Trebuchet of the Large Variety (a Work in Progress), 4.28.07 Update
49,722
110
62
This is my second wooden, hanging counterweight trebuchet and the first well-documented one. It will be bolted together from many self-designed and self-constructed components, each about six feet in length. Hopefully, that strategy will allow for some degree of siege mobility and make fixing broken sections of the device far easier. Oh yeah, a trebuchet is a medieval-era siege weapon capable of hurling a variety of things great distances, inducing feelings of pleasure (in me anyways).
I want to hear your trebuchet tips! This project is just starting and will be updated gradually as things progress; I'm sure there's some latent treb-knowledge in the heads of many Instructablers. Let me know what you think of current plans and where you'd like to see the trebuchet go. Favorite arm-ratios, clever trigger systems, winching mechanisms, sling designs...I'd love to try implementing them. I've never attempted a large scale floating arm trebuchet, but if you're convincing enough, I just might. If you'd like to be a collaborator, let me know and I'll try to add you on.
Also, I'm an enormous SketchUp fan. I'll try to present screenshots of any models I use but viewing and helping with this Instructable will be easier if you just download the (free) software here.
This page will also carry the breakdown of the trebuchet's cost (see the Excel file below). As of my last expenditure on April 27, 2007 I've spent $315.
This here Intro page will be the resting spot for the most current model of the entire trebuchet.
A warning to fellow siege engineers: This project can be considerably dangerous, given the gravitational energy of these things and the fact that it is a weapon. Exercise great caution if you decide to build a trebuchet of any size--smaller models (like this) should be attempted first to get a sense of their operation.
Last note! The Sourpuss Trebuchet is a major inspiration to this project; a final product half as good as their device would be incredibly pleasing. The Dr. Seuss Treb should also be cited for it's poetic awesomeness.
Supplies:
Step 1: Base: Design (I)
This step will cover my design for the long end of the base (the entire base will be rectangular in shape, I think; the short ends will be covered in part II). The plans for one of the long ends can be seen in the SketchUp file. As each long end of the rectangular base is identical, this design will just be built twice.
I wanted a slot in the middle of the base to help align the main vertical support when it is put in place (this whole thing is modular, remember). Have no fear, more bracing than 5.5" of pine will be made for this vertical support later. The total length is 18' and I decided to go with 2x6's (which are in fact 1.5" x 5.5", just to make that clear) just cause they seemed pretty sturdy... These long lengths of the base are 3 2x6's wide (aka, essentially invincible).
The screenshots of the SketchUp file below give the whole picture (it's pretty simple). Each section--red, blue, and purple--will overlap by 16" and be bolted through to secure all three pieces into one component. It helps later to remember that every offset made in this part is 16". Note that the red and purple section are identical (whoa!). The blue section looks kinda tricky but just check out the dimensions, don't forget about the 5.5" slot, and remember the overlap/offset 16" rule.
Step 2: Base: Construction (I)
Let's build that base design (I) thing! Hah, I borrowed a little two-door Saturn to get to Home Depot and had to make three trips to get all the wood...sigh. It was fun though; I bought 16 2x6's to do the job (each is 8' in length). You are strongly encouraged to be more resourceful and find some scrap wood or make things less thick, whatever you'd like (that's going to be a recurring, cost-saving element in this Instructable, "be more resourceful than me").
Square the ends of your wood before you mark them (just cut off an inch or so from end, then measure from that freshly cut end). Mark the lengths and slice it up!
A quick cutlist (all parts come from 8' 2x6's):
legend: quantity of 2x6's should be cut to the given length
8 at 6'
4 at 4' 8"; 4 at 2' 9 1/4" (make these two pieces off of the same 8' 2x6 and repeat four times)
4 at 7' 4"
It may be handy to have the previous step, Design of base (1), open as you read this. I used 10d nail fasteners (they're 3" long) and some carpenter's glue to put the pieces together.
Construction of blue/purple sections (remember, blue = purple...I'll stop saying that) is as follows. You'll use a 7' 4" piece, a 6' piece, and a 4' 8" piece. Lay the flat ends of the pieces atop each other with the 6' piece in the middle. Go to one end of this component and align all the ends at the end..an awkward repetition of words but press on! If you align them, the other side of the three boards will become staggered at 16" forming something vaguely step-like. Fasten those suckers together; I put a good layer of glue and then drove two nails every 6" or so. Clean up the glue that comes out of the seams with a warm paper towel. That makes one component; repeat this three more times (you'll have four of the components at the end).
