Third Hand++: a Multi-use Helping Hand for Electronics and Other Delicate Work.
382,270
1,464
278
In the past I've used the third hands/helping hands available at chain electronics shops and have been frustrated with their usability. I could never get the clips exactly where I wanted them or it took more time than it really should to get setup right. I also wanted the ability to hold small circuit boards and alligator clips just don't do a very good job.
I was familiar with the adjustable coolant hose systems used to spray coolant at cutting tools in the machining industry and thought that would be a great place to start. I ordered various nozzles and hose segments from my favorite online machine tool supply company and started experimenting. This is what I came up with. While it still has plenty of room for improvement it has served me well over the last 3-4 years.
These arms can be placed into pretty much any position and they will stay there.
Another nice feature is that you can make all sorts of attachments for holding whatever you need to work on. So far I've made a circuit board holder, a clamp, a mount for an LCD, and an extraction fan for keeping fumes out of your face.
All you really need are some simple hand tools, a couple taps, a drill bit and a drill to make the basic version. If you have all the tools you need, it can be made for $20 or less.
Step 1: Getting Started
The first step is to gather everything you'll need.
Tools:
- Drill (A hand drill will work but a drill press would be better.)
- 3/8" drill bit
- 1/8-27 NPT tap
- 6-32 Tap
- A tap handle
- Ruler
- Center punch
Don't forget safety glasses!
Parts:
- The Base:
I used a block of 1/2" thick aluminum (5.75"x2.5"x0.5"). Aluminum is heavy enough to be stable and is easily tapped. You can use whatever you want as long as it is at least a 1/2" thick and can be tapped. (Plastic, wood, MDF, steel, etc...) The lighter the material, the larger the base needs to be in order to remain stable. If the material is too soft the threads will wear out and the arms won't stay in. If you don't have a local source for the aluminum you can order it from an online metal sales company cut to length for about $6 plus shipping. I have used www.onlinemetals.com for other projects in the past.
- The arms:
The arms are made from coolant hoses and nozzles used in the machining industry to keep cutting tools cool and lubricated. I used the Snap Flow brand coolant hose system which I bought from www.use-enco.com. They sell a "Male NPT Hose Kit" that has 13" of hose and an assortment of nozzles and connectors. That gets you most of what you need to make a two handed Third Hand. I'd recommend buying two kits and a few extra nozzles and connectors. For around $12 you will have more than enough parts to make 4 arms.
For each arm you will need:
- One 1/8 NPT connector
- 4-5" of hose
- One 1/8" 90 degree nozzle.
You may want to consider buying the hose assembly pliers for $23. They are a little difficult to snap together by hand. I didn't buy the pliers but I kind of wish I had.
- The Hands:
Each hand is made out of a banana plug threaded into the 90 degree nozzle and an alligator clip. I chose the "Flexible Banana plugs (2-Pack)" from radio shack because it has 6-32 threads that will thread into the nozzle. The alligator clips are the standard 2" size.
Step 2: Building the Base - Layout
Once you have chosen your base material you will need to cut it to size, if it has not been done already. I used a block of 1/2" thick aluminum (5.75"x2.5"x0.5").
Next you need to layout the location of the hole for each arm. In this case I'm using three arms. The arm locations are not critical, they just need to be close enough that the hands will be able to reach each other and symmetrical so they look nice. It will also depend on the shape and size of your base material. A triangular base might also be a good way to go if you plan on using 3 arms.
Use a center punch to mark the center of each hole for drilling.
Step 3: Building the Base - Drilling the Holes
I usually start with a smaller drill bit to get it started and then finish it with the 3/8" bit. Make sure you drill all the way through the material so it can be tapped. You want the hole to be perpendicular to the base so the hose connector will be flat on the surface when threaded in. This can be done with a hand drill but a drill press would be easier.
Step 4: Building the Base - Tapping the Holes
Tap the holes for the arms using the 1/8-27 NPT tap. Remember that pipe thread is tapered so you will need to tap it deep enough that the hose connector screws all the way in. But tapping it too deep will cause it to be loose and potentially strip the threads on the hose connector. Also remember to keep the tap perpendicular to the base.
I don't have a tap handle large enough for the 1/8-27 NPT tap so I used one of my sockets designed to hold taps.
If your base is metal, I recommend using thread cutting oil or any lubricant like WD-40 that you may have on hand. I use Tap-Magic thread cutting oil.
