The IPillow
21,487
75
32
About: Architecture Grad/Digital Fabricatior
Ever had the problem of wanting to listen to music while in bed but don't like the inconvenience of headphones or getting tangled in cord if you fall asleep? If so then this is the Instructable for you.
Supplies:
Step 1: Gather Materials
Needed Materials:
-Headphones/small speakers
-Material (i used felt)
-Glue
-Thread
Needed Tools:
-Marker
-Scissors
-Sewing Machine
-Hot glue gun
Step 2: Outline What Type of Shape You Want
I did a Head Test to get a rough indication of where the speakers would be.
Then i drew my idea onto the bit of felt. The one pictured is by no means perfect so feel free to change it around. Basically it's divided into 4 compartments; 1 for each speaker, 1 for the bunch of extra wire and another for the cord to pass through
Step 3: Cutting
Cut out your design (this one will be the bottom) and then use it as a template for the other (this is the top). Simple!
Step 4: 1st Bit of Sewing
Sew the bottom, both ends and half of the middle ones. This is because there has to be a gap left for the cords to pass through.
Step 5: Glue Stage
Glue both speaker to roughly the middle of each of their sections. Then bundle the excess cord (i had a bit) and glue it together and to the middle of it's section. You also might want to glue the cord that passes through the sewed line for ease of sewing later.
Step 6: More Sewing and Stuffing
Sew the other ends leaving a gap for the hole or the cord to pass.
Then stuff each section with stuffing to your liking. I like it soft
Step 7: Last Bit of Sewing
Now sew the top together and don't forget to leave yet another gap for the cord to pass through.
Then sew the top section together and you're nearly done
Step 8: Last Bit
Now tidy it up by cutting off the scrappy bits and loose bits of thread.
I also decided to attach some safety pins to each end so i could pin it to my pillow
Step 9: Using It
i pinned it to my pillow to stop it moving around.
Now you can rock out while catching 40 (or more) winks!
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    32 Discussions
    best idea ever now i can listen to muisc in bed when my mom says to put my mp3 away. i rate 5 outa 5 stars
    great idea! Now I don't have to have the fear of strangling myself with my headphone cords...
    allandnnn
    11 years ago on Introduction
    I'm thinking if you wanted to make a stationary version you'll never move get some cheap speakers 2inch from radio shack or from the salvation army (seen a set of pioneer speakers go for 2.99 each get a hard foam cut out the peach you will replace the speaker into place speaker cover with soft thin pillow or cotton cushioning (hobby lobby is great with this stuff) cut some old head phone wires so that you keep the jack wire up the speakers so you don't shock your self heat shrink the wires prior to closing the whole thing up by some fabric for the size of the pillow you will be sleeping on cover the pillow with it and sew shut i'm sure this way you could make one for you and your significant other my only snag thinking about this is if you will have enough power to run it
    Phoghat
    I made something similar using Radio $hack components and 2 sets of clip on headphones. Last Christmas they had "Clipz" headphones for $2.95 a set. I bought a few for future projects. Then used a mini-amp/splitter that uses a AA battery (OK, played in a band when I was a kid; Marshall stack right next to right ear). I bought a cheap very firm pillow and sliced it open and performed steps as above. Works pretty well for me.
    hogtowner
    11 years ago on Step 8
    GREAT Idea!. I wondered what to do with all my freebie headphones.
    Lizzzy
    Yeah its cool, but its pretty similar to the super ipod instructable i saw ages ago.
    Brennn10
    Great instructions! My friend listens to his music with his headphone in one of his ears, and now he has lost some of his hearing in that ear. This is a great idea for those who do not want to risk potential hearing issues.
    darcy_zBrennn10
    Reply 11 years ago on Introduction
    I found that after around 3 years of apple ear-buds in my ears i had a decreased level of hearing, not that noticeable but i'd was saying "what" and "pardon" i whole lot more. i swapped to the big old school ones and in a couple of months i've seen a noticeable improvement
    I have a pillow speaker. It's just a flat speaker I put under my pillow, but this is another method I guess...
    AceFace
    Just to leave an idea. Is there any 'soft' or less harsh methods of producing buttons for a plushy surface. I though that a piece of silk would work, but I would have to add cotton stuffing before the photocells I plan to use. I am not sure if layering it will work. I fear I might roll over and crush it, or worse, pump up the volume.
    technodude92AceFace
    There are 'ibles on using cloth to make buttons.
    This one shows how to make a TV remote out of it, but it should be easy to adjust for your application.
    menace
    Hey! I found a Pillow just like that a few years ago and I bought it for my sister as a birthday present. pretty cool though!