The middle, blue section with the slot will require two 6' pieces and two 2' 9 1/4" pieces each (we'll be making two of the blues). Start by putting a 2' 9 1/4" piece 16" in on one end of a 6' piece. Mark where this piece is going to be located before fastening so you can put the glue down carefully--this thing has a slot and glue should be kept out of that area opposite the 16" offset. Fasten that and then find yourself a scrap 2x6, there should be several somewhere... The 5.5" slot is the width of this scrap; set that in place then butt up the other 2' 9 1/4" piece against it, down the length of the 6' piece. Put down your glue and, with the scrap still in place and the small piece tight against it, nail it all together (er, but no nails in the scrap piece). The remaining 6' piece will go 16" in from the first 2' 9 1/4" in piece you put in during the last sub-step. The entire thing will form a sort of "jagged parallelogram." Hah, you'd likely be better off looking at the design photos than listening to my ridiculous descriptions. Repeat the blue section twice.
You should now be able to create an 18' long section of the trebuchet's base by aligning two of the "step" pieces with the slotted, "parallelogram" piece in between. If it's a bit off and things don't quite line up, it's not a big deal as the bolts used to hold the pieces of the component together can be placed anywhere in that overlap.
I'd love to hear some suggestions for improvement to the techniques in this section--I'm a half step above "novice carpenter" so I have a feeling there are better/more accepted ways to do some of this.
Step 3: Base: Construction (II)
If you recall, the plan was to connect all of these base pieces (like the rest of the trebuchet) with bolts. I somewhat arbitrarily chose 5/16" diameter bolts. They're 5 1/2" which was the minimum length to fasten three 2x6's face to face to face. Washers and nuts corresponding to the 5/16" diameter were also purchased. I initially thought of putting four bolts through every 16" overlap (totaling to 8 bolts per joint). In retrospect that qualifies as excessive--it'd require 32 fasteners all in all. I ended up buying half that and two extra (18 total) for two bolts per connection plus spares. On to drilling!
It'd be nice if any of the red/purple base pieces could go with either of the blue pieces. Part labeling would not be required and assembly would likely be simpler. To attempt this Herculean task I made a little drilling jig out of a spare 2x6. I would use four holes in this piece to align the bit when drilling the red, purple, and blue pieces. This ended up failing for two reasons. (1) I didn't measure the holes in the jig. They would need to be exactly symmetrical about both axes for any red/purple piece to fit with any blue middle section. (2) None of the red/purple (should I just start calling them rurple?) pieces were "exactly" the same meaning the jig aligned on them differently. Things won't fit if they're off by more than 1/8" or so, so another method was chosen. Press on!
Giving up on interchangeable components, I started drilling one part with the jig (let's call this part A). The piece intended to fit with A was then drilled using part A as a template for the second. All pieces were labeled.
Final note (apologies for the wordiness of this step): Though my bolts were 5/16" in diameter, I drilled holes for them with a 3/8" bit (1/16" larger). This made actually putting the bolts in far easier.
Step 4: Main Support: Design and Construction
What I call the "main support" is the vertical piece that goes in the center of the base; it will hold the treb's axle. Each of the two supports is designed to break down into three components. When the pieces are bolted together, the main support is about 15' 6" tall. Cool.
I needed 18 8' 2x6's for these; you can get fewer boards if you buy 10' lumber but the costs were actually about the same and using 8' pieces gives a lot more scrap (useful later). Here's the cutlist for both of the main supports:
(cut this many 8' 2x6's) at (into these measured parts for each 8' 2x6)
2 at 4', 2' 5 1/2" (thus cut one 8' piece into 4' and 2' 5 1/2" pieces and then repeat with the other 8' piece)
2 at 4', 2'
2 at 4'
2 at 5' 4"
4 at 6' 8"
4 at 4' 4"
2 at 6' 1 1/2"
The SketchUp file will be most helpful in construction--the same techniques that were employed in the base construction were used here (16" overlaps, nails, glue, music). Once your pieces are made, align them and drill holes for the bolts to come.
I actually held off assembling the very top pieces (blue) of the main support. The axle will pass through this part and I wasn't sure of how to drill the axle hole such that the axle is level. This'll be posted in the questions section and mulled over. A response and my course of action will eventually go here.