Step 5: Building the Base - Surface Finish
Now that the holes are drilled and tapped you can smooth the surfaces and round the corners using sand paper. I started with 80 grit, then used 220 grit and finished it off with coarse Scotch Brite. The Scotch Brite gives it a nice satin finish.
Step 6: Building the Hands
Remove the red and black covers from the banana plugs and discard. We only need the metal parts. Using the 6-32 tap start threading the 90 degree nozzle. The banana plug threads aren't actually 6-32 but are close enough and provide a nice tight fit. Once the banana plugs are installed you can just slide the alligator clips onto the banana plugs.
The alligator clips work pretty well as is, but they do have a tendency to rotate when holding longer or heavier items. In the next step I'll show you how to improve them.
Step 7: Improving the Hands - Optional
As I said in the previous step, the hands have a tendency to rotate on the banana plugs. While this is a feature I wanted, the ease at which they rotated was a problem in some situations. This is in part due to the alligator clips expanding when installed. You can see the gap in the picture below. To fix this I came up with a couple solutions. You can certainly skip this step and be happy with the results but doing this will make it a lot easier to use.
Metal Sleeve:
I had some stainless steel tubing sitting around that was the perfect size. OD:1/4" ID ~3/16" (0.192"). I cut a 3/8" long section of tubing and using a hammer, lightly tapped the alligator clip into the sleeve. This is the best fix in my opinion.
Wrapping with wire.
I found some thin solid core wire, wrapped it around the clip and soldered it in place. This is the easiest and cheapest solution to the problem.
Step 8: Assembling the Arms
Unless you bought the assembly pliers($23) when you ordered the coolant hose parts, assembling the arms can be a little tricky. I didn't buy it, but here is how I figured out how to put them together with ease. Slide the parts you want to join onto a #2 Phillips screwdriver. This will keep everything aligned and all it takes is a sharp tap to get the parts to snap together. Just hold onto the hose and tap it on the work surface in the direction of the part you want to attach.
Although theses pictures show 10, I found that about 7 hose segments per arm to be about the right length. Of course that is my preference and you can use as many as you want.
Step 9: Finishing It Up.
Now all you need to do is thread the arm assemblies into the base and you're done!
Next I'll show you some of the attachments I've made.
Step 10: Attachments - Circuit Board Holder
The circuit board holder has been one of the best attachments I've made for the third hand. I've used it to hold boards as small as an inch wide all the way up to ~8 inches wide.
Making these might be beyond the capabilities of most people because of the tools needed.
I used two pieces of 1/2 x 1/4" aluminum** each about 2.5" long. In the end of each I drilled a 5/32" hole around 3/4" deep. You could do that with a hand drill and a vice but there isn't a lot of room for error. A drill press or a mill would be best.
To make the slot I used a slitting saw in my mill. The slot is a little over 1/16" wide and 1/8" deep running the entire length of the rail. I suppose you could do this with a hack saw or dremel, but it would be difficult and I suspect the results would be pretty rough.
** - Next time I would make them out of Delrin or other plastic since many circuit boards have components and traces right up to the edge of the board and could be shorted by the aluminum.
Update - Below is a picture of the circuit board holder made out of black Delrin plastic. These were a bit easier to make since I was able to use a 1/16" end mill instead of the slitting saw.
Step 11: Attachments - Fume Extraction Fan
I made an extraction fan using an old CPU cooling fan, a bit of filter material, another 1/8" 90 degree nozzle and a couple screws. All stuff I had lying around the house.
For the filter I cut a piece of white scotch bright to the shape of the fan and attached one corner with a screw. The opposite corner I used a long screw to go through the fan and filter into the nozzle. Connect it to a twelve volt source and solder without having fumes in your face.
In my next version I plan to add white LEDs to provide extra light in addition to the extraction functionality.
Step 12: Attachments - LCD Mount
I made this mount to hold a graphics LCD a while back when I was playing with a BASIC STAMP II.
I used a mill to build this, but I'm sure it can be done with hand tools.
I milled the black bracket out of delrin plastic, drilled and tapped the appropriate holes and screwed it to a large straight nozzle. I'm not going to get into the details as it is fairly self explanatory and not everyone is going to have the same LCD. I mostly wanted to show you the variety of attachments that can be made for the helping hands.
Step 13: Attachments - Clamp
This clamp can be used to hold larger items than what will fit in the alligator clips.
All I did to make this was to remove the bolt at the end of the clamp and replaced it with one twice as long. Then I screwed it into a straight nozzle that I had drilled and tapped to a M3-0.5 thread.
