The WASP
118,065
1,748
68
About: I made a beer mug with only a knife and a hatchet. I think that says a lot about me.
WASP - Wild Appealing Survival Point ;)
A few years ago a friend gave me a couple of so called 'glaziers knives' (don't know if that's really the right name) - forged knives you'll find in every DIY store, used to remove the putty junction from windows. They are cheap, made from thick carbon steel & have a nice hole in the handle.
Somehow I felt I could do something survivalistic with it. They were there in my workplace and a few times I made some designs but these never went into production.
Untill now, so. 'Why not make a kind of arrowhead from it?' I thought.
A design went into real life and this 'key' came out.
Some will call it a key, others a skinner, kunai, key ring, piercing, pendant, spearhead, wood drill bit or selfdefence tool.
I'm sure that some will call it just a waste of time LOL
Well, it can be all of this and maybe a lot more. One thing is sure: this can be the smallest hottest tool you've ever had, the kind of tiny tool you'd be happy to find in your survival or emergency kit - or to wear around your neck - when the need is there. It's small, sturdy, lightweight & very easy to make.
And it's cool, but that's my geeky opininion...
The 'key' has been long time without a 'real' name, until my wife saw 'an insect' in it. 'Why not call it 'the wasp' she asked. Big head, small thorax, pointed abdomen, it's got it all!'.
And so she gave birth to the WASP...
Feasible for everyone with a grinder or grinding wheel - this is brutal basic metalworking like you've never seen.
Making time: one hour round.
Enjoy!
Supplies:
Step 1: Design
Go get that knife, tape the top & draw your design on it.
Step 2: Cut, Grind & Sand
I made the first two with a grinder, the third with a grinding wheel (I was forgotten I got one) - definitely the best & safest tool to use.
Take care not to overheat, this will disturb temper - spraying lubricant of soaking in motor oil are good ways to keep it cool.
Step 3: Heat Threatment (optional)
Grinding & sanding may affect steels hardness, so if you want to be sure to have a tool that's really rockhard you'll have to harden it (again).
Boost the forge (YES FINALLY I GOT A FORGE, YESSSS!!!) & heat the key to nice red. A good trick, is to put salt on the blade. Once it melts you're about at the right temperature and quench it in (clean motor) oil.
To temper it, let it cool down & throw it in the oven at 425°C (220°C) for 30 minutes (thanx member Deathcapt, your advice in the DARC has been a great help!).
Step 4: Done!
Sharp it if you want, and finish with a length of polyester rope - unbreakable & perfect to attach the point to a pole to use it as a spearhead.
Use a fishermans knot.
You can wear it around your neck (don't do this with a sharpened key - common sense), tape it to your cell phone or just add it in your survival kit.
Hope you enjoyed it, take care & good luck guys!
Step 5: Bonus: Making a Spear
This is the 'controlled environment' setup - outdoors it will be the same, but different.
Just kidding! I used a saw & a drill to have a perfect cut, out there you'll probably only have a knife.
So, cut a pole - choose straith growing species like hazelnut.
Exit bark - it will dry faster.
Cut a groove in the thickest (and most heavy) side.
Harden this side in the fire.
Make two grooves around the tip.
Put the key in the groove.
Prepare a few 'nuts' & put them on each side of the key.
Fix the whole with rope.
Wax the tip.
Done!
Instructables Outdoor Projects Contest
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    68 Discussions
    Wolf bro 109
    3 years ago
    really screams out"Scorpion Spear".
    AluminumFoilMaster
    4 years ago
    This doesn't look like a white anglo Saxon protestant
    Blaise_Gauba
    5 years ago on Step 4
    Very cool...and great idea! I don't really have a shop since I live in an apartment in the Los Angeles area. But I DO have a lot of tools and hand held grinders are some of them...plus a decent Dremel tool as well. Can I get that (putty) knife at any hardware store? I've never seen one of those before. And I have worked in a lot of shops that use a LOT of different type of tools. Anyway, I am going to look and/or ask for that tool and see if I can make one myself. Thanks for the idea. I might lengthen my a bit...more spear head length. But yours is cool.
    Actually I don't have any idea where you can get this knife in the states - I live in the ancient world you know ;) But like you said, any piece of decent carbon steel may do the job. Hope yours works out great also!