As stated earlier, save your scrap! There's going to be a lot of extra wood and future pieces of the trebuchet will make good use of them.
Step 5: Initial Assembly
With the base and main supports both about two-thirds of the way done and no lumber to work with last weekend, I decided to put this thing together. There's not much instruction here, it was just nice to see how the project was progressing. The diagonal supports that can be seen are temporary. Things bolted together nicely and it was, on the whole, very intimidating...
Step 6: Base: Design (II) and Construction (III)
The two 18' long base pieces need some method of attachment to one another (besides the treb's axle). Enter the base ends! Each base end will consist of two nearly identical components that are bolted together. The long ends of the base will slip into the channels and some sort of rod (or a realllly lengthy bolt) will attach both components. The vertical pieces you see are for diagonal braces of the main support piece; one end of the diagonal attaches here (at the base section's end) and another attaches up at the top of the of the main support.
The SketchUp file posted contains the measurements of these pieces.
Assembly time! Let's start with a cutlist (suggestions for ways to improve my cutlist presentations would be great...I'd love to use a table or something but don't I don't think Instructables has that format yet and I don't want to make people download another file):
(cut this many 8' 2x6's) at (into this quantity of these pieces)
4 at 4' 1/2", 2' 8 1/2", 8"
2 at 2x (2' 6"), 2x (1' 1 1/2") this means take an 8' long 2x6 and make two 2' 6" pieces and two 1' 1 1/2" pieces. Then repeat with another 8' long 2x6
2 at 2x (2' 3"), 2x (1' 4 1/2")
2 at 4x (1' 4 1/2"), 2x (10 1/2")
I ended up using only 8 2x6's (the cutlist above calls for 10 total) because of the large amount of scrap left over from making the main support.
The assembly of these pieces ended up being the most complicated part of the build to date. I was fortunate to escape with only one mistake (gluing/nailing two pieces that should not have been attached). For those following the plans, be extra careful in this step to check that you're attaching the right parts--many things look very similar but some components are mirror images of one another or one piece is slightly longer, etc.
It's also tricky because the nailing has to be done in a specific order due to the length of nails. Allow me to explain...first checkout the SketchUp file. The design can be aptly described as "screwy" so look at it carefully. The specific construction notes are listed in the notes on the images below--read carefully. Questions about any part of this in the comment section or a private message are completely understandable.
Step 7: Current Questions
A list of things that need to be resolved (I'd love to hear your thoughts!):
(1) The main support pieces need to have an axle hole drilled clean through them. I'm not sure how to do this precisely enough such that the axle is level when in it's in place. The difficult comes from the fact that pieces are bolted together and have a little bit of give. The wobbling of the pieces is very slight and may be insignificant...I'm really not sure.
(2) A good counterweight material is needed. High density is a must but something that comes in manageable pieces is also important. I've done concrete blocks before and it worked alright--would adding metal to the concrete mix be beneficial?
(3) Wheels, how do I get strong removable ones? I'd rather not purchase them because I bet they'd be expensive. A trip to the scrapyard is probably in order. Other ideas?
(4) Arm ratios!? (This is the ratio of the throwing arms long end to it's short end; the ends are split by the axle's position). What's the advantage of a large ratio (5.5:1) vs a small one (2.5:1)?
Step 8: Further Order of Operations
Here's the plan for the next week or so (I'd like to hear thoughts):
(0) get wood for the base ends and make 'em
(1/2) put the small additions onto the main support as per the plans
(1) drill axle holes in main support; fix the possible alignment problem by assembling both of the main supports, putting the axle through them, leveling/squaring everything, and then drilling the bolt holes for the top piece's connection to the rest of the main support
(2) continue refining model
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    62 Discussions
    I am building a trebuchet at the moment and need sopme more infor on the frame of the base i did a quick test fire and it ranged from 20-50 metresdepending on the lenth of the sling and the countwer weight
    Qwerty.07
    11 years ago on Introduction
    In about yr8 so i was about 13-14 i build a trebuchet that with the arm totally vertical it would have been about 1.5m high(3-4ft) and yer i figured out throught my own calculations that 1:9 is the golden ratio for the whole thing 1:10 also works good. 1:9 is applied to the arm length and the wieght ration so plan how much what you intend to through ways then base your design on that. there is also another issue as you whiether you want to use the some sling ever time or have idividual slings. if you don't know what i mean you can either have a fixed sling which means that one part is attched to the arm and the other is only hooked so when the arm reached the de-ttach point it un hooks releasing the ammuntion i find this is a bit to mess around with so i went the other option. on mine i had a hook that the end of the arm it looked like this: / / | | | i hope you get the picture and yer i attached a chain to a tennis ball that the chain hooked on to the hook (no duh) and yer i also realised the the weight ratio was out so i added bits of lead i cut from a sheet to sum up the differents and you realise that the heavier ball went about 3-4 times feirther so yer i hope i helped you feel free to ask me about my project and i would like to see how your trebuchet turns out.