This version can hold about 10oz. before it starts to pivot. However if you drilled a couple holes in the bar near the stationary end of the clamp and attached it to a 90 degree spray bar nozzle with two screws it could probably hold a few pounds.
UPDATE: I've made the improved clamp arm and it holds about 2.2lbs. I used a right angle adapter to make positioning the clamp easier. #4-40 screws thread right into the spray bar nozzle without having to tap them. However, drilling through the hardened metal bar of the clamp took some effort.
Step 14: Other Attachments and Ideas
ESD
When I made the first version, which I've used for years, I was concerned with ESD and so I soldered a wire to the banana plug which ran inside the arm and was grounded to the base. I also drilled holes in the front and back so I could plug in a static wrist strap in the front and in the back, connect it to the static ground at the workbench. I probably should have soldered in a 1M ohm resistor to the wire going to each hand for more protection.
Powered Hands
I've also thought about adding binding posts to the base and wires going up to the banana plugs so that voltage can be applied to the hands for powering circuits or loads being held by the alligator clips.
The down side to the above ideas is that the left and right hands are wired to the base so changing attachments, that requires a nozzle change, means you have to disconnect the wire. However, most of the attachments I made that require a nozzle change are primarily used on the center arm. The alligator clip hands and the circuit board holder just slide onto the banana plugs so no nozzle change is required.
DMM/O-Scope Probe
I am also working on an attachment to hold voltmeter leads or an O-scope probe. I always seem to run out of hands when measuring signals on a circuit board.
Magnifying Glass
Although I never used the magnifying glass on the old helping hands I had, I'm sure many people would use one. It would be easy to adapt one to use on the center arm.
LED Light
A little extra light would be helpful as well. I plan to combine the extraction fan and an LED light.
Small Parts Tray
Below is a picture of a base that I made for a friend that has a pair of parts trays milled into the aluminum. Also below is a picture of a 4 armed version that I made for an instructables member with 3 pockets milled into the base.
Other thoughts
There are a ton of different nozzles and connectors available for the coolant hose systems. I'm sure there is no end of attachments and accessories that can be made for this third hand.
12 People Made This Project!
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
278 Discussions
mrtiger2016
2 years ago
Another variation of this by using the premise circuit board holder plus the flexi pipes and alligator clips some hookup wire you can really upgrade it nicely.
treesapmrtiger2016
Reply 12 months ago
I love the idea of attaching these to the PCB mount. I'm going to use the extra arms that came with my set to do this. Thanks for the idea!
ClydeS
2 years ago
You have to add a piece of 1/2" copper pipe to the 1/2" male adapter. It just slides inside the adapter. You could glue it in but it would be better to solder it
ClydeS
4 years ago on Step 1
Perfect! I was soooooo tired of using crappy third hands for soldering. This is just perfect.
I modified mine so that each arm is on a freestanding base instead of a fixed station. This provides much greater flexibility for the sort of soldering that I do -- jewelry mainly.
The base is made of a 1/2" cast iron floor plate, a 1/2" male adapter (copper plumbing fitting) and a 1/2" connector. I removed the "valve" piece on one end of the tube and inserted that into the connector/base along with some glue. Then inserted and glued alligator clips to the other end. I also filed down the teeth on the alligator clips so as to not mar the soft metals that I work with.
I made four of these with two being half the size of the other two, again for greater flexibility.
DsdudeClydeS
Reply 2 years ago
I know your comment is two years old but any chance you have some links for the different parts you used? I like the idea of each arm being free.
ClydeSDsdude
Reply 2 years ago
Hi,
Sure. Here's a few links
Flange plates
http://www.ebay.com/itm/10Pcs-1-Black-Malleable-Threaded-Floor-Flange-Iron-Pipe-Fittings-Wall-Mounted-/381855931525?hash=item58e8631c85:g:7kYAAOSwXeJYMsf3
Male adapter
http://www.ebay.com/itm/1-2-C-x-1-2-Male-NPT-Threaded-Copper-Adapter-/251649760875?hash=item3a977e9e6b:g:8PsAAOSwnDZUGvXB
I'm guessing you can figure out the other parts
DamianP3
3 years ago
Awesome idea, but what can I use instead of the coolant hoses? Because in my country they're not cheap nor easy to find. Thanks!
basha2DamianP3
Reply 3 years ago
you could probably get a ton of wire and coil it around itself, then cover it in heatshrink. You could also use plain larger gauge wire. This is also a way to ground the clips.