    Ancient World meaning Europe? Yeah, I do not recognize that tool at all. But I will look for something that I can make one out of, that's for sure. The spring steel from automobiles (older autos) works well from what I hear. I have a friend who designs and builds knives for Buck up in Idaho. I haven't spoken with him in decades...but I remember when we were teenagers, he built his own forge, and started making some really nice (big) knives from the flat springs from old salvaged Jeeps.
    Worse, Belgium! ;)
    Spring steel is great, a lot of metalworkers use it. Another - maybe easier - way to get somer good carbon steel is going to flee markets and trying to find some old machetes, files or butchers axes - all great stuff to redesing to custom knives.
    Oh...is Belgium worse than the rest of Europe? I didn't know. Of course, I have never been to any European countries. Mexico, Japan, Thailand, South Korea...but not Europe. Good idea about flea markets etc. for old files, machetes etc. Cool. I'm going to look around and see what I can find. Thanks for the ideas.
    The Truth About Belgium: I was kidding, no worries! There's good & there's bad, like everywhere. A lot depends on the people you'll meet: maybe a bit 'cold' at the start, but once that ice's broken those hearts will open. Add a few dozen of the best beers in the world - no more kidding - and you'll never wanna leave again ;)
    Ah...yes....Belgian beer...how could I be so ignorant? I've lived in Mexico where I was basically treated really, really well and even had considered living there permanently at one time (I was only eighteen at that time, no real-world experience), and I have lived in Japan where the Japanese are really nice people...but certainly there are still wounds there in much of the older generation from World War II. I have both been greeted very warmly as well as have been verbally attacked by WWII vets while living in Japan. It was a strange feeling, not having had anything to do with any wars, but having come from a country that perpetuates them, but Hirohito was certainly no saint. I've lived in Thailand and of all the places I have visited, I think Thailand would have been my first choice just for the hospitality, the weather, and the amazing people of that country. Their humor and outlook on life is very similar to Americans. The Thai's love to laugh and they have some of the best food I have ever had the pleasure to put in my gob hole. Then of course, I have never been to Europe, and I KNOW Europe is one of the most amazing places for food. My best friend lived in France for four and a half years building Euro Disneyland and he said that at first, the French are aloof, but if you show a serious effort to try and speak and learn their language, then they are no different than anyone or anywhere else on the planet. I have found this to be true in every country I have visited. I studied Thai for over a year before actually going there and I had a co-worker at Disney who was from Thailand so he helped me a lot with his language...and I can tell you, Thai isn't that easy to learn. I had a much easier time learning Japanese, but then I studied Japanese for almost two decades. I have always had a fascination with foreign languages. I've lost most of my Spanish though. I just don't hold conversations with anyone from any of these countries anymore. Well...I hope you are having the good life over their in the beer capitol of the world. Bike racing, beer, old world, real history...I don't know...I sometimes think I would rather live somewhere else on this planet than the U.S., especially during these strange and violent times...a police state, the most corrupt politicians in American history, banksters that get away with the most heinous crimes. Yeah, Belgium is sounding pretty good right now. Hey, at least we have our hobbies and get-a-ways like Instructables where we can see what REAL people are doing in the world. ~Peace
    I like that spirit mate! Living in other countries has all to do with respect for local habits, way of life & language. In a tiny country like Flanders aka that northern part of Belgium where people used to speak dutch & pin the heads of their enemies on their garden fences (hehe) we are - historically - so used being overruled that speaking other languages makes part of our culture. We're used to cameleonise verbally with the other countries and we appreciate it a lot if others do the same when they visit ours (that's why there's so much friction with that southern - french - part of the country). If you like the great outdoors I don't recommend moving to Belgium - it's getting a lot too crowdy & open space is getting scarcer than gold. We're lucky having found our tiny spot in the open lands but it's just a question of time before the surrounding fields are going to be transformed in concrete & lights...
    Good luck with your project & let me know the result!
    bartworkertriumphman
    Reply 5 years ago on Introduction
    I'm believing more & more that there's really nothing the Chinese didn't invent thousands of years ago ;)
    gnevinsbartworker
    Too bad the Chinese don't know how to make good steel. I would much prefer American, English, Spanish or German steel.
