This Footstool Is a Better Way to Use the Toilet
130,003
708
171
About: It's said that to perfect a skill takes about 10,000 hours of work and study. If that's the case I've got around 9,000 hours to go. But, like they say, it's not the destination but the journey.
On the television show "Shark Tank", where entrepreneurs seek funding to help bring new products to market, I was introduced to a product called the "squatty potty". The goal of the product was to re-align a persons internal plumbing when seated on a toilet thereby resulting in a more natural squatting position when defecating. Simply raising the feet off the floor accomplishes the desired result. Lo and behold, the sharks bought in and agreed to help finance and distribute the product. At the time, while I found the idea interesting I also saw it in a mildly amusing light. However, some time later I mentioned the show to my daughter and son-in-law and was surprised to hear that they owned one and loved it! A subsequent google search showed a number of different designs online so, rather than buying the plastic version, I decided to make a nicer looking one myself and give it a try. I'm glad I did. I'll be darned if it doesn't work!
Supplies:
Step 1: Easy to Build
It only takes four pieces of wood to build your version of this "defecation station" (bad joke name #1). It consists of a top, two legs and a center support. I was able to build two units for under $30 which is roughly the cost of one plastic "poopin' pedestal" (bad joke name #2, sorry!) from a retail store.
The general dimensions are as follows:
Top: 20" x 9"
Legs: 7" x 8"(7" is the height the legs before making a second, angled cut to pitch the top of the stool at a slight downward slant after assembly. Simply take a straight edge and draw a line from the back of the leg to the front so there is approximately a 3/4" difference in height. Make the angled cut to arrive at the final dimensions of the legs: 8" long by 7" at the rear and 6 1/4" at the front).
Center support: 1 1/2" x 13 1/2"
Using any nice hardwood will allow you to stain and finish the unit to your liking. I chose 3/4" red oak which I purchased at my local home center.
Step 2: Shaping the Top and Legs
Shaping and then rounding the top and bottom of the legs is simple and straight forward.
1) Draw the pattern for the top - a place for each foot with a cutout allowing the unit to be pushed under the toilet when not in use. I used a hole cutter to draw the internal curves of the top.
1) Using any round lid or can just trace the desired curve on the outside corners of the top and legs.
2) Take a jigsaw and cut out the pattern and corners on the top and legs. (Use the hole cutter to cut the internal curves for the top.)
3) Sand by hand until smooth and any burn marks have been removed.
Step 3: Assembly
I assembled my footstool using pocket holes and screws. Pocket hole construction provides rock solid joinery that often doesn't require gluing. If you don't have a pocket hole jig it is just as easy to drill angled holes for nailing the pieces together. If nailing, be sure to add glue for additional strength. Clamping the pieces before screwing or nailing is a must.
Since your feet simply rest on the footstool there won't be a lot of stress on the legs so whichever method you choose for assembly should be fine.
Step 4: Stain and Finish - Then Take a Seat
The final step is to stain and finish your footstool. After staining I applied two coats of Watco Danish Oil to the entire stool. I then applied three coats of polyurethane to just the top for extra toughness and protection.
That's all there is to it. A simple weekend project that you enjoy using whenever nature calls.
5 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
171 Discussions
Steinzel
2 months ago
I've been looking for some easy plans for one of these! It really does help!
Thanks!
ghhillbilly
2 years ago
i'm gonna make some of these thanks
bidetfan
2 years ago
Awesome idea! Thank God you can't make an attachable bidet out of wood because I'd be out of business real quick! LOL. We think that the only thing which can make going to the bathroom even more comfortable and effective is using water instead of toilet paper to clean. And the most cost-efficient way to do this is through a bidet attachment. We sell a line of attachable bidets and would love your business (pun intended!). Please visit our website and give us a try! You have nothing to lose - we have a 30 full money back guarantee. Check us out! Thanks a lot!
https://superiorbidet.com
ColH2
2 years ago
I cannot believe the amount of comments that are negative with regards a squat stool. I cannot believe any doctor states there is no scientific evidence to support the benefits, because their is scientific proof. I started squatting on the top of public toilets over ten years ago for hygiene reasons and I instantly enjoyed total evacuation of my bowel without having to wipe my butt more than once. I looked forward to going to the beach every day just to squat. I have a stool at home, but it is not quite as good as the deep squat, thus why I am here today. I can only believe that the negativity from some has to relate to the fact that squat toilets are something Islam has given to the world, or your bowel is so twisted nothing will help.
mrstan
3 years ago
Can not resist.. have to post this classic related picture.. Someone has to do it!
