Theatrical Effects: Replicating a Pyrotechnic Effect Without Any Pyro
22,229
28
27
No pyro? What fun is there in that? Well, unfortunately, for Woodbury Community Theatre's prodution of the Wizard of Oz, the high school would not let us use pyro in the theatre (And anyways, hiring a licensed pyrotechnician for the shows would cost over 5 grand, plus the cost of filling the necessary paperwork.). Oh, well. I guess we will have to figure out how to make all of the nice effects without any pyro...
The effect that I am going to be replicating is a firecracker. The effect needed to produce a large quantity of light in a very brief period of time, mimicking the flash from a firecracker, or an airburst, or a small amount of flash paper. The flash that is required is larger than usual, because theatrical lighting is much brighter than usual, around the house lighting.
Here is a video of the demo board that I created for this Instructable. I apologize for my camera's inability to adapt to the rapid flash from the device.
Step 1: Different Methods of Creating This Effect
I thought of several methods to solve this issue. Each effect has its own set of pro's and cons, that I will detail below.
Effect Description Pros Cons Safety
Pyrotechnics We hire a licensed pyrotechnician to come in and rig the witches broomstick with a pyrotechnic flash.
  • Large flash and a bang, syncronized perfectly, a small amount of smoke
  • Flash eminates from broomstick
  • Extremely Expensive
  • Only one flash per "loading" of the prop
Moderately Safe
Focused Incandescent Fixture We position one of our ellipsoid fixtures and position it to illuminate the end of the broomstick, coupled with theatrical fog to simulate an explosion.
  • Bright flash with smoke
  • Zero-cost
  • Can syncronize with sound effect to create bang
  • Impossible to point, and repeat for each flash (The actors would not be able to hit the exact same spot, every single time)
  • Incandescent bulb heat up time doesn't create a quick flash (Think cheesy theatrical/movie lightning)
Extremely Safe
External Strobe Light We rent, and mount a large strobe light on one of the flies, and use it to illuminate the entire area.
  • Bright Flash
  • Low cost (We have a company nearby who rents to DJ's for extremely low prices)
  • Floods the entire area
  • Fairly hard to syncronize to bang (internal variances in strobe light can cause the bang to happen before or after the flash, ruining the effect.)
  • Flash does not eminate from broomstick
Extremely Safe
LED Strobe Light We build a small LED-based strobe light, which can be mounted in the tail of the broomstick.
  • Fairly low cost
  • An excuse to use high power LEDs
  • Lower voltages keep it safe
  • We would need at least 20 LEDs to create a large enough flash, so disguising the flash unit would be hard
Extremely Safe
Disposable Camera Flash Strobe We disassemble a disposable camera to steal the flash unit, mounting it in the tail of the broomstick.
  • Zero-cost (All parts were found in my basement)
  • Bright flash
  • An excuse to tear apart a disposable camera and use the high voltage stuff inside (Haven't you ever wondered what was inside one of those things?)
  • Easily disguisable (Flash tube is small, and battery pack can be hidden in the tail)
  • Multiple flashes can be achieved without having to reload the prop.
  • Fairly hard to syncronize to bang.
  • Extremely high voltages can injure actors if misused or misbuilt
Moderately Safe
As such, I decided to go with the Disposable Camera Flash. To combat the cons of this method, I came up with the following solutions.
  1. Synchronization: To synchronize the flash to a sound effect, we created a two part effect. The first part was a "charge up" sound effect. This lasted about 3 seconds, and was promptly followed by a large bang, with some thunder mixed in. The plan was to fire the sound effect when the witch pointed her broom, and then she would fire the flash right before the bang happened, so they occur simultaneously to the audience.
  2. Insulation, insulation, insulation. To protect the actors and the techies in charge of preparing the broomstick, I wrapped the PCB for the flash in a layer of Gaff tape, which provided a thick insulating layer, but still provided access to the charge button and battery holder. I also double insulated the connections at the flash tube, with a double layer of shrink tubing, and multiple layers of clear packing tape around the tube. This was a very important step, as the ends of the tube carry 300 volts constantly when the flash is fully charged.
Step 2: Disclaimers and Safety
Yes, I am going to have to run through this, but as this project has the potential to cause bodily harm if misused, I feel obligated to state the following.
I AM NOT RESPONSIBLE IF YOU DO NOT FOLLOW THE INSTRUCTIONS, AND GET BLOWN ON YOUR REAR END. THIS PROJECT INVOLVES EXCESSIVELY LARGE VOLTAGES, AND SHOULD BE HANDLED RESPONSIBLY.
This project is fairly dangerous, and can injure people. Please, be responsible, and be careful. Use common sense.