Archy
6 years ago on Introduction
I'm building the same thing, with the magnet fittings from locline instead of tapping my steel block.
However, since I'm using a 14x14"x1/4" steel panel as a workspace as well, I'd like to coat it so it's not a bare metal surface that is a) conductive b) hard (dropping delicate components) c) slick (said components rolling off, and if unbroken before, broken upon falling off the surface).
I've put a fair amount of time into googling things like "rubber metal coat", "coating metal vinyl", etc. But the best I've come up with is plastidip. It seems that plastidip is really susceptible to sharp edges, which concerns me, as removing the magnetic mounts will probably require me to leverage them against their edges.
I need a durable, soft/rubbery coating for steel.
So, any ideas for what I'm looking for, or how I can search better?
BjörnP2Archy
Reply 3 years ago
Have a search on ebay for Silicone Oven Sheet or "Silicone Baking Mat" or similar combinations, there should be heat tolerant silicone sheets in different shapes, colors and sizes for around $2US incl. shipping.
I have not tried them for this purpose (but for their intended) and seeing they are insulating, heat tolerant and not very slippery, they may be ideal. Not sure if they are ESD safe though.
Liamthe1stArchy
Reply 4 years ago on Introduction
I do a little out of the box thinking Children's mats made from recycled rubber type material sold in Aldi and Lidel stores in the EU and UK of course.
I have them on my Garage workshop floor and on my work bench, nothing has ever broken these mats lock together like a jigsaw. anti slip too not sure about anti satic?
AndrewB52
3 years ago
The original idea which is now quite some time ago is very imaginative. I am in the process of trying to make my own improvements. For one thing, I wanted something that was in and of itself heavy, that did not need to be clamped. So, I am working with 2 separate prototypes, one that is 3/8" steel plate 10 X 12 and the other smaller 1/2" measuring 6 X 8. As you would imagine, they are both heavy. There is a magnetic mount one can get from modularhose.com but it is rather expensive. I am trying various neo magnets covered in rubber, plasti-dip or paint. I wondered what would be the best cover for the metal. Each has a plasti-dip rubber base preventing them from slipping on any surface or potentially to be use for the magnets which hold the hose. The challenge has been finding a surface that will be durable and will not scratch or dent from the magnets which are strong. I have tried automotive undercoat...not so hot. Now trying an automotive high temperature paint as well as a truck bed cover aerosol. The latter has been problematic because it takes forever to dry. The high temperature paint is curing. Yes, I know this sounds a bit over the top, but I want it to look nice as well as function well. I purchased the standard Loc-Line because it is better made, that is more stiff than the knock off. I am going to use both alligator clips and reverse tweezers. I am trying to design this so you can change them.
What I have not decided is whether or not to include a bright LED. My question is whether or not people prefer that or prefer to use a headlamp when they work. I welcome any thoughts. I will post images when the project is completed.
Odonata
3 years ago
This is a classic. I finally got around to making one. I made my workstation from wood and drilled holes to mount the arms (via 3-way junctions, machine screws, and hex nuts.) This way the arms can spin.
Mounting the attachments to the loc line was an issue because I didn't have nozzles handy. I also wanted more flexibility. So I hotglued 8-32 nylon thumbscrews like the ones here below into the links.
http://www.amazon.com/dp/B000OD0JOA/ref=biss_dp_t_...
Hot glue bonds well to nylon and I hope to the plastic of the loc line. Time will tell, but it seems really solid. I like this solution because I can mount anything that fits onto an 8-32 screw with an acorn nut, hex nut, or even a decorative filial (pictured). Thanks again for the idea!
Drakemoore
3 years ago
Curious, what's the rough weight that a set of three of those hose hands can handle without getting wobbly / sagging?
uspatriota
4 years ago
here is my spin on your idea...I mounted it to a lazy susan apparatus
JGUZMANO
3 years ago on Introduction
Thanks for sharing, great Instructable. Very useful. I'll post pics of mine when finished.
colinj
This is a great instructable and a brilliant tool! Kudos!
I too bought the SparkFun version as I don't have the tools to make one of these and I saw that Ryan gets something back from each purchase.
I did want more arms and larger alligator clips than what SparkFun provided I got some extra arms and then headed out to get some banana plugs and clips. Since I didn't have a proper tap for the nozzle/banana clip attachment I went the route of heating up the threads on the banana clip with my heat gun. Once I got the metal warm enough to soften the plastic I was able to screw the banana plug in to the nozzle.
