Tug Belt - a Minimalist Belt That Fits in Your Wallet
36,691
223
27
About: Industrial Designer by day, Maker by night.
Forgot your belt?
Have a pair of pants that are slightly too big?
If so, you may be interested in building this Tug Belt.
Here are the highlights:
- It tightens your pants by twisting a belt-loop.
- It fits in your wallet.
- It's easy to make
You can build your own Tug Belt out of an old credit card by following this tutorial.
Thanks, and enjoy!
-Josh!
Step 1: Gather Your Supplies
Here's what you will need:
An old credit card
- Make sure it does not include any important or private information.
- Make sure it is of a standard credit card size and (Ideally) doesn't have any raised lettering.
Safety Glasses
- If you like your eyeballs.
The Paper Print-Out
- Print the attached PDF
- Ensure your print-settings do not scale or crop it, or it will not be the correct size.
Scissors
- For cutting the paper print-out and credit card.
- Optional: Heavy-Duty Scissors for easier cutting of the credit card.
Double-Sided Tape
- For temporarily attaching the print-out to the credit card
Center-Punch
- For more accurate drilling
Drill / Drill Bits
- For drilling into the credit card.
- 3/16" and 1/8" DIA drill bits.
Random Block of Wood
- To ensure you don't drill into your table or hand.
Sand Paper
- To smooth out your cuts
Step 2: Cut and Mount the Print Out
Cut along the outer, dotted lines of the paper print-out (file is located in the previous step). This should give you a shape that is identical in size to your credit card.
Use double-sided tape to secure the paper to the credit card.
NOTE: Which side of the credit card (and which orientation) you tape to matters.
- If you plan to wear your Tug Belt on your RIGHT-SIDE then tape the paper to the back-side of your credit card if you want the front side visible when worn. (not shown in pics)
- If you want to wear your Tug Belt on the LEFT-SIDE then tape the paper to the front-side of your credit card if you want that side visible when worn. (as shown in the pics)
Step 3: Drill It
Use that random block of wood as a backing-plate to prevent drilling into your table.
Then use the center-punch and drill accordingly with the 1/8" and 3/16" DIA drill bits.
Step 4: Cut It
Use your scissors (or ideally heavy-duty scissors) to cut along the solid black line.
You can optionally use an Xacto-blade to cut the tight spots.
Be sure not to bend the credit card too much. Credit card material (PVCA) isn't particularly strong. When I made them, I used to laser-cut them from a much stronger material (Delrin) and sanded it to get a soft-touch surface.
Step 5: Sand It
Remove the paper and double-sided tape from the credit card.
Sand the edges smooth so that they don't cut your skin or clothing.
Congrats! You just made your own Tug Belt.
(Fancy laser-cut Tug Belt also shown in picture)
Now you just need to learn how to wear it (the next step)...
Step 6: Wear It
Follow the pictured instructions to wear it.
And when you are not wearing it, store it in your wallet.
Thanks.
-Josh!
  • Jewelry Challenge
    Jewelry Challenge
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
27 Discussions
jluetger
2 years ago
Did not work with my jeans not strong enough to pull and twist loop.
joshpit2003jluetger
Reply 2 years ago
Perhaps I should have mentioned it in the instructions, but you need to lift your pants up, then twist the Tug Belt on.
Djjazzyjasper
2 years ago
I made one and it didn't work with my jeans. I followed the instructions cor
joshpit2003Djjazzyjasper
Reply 2 years ago
Hey Jasper. Thanks for making one dude.
I've tried it on a variety of adult pants and it worked with all of them, so if you can explain why it didn't work with your jeans I might be able to help you.
Also: It's not the most intuitive installation, so be sure to follow the diagram directions to insure you are using it properly.
Thanks, and looking forward to your response.
Djjazzyjasperjoshpit2003
Reply 2 years ago
When I try to put it on, it folds in half. Maybe it's the wrong material?
Reply 2 years ago
hum, it's supposed to curve with your waist, but not fold in half.
Credit card material (PVCA) breaks easily if it is bent too-much so I wouldn't expect yours to last very long if it is folding. I'd suggest trying to find a thicker or stiffer credit-card, perhaps glue two together if your credit cards aren't strong enough. Best of luck.
jobics
2 years ago
Amazingly ingenious!
clark5113
2 years ago
Brilliant. If things keep going the way they are in this country, we are all gonna need one:)
dewhickey
2 years ago
Good idea. Or I could tie a piece of cording to two belt loops.
joshpit2003dewhickey
Reply 2 years ago
You could also zip-tie two belt loops together.
A one-time use solution with a zip-tie though, but might be faster than tying a knot.
dewhickeyjoshpit2003
Reply 2 years ago
Zip ties are fast but pokey. I'l try it and see if I can get it angled comfortably. Zip tie would focus the tension narrowly and could wear down the fabric.
joshpit2003
2 years ago
Just hit 100 "Favorites". So awesome.
Thanks guys.
rch
2 years ago
Brilliant!!!
Phoenix830
2 years ago
great product, and instructable. If I bought one I know I'd forget to put back in my wallet after first use
joshpit2003Phoenix830
Reply 2 years ago
Thanks.
I'm starting to get better at writing instructions, but they are still taking me more time than I would like (this one was 6 hours to document).
They stay on your pants quite well, even if you take your pants off. That being said, I haven't run a Tug Belt through the wash yet, but I imagine the Delrin would hold up. Not sure about the credit card material, perhaps you could build one and test that for me.
Moveforward52joshpit2003
Reply 2 years ago
This is very well written. I appreciate the time you put into word crafting. It shows! It makes a huge difference. Thanks! This is a great idea. I hope you sell a lot.
Yonatan24joshpit2003
Reply 2 years ago
It takes so many hours to make an Instructable, and then you look back 1 day later and say to yourself "Wow. "I could have done all of this in 15 minutes."
Been there close to 100 times ;)
nliwilson
2 years ago
Neat! Such a simple little thing anyone can make, that's excellent. :)
