier to solder since you can crimp the wire before you solder.
    Will try it on my next batch.
    BobberW
    1 year ago
    This is what it's all about, sharing and improving ideas to make a life better>,not my art, but a special blender artist>
    HogHunter
    3 years ago
    An unbelievably simple and obvious solution, I can't think of why I never did this.An add on of a small rod attached to a base would be nice. Using a coupling nut and a bit of threaded rod it could be attached and removed easily. Perhaps when I make mine, I'll do that and show you what I mean. I've attached a few pictures of the hardware I'm talking about.
    kelms1
    3 years ago
    You just made my day!!
    crazypj
    3 years ago
    That's a great solution, wish I had thought of it
    Rubberduckycrazypj
    Reply 3 years ago
    :-) well, you can take comfort in making one...
    Gregarious
    3 years ago
    A very neat solution to a very common problem. Good clear 'ible.
    lor123
    3 years ago
    simple but effective!
    great!!
    bradk3
    3 years ago
    Brilliant! This will save me some swearing and burned fingertips.
    BillJ1
    3 years ago
    excellent idea, great job!
    pteppic1
    3 years ago on Introduction
    Nice idea.
    Just one small suggestion: if you wrap the tips of the alligatorclips in tape or heatshrink you won't get those bitemarks in the insulation if you accidentally heat the cables too much
    Rubberduckypteppic1
    Reply 3 years ago on Introduction
    Liked your suggestion!
    I'm using heat shrink sleeve on the wires as you can see on the pics, so the bite marks don't really matter.
    Thanks!
    twitting
    3 years ago
    I like it! I'm going to make a few of them.
    amberrayh
    This looks like a handy little tool. Thanks for sharing!
