Mini Peltier Air Conditioner (Plans)
382,886
303
105
About: Hi I'm Angelo! I am a college student taking my engineering majors in BS-EE/ BS-ECE at the DLSU. I use my course as an inspiration for making my current projects! I've been posting projects here ever since I...
This Instructable will show you how to make a environmental friendly portable air conditioner. This machine uses a Peltier Module as a cooling  mechanism and some cooling fans for blowing air.
Supplies:
Step 1: Here Is a Picture How It Works
This is just like the everyday air conditioner that we use. The only thing unique about this that the cooling unit has no moving parts. The only moving parts here are the PC fans.
Step 2: Needed Parts, Tools and Materials
This page shows you the things that you need that you need to buid this machine.
Step 3: Ilustration
Step 4: Notes Before Starting
Step 5: Electrical Wiring
Step 6: Attaching the Heat Sinks
Put epoxy on both sides of the peltier module and connect the heat sinks together.
Note: Copper paste would be better.
Step 7: Attaching the Fans
Put epoxy on the heat sinks and connect the two PC fans to the heat sinks.
Step 8: Attaching the Wood
Attach the wood with epoxy.
Step 9: Attaching the Wood and the Metal Net
Use Epoxy
Step 10: Attaching the Wood
Use epoxy.
Step 11:
Step 12: What It Looks Like
Step 13: How to Use It
Use the tube for better ventilation.
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    105 Discussions
    snowluck2345
    7 years ago on Introduction
    a good improvement would be to water cool the hotside of the peliter and to put the radiator outside. peltiers use alot of electricity, they use 100w to move 100w of heat roughly.
    alherrle
    20 days ago
    Please consider adding a fuse on both positive and negative wires close to the battery
    AsanyaC
    10 months ago
    Hello sir,
    I tried building a peltier module using TEC12706 but after attaching the materials together, with a 12V cooling fan and a 12V 3A adapter. I found both heatsinks getting warm. I was supposed to use it as a cooler. Please sir, what could be the cause of the malfunction?
    ReeceB12AsanyaC
    Reply 5 months ago
    First of all, you should probably have a more powerful adapter than 3A because one peltier would draw around ~3A and two will draw around 6. One reason that you find that both sides are getting hot is because you do not have a big engof heatsink on the hot side and not having a big enough heatsink will cause your peltier module to burn out very quickly. A good size to have on the hot side is about 4 or 5 times as big a heatsink than on the cold side.
    VarunM66
    1 year ago
    Instead of and air conditioner use Peltier to make a freezer. It's much more effective.
    steveastrouk
    9 years ago on Introduction
    I am a professional designer and user of TEC/Peltier modules
    This instructable, whilst very enthusiastic, and very nicely illustrated won't work as advertised. Moving HEAT is not the same as creating a temperature difference.  A Peltier cell will only create a maximum delta T of about 50 C, and pump NO heat, or it will pump its "rated power" at ZERO delta T. In truth, getting 25 C at half power, in normal ambients is doing well.
    Real airconditioners can cool more than their electrical input, Peltier cells can't technically, the Coefficient of performance of a real aircon is >> 100%, for a TEC< 100%.
    Peltier have an average efficiency of 15 to 20% while standard A/C are about 60%
    the only advantage of one using a peltier A/C over a pump one i the reduction of moving part (thus long term reliability) and possible noise reduction caused by the pump, but they could have improved that since i still run an hold 1995 A/C :)
    corradiniMonsieurDudu
    Reply 1 year ago
    There's also size, complexity, and capital cost (vs. operating cost). For larger-scale operations, traditional cycled A/C is generally more appropriate; for smaller, portable, and/or other applications a peltier often makes good engineering and/or economic sense.
    gn0stiksteveastrouk
    Reply 6 years ago on Introduction
    Doesn't a device with COP > 100% break the laws of thermodynamics? Seems like if that were true, you'd be able to harvest the difference in output to power the system, which... you obviously cannot.
    TrygveLgn0stik
    Reply 4 years ago on Introduction
    At least in theory it should be possible to make a heatpump power-plant. The energy is absorbed from the surroundings. The problem is to make enough heat to run a small power-plant with losses here and there, with a fairly expensive setup(compared to potential production).
    A heatpump regularly has a COP above 3, for heating purposes(1 part electric=3+ parts heat output, depending on outside temperature).
    steveastroukgn0stik
    Its easier to point you at Wikipedia than to explain here, but suffice to say, no, thermodynamics isn't violated. ........
    KodiY
    2 years ago
    hello friend may i know the use of epoxy and metal net used in this
    please let me know this
    yashwanthprabha@gmail.com
    Hi, As we know peltiers are only 15 to 20% efficient as compared to A/C refrigrant gas type, but what if Peltiers are used as Heat pump inplace of compressors in A/C units. Yes they will consume more energy, but where is the problem?? We can use free energy to supply it that power. The Renewable energy source, Yes!! The sun. We can use Solar panel + invertors + Peltier TEC and can make such an assembly which can circulate water through cold and hot side of peltier. The we can run that water through Cooling coils as is done in normal AC. The more the sunlight/heat we get more will be energy produced and more heat will our TEC pump out of the room. In Areas where there is hot temperature.... This will prove very effective!!!! and you don't have to pay any electricity bill too. Just some intial investment in Solar panel, panel invertor and TEC A/C assembly.
    We can call it - SOLAR THERMOELECTRIC AIR CONDITIONER. :) :) :)
    If you want to know how to build one!!! contact: bhimeshsharma@gmail.com
    deadmonkey01
    2 years ago
    Please don't epoxy directly to the peltier device!!
    Use heat paste where the heat sink comes in contact with the devices. Not doing this will most likely kill your device as soon as it reaches the temp threshold for your particular peltier module.
    rmckay5
    5 years ago
    Hi,
    I'm trying to make something very similar to this design, but I'm having some wiring problems. Peltiers are really hard to find where I live and the only one I could get my hands on has no markings and no instructions - the only thing the seller knew about it is that it's 12v. I have a 12v 3.3A DC adaptor and when I wire it all up in parallel the LED on the adaptor blinks, the peltier works, but the fans just twitch like they're trying to start but can't. When I wire it in series it all works fine, but the peltier doesn't get very hot/cold at all. Is my DC adaptor amperage too low or too high? Any suggestions would help!
    kldpsh7rmckay5
    Reply 3 years ago
    Your CD adapter amperage is low. It requires 60+watts to work but you have only 12*3=36. Use a 12 volt battery instead
    StevenS63rmckay5
    Reply 3 years ago on Introduction
    Hi Rmckay5,
    I found some fans will not operate outside of a specific voltage range - I'm guessing they are voltage regulated/gated.
    I've had success with the cheap non-led Coolermaster fans for voltages above 30-34V DC.
    They run.
    siemenwautersrmckay5
    your power supply indeed has a to low current. the reason its blinking is becous it shuts down do to the lack of power / starts up for a second and then shuts down again ( this is the easiest way to say it its actually more complex) thats why your fans are twitching. if you wire it in series the current is to low for your peltier do to the fans that requir less current.