    I think I'll have to take a poll on the ideal arm ratio (I think the physics may be beyond me). Your suggestion is the lowest I've heard yet--it's gone as high as 5.5:1...
    daliad100Vertigo666
    the ideal ratio is 4:1I was watching scrap heap challenge (throwing scooters) and the guy who was one of the experts said that the ideal ratio is 4:1 and the judge said 100-150 times the mass of the object which you are throwing on the counterweight end (the shorter one)
    Well, the second bit about the mass isn't on the site but I remember it from the show
    abehambino
    Have yet to build a trebuchet but have done quite a bit of research on them. what I do know about distance of the counterweight and such is that the ratio of counterweight to ammo should be the same as the ratio of of the length of the counterweight arm and the length of the longer arm(the name slips my mind). Hope this is helpful. I have plenty of more ideas I am working on and would be glad to give advice. Just let me know what you need.
    I built one of those with a simpler design than yours. I used cinder blocks for the counterweight (about 200 LBS of them) and it can throw about 250 feet with a 1 LB projectile and im not done testing it yet. it cost me about $50 in lumber and screws. mine is a free swinging counterweight with fixed base trebuchet. It has a frame of an equilateral triangular prism with side lengths of 8' and a depth of 4'. The throwing arm is 15' and the main weight arm is 3'. The metal bar I used was a circular fence post. If you want more information on building and tips on design, contact me at tjlavelle@gmail.com. By the way, I would reinforce the throwing arm if I were you, my first one was a similar design and it broke pretty quickly. I can give you a better design if you like that uses 6 8-foot 2X4s. Remember to keep the release angle so that it releases at 45 degrees from the ground for maximum range. By the way, you spent a ridiculously large amount of money. Low grade 2X4 is strong enough if you use equilateral triangles. If I had bought all the materials for my treb, I would have spent at most $80. Please contact me, I will be happy to help you as much as I can!
    for projectile weight to counterweight weight use a ratio of 136 to 1 or, if you have a heavy throwing arm, at least 200 to 1
    by the way, sorry for all the replies to myself, i just keep thinking of new tips and i have so many more to share so contact me
    a ratio for throwing arm is 5:1 for max range
    you can smash up the cinder blocks like i did for higher density or just use rocks
    for axel hole on the arm cut a square into the arm 1/2 inch larger than the diameter of the arm and attach more boards to seal up the hole
    the axel holes on the supports can be made by buying some huge screws about 3/4 inch thick and attaching them parallel to the ground just under the top of the support structure and then just resting the axel on top of these screws. This is what I did for my treb
    as long as you have a free swinging counterweight treb, you should not use wheels, they will actually be detrimental to the range as long as you use the free swinging counterweight design.
    johnshepperd
    8 years ago on Introduction
    for my counter weight i am using 3 garage door springs that are attached to the bottome and when arm is down they are almost to critical expansion
    arveyda
    My middle school students chose this as the design for their final project (they are an ambitious bunch! :-) ). I will post some shots if it is successful. Thanks for inspiring my th, th, and 8th graders!
    will-i-am
    9 years ago on Step 5
    Definitely like your use of wood joints; old school strength.
    spaten0
    9 years ago on Step 7
    Um what is a good counter wieght if ur in the woods find a downed tree and cut it up the logs will be heavy lol
    ace117
    10 years ago on Step 7
    the longer the arm with the counterweight is the slower the trebuchet will swing, for adjustable range I would make several attachment holes and then test it to see what the range is, the further from the fulcrum you go, the less range you get in the end. if you don't understand this tell me and I will explain in further detail.
