Tip for How to Remove Dents From Wood With Just an Iron
13,090
229
12
Supplies:
Step 1: Dented Wood
When it comes to making furniture, it is important to have wood that is free of dents and scratches. During this particular build, I accidentally laid a piece of wood on the ground and it got all dented up, but it can easily be salvaged! All that you need is an iron.
Step 2: Ironing Out the Dents
Once your iron is heated up, apply it to the dents and use the steam function directly on the dents. The steam and the hot iron will pop out most of the dents, unless they are really deep.
Step 3: Done
Most of my dents were just surface dents, so the board came out good as new!
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    12 Discussions
    nsimpson4
    4 years ago
    I used to work in a furniture factory, and we done this all the time. It's best to use a damp rag under the iron to prevent burning. Also, if you just have a small dent, you can just put a drop of two of water on it. In either case make sure it is fully dry before painting or staining ir it will ruin the finish.
    dmržljak
    4 years ago on Introduction
    I just can't belive my eyes! Great job! You got my vote!
    CapnGonzo
    4 years ago
    Thanks for pointing that out cajunfid, ya definitely only do this to untreated wood to avoid damage. Yekreb, I'm not sure, I've done it to pine, and I've seen it done to a walnut rifle stock when it was being refinished. So it may work on hardwood since it worked on the walnut.
    yekreb
    Will this work for hardwoods too? Like teak flooring.
    cajunfid
    Nice job! I think it should also be understood that this works best on untreated/unstained wood. If the wood is stained there is the potential to cause hazing.
    ThumbSucker
    4 years ago
    My computer seat leaves a mark on my wood, Ill try this later.
    eagleknight
    4 years ago
    The alternate way is to get a paper towel or rag and make it damp. Then iron the areas. Be careful with an iron directly on the wood. You could get burn marks.
    CapnGonzo
    4 years ago
    No, I've done it a few times so far with no problems, but It may be possible, not sure.