Donna55959.
3 years ago
Squatting is the natural way to poop. Humans have always squatted - there were no toilets in the pre-historic age and it is only in fairly recent times that we have had porcelain toilets to sit on. Many people who suffer from constipation find squatting works much better. I had a friend who lived in Dubai (where their toilets require you to squat) and she said she never suffered constipation while she was there. A baby poops lying down because they cant squat. as soon as they walk they squat. Humans are meant to squat.
Adamik
3 years ago
NPNana
3 years ago
I don't know who first came up with this nonsense, but my doctor says just the opposite. Look at a baby. Do they get in a squatting position to poop? No. Do they have any problem? No. They are stretched out straight. My doctor says to stretch your body out as straight as possible to get the best results. I'll take my doctor's advice over some unknown entity trying to sell a product.
marvelljonesNPNana
Reply 3 years ago
Once they learn to walk, they squat every time. Until they're potty trained. Most other primates with solid food diets squat. It needs more scientific study. It's possible our bodies adapt over time to using toilets. Maybe we need to study isolated primitive peoples and see how they go.
BrettlerNPNana
Reply 3 years ago
haha, ya cause all doctors know everything right.... they are all knowing and all of them are never wrong.... babies also dont have a very developed digestive system yet not to mention most of what is put into them is either a liquid or mush, so its easy to go through them in general as their digestive system developes. It is so amazing to me how people have completely lost all ability to use common sense and even more so that common sense is somehow being lost from society. Even with all the information at the tips of your fingers ....
zorrothefoxNPNana
Reply 3 years ago
Take a look at this video... It shows the anatomical reason why you SHOULD be squatting... There is a muscle at the end of the large intestine which keeps the colon clipped shut... This muscle opens up completely when you squat at a particular angle.
ccrazedzorrothefox
Reply 3 years ago
The video is an advert trying to sell something and as such is not a viable source of fact.
JohnR17ccrazed
Reply 3 years ago
Invalidating something without evidence is simply silly. YEs they have a video explaining how it all works. The vid is accurate the info is fairly accurate. The choice is to buy one or not, nothing more.
ccrazedzorrothefox
Reply 3 years ago
zorrothefoxccrazed
Reply 3 years ago
then check this out https://en.wikipedia.org/wiki/Anismus
"Conversely, relaxation of the puborectalis reduces the pull on the junction of the rectum and the anal canal, causing the anorectal angle to straighten out. A squatting posture is also known to straighten the anorectal angle, meaning that less effort is required to defecate when in this position.[15]"
Hope that helps!
JohnR17NPNana
Reply 3 years ago
If you have ever served in the Army, toilets do not abound where you may end up. Squatting with the back against a tree for support , allows for everything (i do mean everything) to come out. No need to push down hard to get things moving. .
ishamsulNPNana
Reply 3 years ago
I'm not sure if you've ever travel to Asia. Squat toilets are normal there, and even if there are sitting toilets, you'll find people that are not sure how to use this, so they squat on the seat (thus the foot prints on the seat... yes not very nice). My Malaysian great grandmother was a midwife, she told my dad that after sitting toilets were introduced in Malaysia, women started struggling to give birth at home, apparently due to the underdevelopment of core, hip and leg muscles.
wmistlerishamsul
Reply 3 years ago
Until a couple hundred years ago humans always squatted. Our evolution is still set on squat.
willbillclarkwmistler
Reply 3 years ago
When I was in Japan --years ago, I was also struck with the squatting method; thinking it was rather primitive. When I found out that hemorrhoids are almost non existent and constipation rare, I realized that "form should follow function". If I was building a home from the start, I would put one in.
SpecimenBNPNana
Reply 3 years ago
There was an article not too long ago asking a gastrointestinal doctor if there was any benefit to squatting. He said there's no harm in it but no scientific benefit. It's not going to make you poop better. This is just like the toilet paper over or under debate. It makes no difference.