  1. ALWAYS TREAT THE DEVICE LIKE IT IS LOADED.
  2. ALWAYS TAKE THE BATTERY OUT BEFORE WORKING ON THE DEVICE.
  3. But just because the battery is out does not mean the device is safe to touch. The main capacitor can remain charged for days after the device has been charged up. When I came in one day for a show, I checked the device to make sure that it worked. Before touching it, I made sure to trigger it. And a full 22 hours after being charged, the capacitor had enough power to fire the flash one more time. THIS CAPACITOR IS DANGEROUS. USE CAUTION AROUND IT. Make sure to discharge the capacitor by firing the flash unit (whether it flashes or not) at least 3 times, and then discharge the capacitor by touching the leads with a screwdriver that has an INSULATED handle. This will make sure the board is safe to use.
  4. The flash tube has a constant 300 volts applied to the ends of the tube whenever the capacitor is charged. If you touch the ends, you will get a shock. And the tube is glass, so be careful with it.
  5. If you are reading this step, good job. You can skip step 3, and move on to step 4.
  6. This Instructable assumes that you are fairly well versed in electronics, and is NOT RECOMMENDED for beginners. I REPEAT: If you are looking for a beginner project, this is not the project you are looking for.
Camera selection: I used a Kodak PowerFlash Disposable Camera. This camera has an Auto-Recharge function, which causes the flash to recharge once it is discharged. Some cameras do not have this feature, and need to be recharged after firing the flash. I would recommend a camera with the auto-recharge feature.
Step 3: Go Back and Read the Disclaimer Again...
If you are looking at this step, then you haven't read the disclaimer. I told you to skip step three, and since you obviously haven't, you should go back and read them. To lazy to do it? Here they are again:
  5. If you are reading this step, good job. You can skip step 3, and move on to step 4. (See, there is the instruction...)
I told you so. You should always read the disclaimers...
Step 4: Disassembly: Step 1
Now, it is time for the fun stuff! The first step to any good disassembly job is to crack the case. In the case of the camera that I am using, there were four tabs around the edge of the case. Carefully pry apart the case, making sure to avoid the board to prevent shocks.
Step 5: Disassembly: Step 2
Now that the covers are off, it is critical that we discharge the board. Remove the battery, and find the trigger contacts on the board. Short the trigger contacts, and hopefully the flash will go off. Whether or not it does, you should still short the capacitor leads afterwards.
Step 6: Disassembly: Step 3
Now that the board is discharged, we can clear out all of the unnecessary components of the camera, including the shutter trigger button, film reel, film, shutter, shutter spring, film winding mechanism, lens, and viewfinder.
But first, take a look at the ingenuity of the trigger for the flash. To ensure that the flash occurs when the shutter is open, the manufacturers of the camera made the shutter the trigger for the flash. When the shutter opens, it contacts a rail at the bottom, completing the circuit, and triggering the flash.
Step 7: Disassembly: Step 4
Now, we can ditch the camera's enclosure. My board was attached with a single clip, circled in the photo. From there, the board simply pulled off of the enclosure.
Step 8: Electronics: Preview
Since we have freed the board from the case, we can now start on the electronics.
Several things to notice:
  • The two trigger bars: We will be modifying those to act as the trigger for the flash.
  • The charge button: We can either leave the charge button, or add a second switch somewhere else, to allow the flash to be charged remotely. For our production, we had enough time to charge up the unit before the Witch's entrance to prevent us from needing to remote the charge button.
  • The battery holder: For our production, we used a rubber band to hold the battery in place, but it tended to rattle loose. I would recommend adding a single AA holder instead of the current holder.
  • The Flash Tube: The business end of the flash, it consists of three contacts. There is a terminal on each side of the flash tube, and then a single contact near the center of the tube to draw the arc across. Once the tube is charged, applying 300 volts to the center contact will draw the arc across, causing the flash.
Step 9: Electronics: Step 1
Now, it is time to finish up the last disassembly step. We need to clean up the board, freeing the flash tube, and getting rid of the trigger bars. Dig up your solder sucker, soldering iron and let's go!
The pictures correspond to the steps below.
  1. Gather your tools. Then take off:
  2. One of the trigger bars.
  3. The other trigger bar.
  4. The flash tube.
  5. The flash tube supports
  6. The flash reflector. This pushed off easily once the flash tube was removed.
Step 10: Electronics: Step 2
The photos correspond to numbers again.
  1. Let's work on the flash tube.
  2. First, solder on two leads, of the length that you desire. For this project, I am only going to be moving things out about 4 inches, but I have gotten the flash to go off when the bulb is 3 feet out.
