Tool “Third Hand”
1,022
31
4
About: Homemade equipment, tools and devices: http://kudelkin.info/en/index-en.htm
Is commonly in use during soldering, welding – in case if the hand/fixing device is missing, or when there is a need to keep something a long time (glue work).
Supplies:
Step 1: “Third Hand” Parts
Actually it is the well-known device named as a forth hand (even if it is called as a third hand). Thеre is no drawing available, because it is not needed. Everything is shown on the picture. We should take the base construction with certain large weight. Cross-shaped construction should be prepared on beforehand using the pipes D=8 mm, which needs to be inserted in base. There are balls welded, on the edges of construction. Then should be inserted the next pipe of D=6 mm, the next pipe of D=4mm. The last pipe is of diameter, selected due to the reason that it will be applied as a clench. Normally I use the typical clamps from voltage tester. As usually, magnifier lens should be fixed to the middle joint, or another magnifying device. So I use the common magnifier which was in sell for grandmother, to hand-knit the socks. But there is needed to make a frame, using pipe which has been cut in longitude direction.
While manufacturing joints, please keep even distance between holes. Put
two semi-finished parts together in vice-grip, the drill holes, having fixed the parts. After that, make the parts shaped.
The diameters of the holes are not specified here, it depends on ball sizes you have available. Diameters of the balls are of reducing values from joint to joint, similar to situation with diameters of pipes. The main condition is – to avoid the tight contact of pipe to hole edges.
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    4 Discussions
    RobertC2
    1 year ago
    Looks like an antique tool from the 40's... it might have come from my grandfather's jewelry shop! Beautiful work!
    AngryRedhead
    4 years ago on Introduction
    This looks functional AND amazing! I'd happily keep this out on a shelf when not using it. :D
    seamster
    Very cool. Is this a kit, or are these parts all available separately?
