Trammel of Archimedes
17,619
192
23
About: I like to design and build random things.
This mechanism consists of a base with two slots intersecting at right angles. Two sliders are confined within the slots and are attached to a handle by pivots (screws) at fixed positions along the handle. The mechanism can be used for drawing a perfect ellipse. This is done by positioning a writing utensil at the end of the handle while making a full revolution. For more information/history, see here.
With that said, it is often sold in novelty shops with interesting names like Bullsh*t Grinder, Bullsh*t Masher or Do-Nothing Machine. Interestingly, most of the names are preceded with state names such as Arkansas, Kentucky, etc. I guess that’s how locals make fun of their neighbors.
I made two versions of the Trammel. The first version is made from wood. This build is similar to LeumasYrrep’s version as shown here. I decided to take a different approach by making the slides from dowels instead of the layered approach. The second version is a 3D print. I’ve included all STL files in case you would like to print your own. The wood version was made from scrap wood; so my cost was minimal. The 3D printed version cost ~ $15 at my local library. The library charges $0.25/gram so I tried to reduce the weight by removing the four corners. I feel I could have reduced the weight by another 25% with a little more CAD work. If anyone is interested, I’ve also included STP files which can be modified or scaled in most CAD packages.
Trammel in Motion.
This video shows the actual build which should help in conjunction with the build instructions.
Step 1: Tools/Materials
Tools:
  • Table or Miter saw
  • Drill Press
  • Drill bits: 13/16" & 7/32"
  • Vice or wood clamps
  • Wood rasp file or sandpaper
  • Screw Driver
  • Tape Measure/Ruler
  • Pencil
Materials:
Step 2: Wood Version Build
You will be building to this drawing.
Step 3: Base - Step 1
Cut 2x6 to a 5.5” x 5.5” block as shown.
Step 4: Base - Step 2
Mark centers for holes on the sides of the blocks. Use a 13/16" bit to drill the holes through the base. Depending on your drill press travel and the length of your bit, drilling the holes might take a few steps. My low end drill press only has a two inch travel. I used blocks to extend the depth - see video. I also had to drill from both sides. Take your time measuring both sides since this must be a smooth pass.
Step 5: Base - Step 3
The groove was cut using a table saw. Mark the locations for the cross slots as shown on the drawing. Set the blade height to ~ 3/4". Make two passes to remove the slot material. Rotate the part and cut the second slot. To allow for smoother operation, place a slight chamfer on the four inner corners. I did this with a wood rasp file although sandpaper will work.
Step 6: Slide - Step 1
Two slides are required for the trammel. The slides are made from two pieces. The first piece is made from a 3/4" dowel. Use a table saw to make a flat section as shown. Although the drawing shows 1.5" long, I suggest cutting this longer (over 3") to make two pieces at once - see video.
Step 7: Slide - Step 2
Cut a 1/2" thick piece of wood as shown. Again, make the length longer than 3".
Step 8: Slide - Step 3
Center the block on the dowel and attach with wood glue. After drying, cut the parts into 1.5" long sections. You might want to round the sharp edges to allow for smoother motion as the slides cross the center section. Drill a hole in the center of the slide assembly. Note that this hole is for a #8 wood screw.
Step 9: Handle
Cut the handle from 1/2" thick wood. Drill the holes as shown. Again, the clearance holes are for a #8 screw. The large hole was cut using the same 13/16" bit from before. Note that a knob (see 3D print) could be used in lieu of the hole.
Step 10: Assemble
Attach the handle to the slides with #8 pan heads. This should be a loose fit to allow the slides to pivot around the handle. Try it out. If it binds, use sand paper to open up the slots. Adding rounds/chamfers to the slides also helps keep the trammel on track.
Lesson learned: I tried to jazz it up with paint which turned out to be a mistake. It worked perfectly until I added the paint. The extra thickness and sticky surface caused friction which prevented it from moving easily. I recommend keeping it bare wood or a stain without polyurethane.
A video of the trammel in motion is shown in the last step of this instructable.
Step 11: 3D Printed Version
Since my woodworking skills were not needed for this version, I was able to add features and achieve tighter tolerances which allows for smoother operation.
Step 12: 3D Printed Parts
All the parts required for the build are attached. I also included STP files for those wanting to modify the design.
Step 13: Assemble
The assemble sequence is the same as the wood version. This version does have a knob at the end of handle. Use a screw from the bottom side to attach.
Step 14: Video of Trammels in Motion
Final Product
Step 15: Comparison in Size
Step 16: Update (Wood / 3D Print Hybrid)
I wanted to resurrect the painted version but didn't feel like building new wood sliders. Attached is a 3D print that will drop right into the wood base. As you can see from the picture, I added chamfers and rounds in the model which allow for smooth operation in the slots.
Step 17: Update: More Advanced Version
I added another path. See link.
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
  • Trash to Treasure
    Trash to Treasure
23 Discussions
ILykMakin
3 years ago
Exswellent! Building the wooden one.
Countersink the sliders and screw to the lever from underneath?
No visible screws then
mtairymdILykMakin
Reply 3 years ago
Be careful with the countersinks. Recall that the screws must be able to freely rotate - loose fit joints.
ILykMakinmtairymd
Reply 3 years ago
Surely. I don't mean crank them down tight, just counter sink with a drill tip to allow the screw heads to hide recessed.
mtairymdronanry
Reply 3 years ago
I like it. I don't have a router table so I'm not sure how I would get the dovetail. I could definitely 3D print it.
Kiteman
3 years ago
"Trammel of Archimedes"! I knew these things had to have a proper name - I know it as the eternal coffee grinder, and I have no idea why...
I really ought to make one...
mtairymdKiteman
Reply 3 years ago
Funny you mentioned the name. I saw one a few years ago but couldn't remember what it was called. I finally found a picture on google images of one called a Reciprocator. However, I couldn't find any other images by that name. I submitted the picture to a engineering board on Reddit and was flooded with names. It sounds like "Trammel of Archimedes" is the correct name but many other colorful names were suggested - see link.
https://www.reddit.com/r/engineering/comments/44gq...
BARKing
3 years ago
Great! I made a bunch of these years a go. They were popular gifts. We called them BS Grinders because there was usually a lot of BS being passed around when one of these was brought out. A lot of amusement and occasionally practical when you need to draw an oval.
abeimers
3 years ago
I am building one of these at school i will post a pic when it is done
mtairymdabeimers
Reply 3 years ago
Cool. I'm looking forward to the pics.
Fathomlis
3 years ago
That is really cool!