  3. Then, cut enough heat shrink to cover the leads and a good amount of the wire.
  4. Shrink the shrink tubing.
  5. Now, we need to create the trigger lead. Cut another lead, preferably out of a different colored wire, and strip the end down enough to allow you to make a complete ring around the flash tube.
  6. Solder the trigger lead into a loop around the flash bulb.
  7. Move the ring to one end, and bend the ring to follow the other lead. This is just one reason why the shrink tubing is important...
  8. Cover the entire assembly with either clear shrink tubing, or (less preferred) use clear packing tape. I didn't have clear shrink tubing of the correct gauge, so I had to settle with clear packing tape.
  9. Solder the entire assembly to the pads on the PCB. Make sure to attach the leads to the correct pads. If you do this incorrectly, you could have a very dangerous situation.
Step 11: Electronics: Step 3
The final step in electronics is to attach the trigger switch. If we didn't have a trigger switch, it would be hard to fire the flash, would it not?
  1. Find a switch. It needs to be Momentary and Normally Open (NO). Other than that, be creative. And, wire on another set of leads.
  2. Solder the leads to the PCB. My board had two pads for one of the trigger bars. Obviously, if you wire them up to those pads, the flash will not work...
This concludes the electronics portion of this Instructable.
Step 12: Test!
We can now pop in a battery, and confirm that the flash unit works.
Carefully insert the battery, and push the charge button WITH A NON CONDUCTING TOOL. I am not sure how much voltage runs through the charge button, but to be safe, push it with a tool...  Wait a second, and then release the switch. Hopefully, you should be able to hear the whine of the flash charging up. If not, don't fret, it might be just inaudible.
Then, the moment of truth. Press the trigger switch, and the flash should fire! If it doesn't check your connections, and make sure everything is correct. Make sure the battery is in the correct direction.
Wait about 3 seconds, and then push the trigger again. The flash should fire again.
Pull the battery, and fire the flash twice. This should almost fully discharge the capacitor, and then discharge it the rest of the way, using a tool with a non-conducting handle. THIS IS CRITICAL. Notice the second picture. Even though the battery has been pulled, the capacitor still has enough power to light the neon bulb, and can still fire the flash again.
Step 13: Insulate
Wrap the entire package in your choice of insulating tape (I used black Gaff tape). I left the battery easily accessible, but you can cover it up if you like. Make sure to do this properly, it looks nice if you take your time, and is much safer. You could also use a project box.
Step 14: Disguise in the Prop
It's now time to disguise the flash in your prop. For the witch's broomstick, I placed the battery pack in the tail of the broomstick, and left the flash dangling out the back. The trigger switch went in the top of the tail, where the witch could push it easily. When the pack was tucked inside the tail, the distance from the broomstick to the audience keeps everything practically invisible unless you know that the unit is there.
Be creative! Expose the wiring if it works, hide the wire in pipe, hide it in a plant, the possibilities are endless!
Step 15: Use
Right before the actor's entrance, you need to charge up the prop. Insert the battery, and push the charge button. This should prime the prop, so the flash will fire.
Once the actor needs to fire the unit, they should be able to just push the trigger switch, and the flash will fire. They can then wait 3 seconds, and the flash should have recharged, and can be fired again.
Once the actor gets offstage, pull the battery, and fire the prop until it will not fire anymore. It should now be safe(r) to handle.
Step 16: Ideas for Improvement
This concludes this project, but, I will leave you with the following:
As this is a theatrical prop, there are many ways to improve the effect.
  • Better battery holder: For more permanent installations, I recommend replacing the battery holder with one that has a switch.
  • Remote the charge button: To allow the actor to charge up the flash themselves, I would recommend attaching another switch that replaces the button on the PCB. This will simplify charging the circuit, and provides a backup.
  • Reorient the main capacitor: Every night, I had to repair the capacitor, by bending it back into place. If the location of the battery pack is taller, you can take and reorient the main capacitor upright. This reduces the chance that it will get bent. I considered it, but it wouldn't work in our case.
  • Better Case: Please, if you have the time and the option, install it in a plastic case... Please...
  • Multiple flashes synced together: By using a Dual pole, single throw (DPST) or a dual pole, dual throw (DPDT) switch, you can synchronize multiple flashes fairly accurately.
    • Build a Tool Contest
    • Remix Contest
      Remix Contest
    • Weaving Challenge
      Weaving Challenge
    27 Discussions
    thegeeke
    6 years ago on Introduction
    Nicely done! As someone who grew up programming intelligent lights for theater, I have 2 more suggestions about how this could be done.
    1. Position an elipsoidal, ParNel, or Scoop behind the actor (or just to the side) so that they are pointing into the audience. Preferably 2-20 fixtures. Use plenty of haze (preferably haze and not fog). At the correct time, flash your lights behind the actors so that it gives an intense effect towards the audience making them feel like the broomstick was pointed at them. It get's really fun if you can use gels and do different colors.
    2. Use as many intelligent lights as possible strobing different colors, positions, and if you have any decent gobos for the effect use gobos as well on the person the broomstick is pointed at. If you do it right, the lights should be only on the person the broomstick is pointed at, and the audience will be so dazled by the sudden lighting that they will not even notice that the broomstick didn't have any effects on it. It takes about an hour to program this sequence and it only lasts for a few seconds, so don't think this is the easy effect. ;)
    There are other ways of doing it, but these two (aside from pyrotechnics) are my favorites. Your ible is a fantastic option for groups that have extremely limited resources though! :)
    thegeekethegeeke
    Reply 6 years ago on Introduction
    Oh, with the static fixtures, don't flash them all at once, do them one or two at a time (depending on how many you have) randomly for a split second each. :)
    pjensenthegeeke
    I considered most of those, but due to the staging (the actress was up on a 4 foot tall platform at the very back of the stage), it would be almost impossible to get the lights positioned correctly for the effect.
    In the space we were using, there were 8 old intelligent washes that we could have used to finish up the effect, but they don't produce very much light... I have done something similar to your #1 suggestion before, and it has worked great, but it just wouldn't work in this situation.
    In this same show however, I did use a combination of an ellipsoid with a lightning gobo and the intelligents on the scrim to produce a stunning lightning through clouds effect. With everything flying behind the scrim (Remember, this is the Wizard of Oz, specifically the tornado scene...), the effect was perfect.
    thegeekepjensen
    Yes, I understand that the ideas I stated would not work in every situation, but I didn't see them in your effects list at the beginning, and since the idea for this instructable is to help people with their theatrical effects and based off of your picture I would say I got started in theatrical effects (lighting, sound, etc.) just about the time you were born, I just thought I would throw that in. ;) (Like I said, good job! As a matter of fact, I probably wouldn't have even thought about doing it the way you did.)
    pjensenthegeeke
    I agree, I probably should have included them, but I kinda forgot about it... Oops...
    And second, Thanks!
    Who do you do lighting for?
    thegeekepjensen
    I own a media production company, I mainly do freelance sound, but I still dabble in lighting from time to time. I started in sound for my church when I was 7, and I started doing intelligent lighting for community theater when I was 8 or 9. Most of my real "training" is in intelligent lighting, even though I consider myself more of an audio guy than lighting. I enjoy both though! (And since my first "real" job was at a climbing wall, I also train people on how to work on lighting and rigging.) :)
    missroberta
    7 weeks ago
    What did you do for the witches entrance? I am staging Wizard of Oz and we cannot use any pyro.
    pjensenmissroberta
    Reply 7 weeks ago
    Oh man, this is a blast from the past. If I'm remembering correctly, nothing actually. She just either jumped out of a wing or appeared in unexpected locations. If I was designing this today, I might have attempted a audience blinder method using LED fixtures. All fixtures full white, full intensity for half second, autofollowing into a blackout, then up reasonably fast. If the witch doesn't have to move far, it can work fairly seamlessly. I've used that method for both appearances and disappearances. Unfortunately, if you are in a small theatre that doesn't have LED fixtures, the effect doesn't work nearly as seamlessly because the heat up and cool down of the incandescent bulbs.
    We didn't want to use smoke effects for the entrance, because we were worried about differentiating the melting from the standard entrance, but you could make a fog-bag for a poofing smoke effect. You will need a large plastic bag. Put the bag offstage with the mouth towards stage. Fill the bag with fog, keeping the mouth fairly closed. Using a foamcore sheet (or just arms spread wide), pushing down on the bag rapidly will create a decent, billowing poof of smoke.
    Props Maker
    3 years ago
    Would you consider making one for me. I am props manager for Into The Woods and theatre has similar regulations. I make a lot of my own props but not anything like this!
    pjensenProps Maker
    Reply 3 years ago on Introduction
    It's probably easier if you find someone in your production! You probably have someone in your show (if not in the area) who can spin this up really quick. It took me less than a day to create this, and I was experimenting on the way. Talk to your tech crew, someone is bound to have the tools and expertise to pull this off.
    bonanno.mark
    5 years ago on Introduction
    Yeah, I saw the trigger going behind the reflector. I did as you did in the instructable and wrapped a stripped wire around the bulb. I experimented with moving the wire to see if I got a better firing rate. You are right that it needs to be at one end (I believe nearest the negative lead). I think though that you have a good point in saying that the trigger lead needs to have very low resistance. I handed over a broom today (they are on the stage for the first time today). I think I will try re-soldering the trigger lead on one of the other attempts and see if the firing rate improves.
    Thanks for the help. I will keep you updated!
    bonanno.mark
    pjenson - I am trying to re-create this (for the wife's WoO). I am having the devil of a time getting the flash to fire as often as it does when it is on the camera. I checked my voltage across the bulb leads and am getting 300v. I can get the bulb to fire but sometimes it takes 20 to 30 seconds before it will trigger. When I put a VOM on the trigger to ground leads I see that I don't have 300v. Any suggestions on what I am doing wrong?
    pjensenbonanno.mark
    Reply 5 years ago on Introduction
    Hmm, the trigger lead will only reach 300 volts when the flash is firing, which is often times too short for a multimeter to register. Does the indicator light turn on right before you can fire it? Or does it come on almost immediately after firing?
    You can also measure the battery voltage. If the battery is low, it will take longer to charge. You want a battery with a voltage above 1.4 volts for ideal use. One other test that you can do is measure the voltage across the capacitor after you fire the flash. You should see the voltage slowly rise back up to 300 volts. Once the capacitor reaches around 270 volts, you should be able to trigger the flash. The time it takes for the capacitor to reach 300 volts is the limiting factor in most cases. If you still are having issues, you might have a bad switch.
    Also, the brand of camera that you use can affect the charge rate. I used a Kodak Powerflash, but if you have a different camera, it might be slower.
    bonanno.markpjensen
    pjenson - first off, thanks for the reply. I appreciate it. So, to answer your questions....
    I have a "Max Hold" on my VOM and it USUALLY is fast enough to catch the trigger voltage. When the circuit fires, it USUALLY registers above 300v. When it isn't firing I can actually watch the voltage climb up to the required 300 as I cross the "shutter/fire" leads multiple times.
    I tried several batteries (including some Lithium). I never got the same rate of firing that I was able to get off the camera. When the circuit is untouched (still on the camera) I am able to fire every 4 or 5 seconds. Once I removed components from the board.... firing became erratic. All the batteries had a voltage greater than 1.5 (the Lithiums where closer to 1.7).
    I measured the voltage at the bulb, that SHOULD have been the same as the capacitor, right? It read 300v.
    I have to admit, I thought the problem was first one switch and then another. Finally I just started crossing the leads leading to the switch. At first it seemed to work - then I was back to the erratic behavior.
    I will say that I bought several (cheap) cameras and all of them had the issue. As soon as I moved the bulb off of the board, firing would become erratic. Now, that seems to point to my soldering (which I will say is not the best). So I used alligator jumper leads. Same issue.
    In the end I gave up and kept all the components on the board (there was a LOT of 4 letter words expelled before I did this). I have soldered the "charge" leads down and actually soldered the leads for the switch directly to the copper tangs that are on the board. At the moment everything is working and I am able to get a good firing rate of every 5 seconds. Of course, this means that I have the entire unit to put at the end of the broom. That is a job for the morning. I am including some pictures of the Frankenstein's Monster that I created. I will post what it looks like in the broom tomorrow.
    Thanks!
    pjensenbonanno.mark
    Aha! I think I found your problem. When you took the bulb off the board, did you move the reflector with it? When the flash fires, the whole reflector gets brought up to 300 volts. There should be a little copper lead which goes in between the board and the reflector, and that needs to be securely attached and have low resistance to the reflector. Alternatively, you can just do what I did, and form it into a loop that fits around the bulb, and ditch the reflector entirely. The catch with that is the loop needs to go around the correct side of the bulb or the flash might not fire.
    nbonanno
    This looks great and just the kind of thing I need to do in a church production of Wizard of Oz. I assume there was a button the Witch pushed to make the flash...where was it hidden?
    pjensennbonanno
    Thanks! If you notice the main image, you can see how her hand is positioned right at the base of the broom's bristles. That is where the button is hidden. The bristles had about two inches of extra length above the coil on the broom, so I could tuck the button the coil, and the board underneath the coil. You can see this clearer if you go to step 14, and look at the annotations on the image.
    nbonannopjensen
    How embarrassing. I had found this front page with a search and didn't realize there were actually steps I could follow! And how nice of you to take the time to show the rest of us how to do this!
    pjensennbonanno
    Hah! No problem! We all have that one moment of visiting a new website and completely failing at it! Welcome to Instructables!
