Tune Your Piano Using Free Software
10,601
31
12
This guide will show you how to tune your piano using just a couple of tools and a free program called Entropy. Even if you've never thought about tuning your piano yourself before, you can achieve a satisfying result with a little effort and patience.
Why should you learn to tune your piano? If you’re like me, you enjoy the satisfaction of fixing and maintaining your own equipment, such as cars and computers, so now you can add your piano to that list! It's true that a professional tuner will certainly do a better job than you. However, if you haven't had your piano tuned in a while, you can likely get it sounding noticeably better than it currently does, even in your piano-tuning infancy. If you don't feel up to tuning your entire piano, you can learn the basic skills to be able to fix specific notes on your piano that are glaringly out of tune. I personally have enjoyed tuning my own piano, and I look forward to improving my skills as time goes on.
The most important skills you will need are being able to properly use a tuning hammer, and being able to hear beating and identify when two strings are in tune. Both of these will come with practice.
Step 1: Obtain the Equipment
To tune your piano, you will need the following equipment:
  • tuning hammer
  • mute(s)
  • computer with an internal or external microphone, or a smartphone
Make sure the tuning hammer fits the pins well, so that you won't be stripping them as you turn them.
I recommend using a laptop with a decent quality external microphone. Internal microphones on laptops or phones may be sufficient to get the job done, but these microphones may have difficulty recording the low frequencies produced by the bass notes, which could affect the accuracy of the tuning.
Step 2: Remove Cover to Access Tuning Pins
On most grand pianos, the tuning pins can easily be accessed by sliding off the music stand above the keyboard.
On upright pianos, there is typically a hinge allowing the top of the piano to open up. The tuning pins are just below that cover.
Step 3: Practice Tuning Single Notes
Caution: When turning the tuning pins, be careful not to tighten them too much. This can cause strings to break.
To prepare yourself to tune the entire keyboard, it is helpful to spend some time tuning unisons (single notes). Since most keys on the piano have either 2 or 3 strings, the strings for each key need to be tuned to precisely the same pitch. Even with an electronic tuning aid, you will use your ear to tell when the strings of one key are in tune with each other. For now, don't worry about whether the key is tuned to the correct pitch relative to the rest of the keyboard.
  1. Choose a note with 3 strings to tune. (To start, the ones in the middle of the keyboard are easier.)
  2. Decide which string to use as a reference to tune the other strings to.
  3. Mute one of the strings (see picture). This is done so that you only hear the string you're tuning and the string you're using as a reference.
  4. Place the tuning hammer on the tuning pin for the string you are tuning. The handle should be pointing roughly parallel to the strings toward the inside of the piano.
  5. Pull the hammer to bring the string slightly sharp of where it should be.
  6. Move the hammer back the other way until the string is in tune. As you do this, listen to the sound of the two strings carefully. When they are far out of tune, you will hear a fast beating in the sound, which will slow down as they approach the same pitch. If they are perfectly in tune, there will be no beating at all.
  7. Once the two strings are in tune, mute the string you just tuned, and unmute the remaining string. Repeat the process for this string.
Notes:
  • The method of bringing the string into tune from the sharp direction helps the pin to stay where you put it. If a string is flat and you simply bring it up to pitch by increasing the tension, it will tend to loosen on its own after a short time (like a spring unwinding, but slower).
  • Having the tuning hammer parallel to the string reduces the amount that your twisting motion can tilt the pin forward or backward, which would change the tension on the string until you release pressure on the hammer, causing error in the tuning.
  • It is better to use quick, short movements of the hammer, rather than long, steady ones. This improves the tuning stability. When you are starting out, you may need to move the hammer more slowly to practice listening to beating and train your ear to identify when strings are in tune.
Step 4: Install Entropy
Entropy is free and open source, and relatively easy to install if you have a common platform. It can be downloaded here.
The reason for using software to help tune a piano is that the non-ideal nature of the strings needs to be accounted for. If you were to tune a piano to ideal pitches (equal temperament), it would actually sound terrible, because the strings produce overtones that are not at integer multiples of the fundamental frequency. Standalone electronic piano tuners and piano tuning software have ways of calculating how the pitch of each note should deviate from the equal temperament to make the harmonics line up better with each other. There are several programs that can do this; Entropy is not the only choice. Entropy's approach is unique because it quantifies the entropy of the piano based on how well the combined harmonics of all the notes line up, and then determines a tuning that minimizes that entropy. For this calculation, the frequency spectrum of each note on the piano needs to be recorded.
Step 5: Record Each Note Into Entropy
Click on the "Record" button on the left of the Entropy window. You will now need to record each note into Entropy. There are a few things to keep in mind for this step:
  • If possible, do this at a time when the room is quiet. Extra noise in the room will reduce the quality of the recorded data.
  • Mute all but one string for each note (see pictures). Remember which strings (right, left, or middle) you recorded, because when you are on the tuning step, you will tune the same string for each note to the pitch calculated by Entropy. The other strings will be tuned to that string.
  • Keep each key pressed down until Entropy stops recording. (The red circle will change to a pause symbol.)
When you are finished with this step, you will see a graph of how each note compares to the equal temperament pitch.
Step 6: Run the Calculation
Click the "Calculate" button on the left. Then click "Start calculation." Entropy will calculate a tuning based on the data you recorded. You will notice that the bass notes are tuned flatter than ideal, and the highest notes are tuned sharper than ideal.
Step 7: Tune Each Note
Click the "Tune" button on the left. For each key:
  1. Mute all but one string (the same string you recorded earlier).
  2. Tune one string to the pitch calculated by Entropy. As you play the note, Entropy will show a line on the graph indicating the pitch, and a psychedelic rainbow indicator. You may be surprised to find that the moving rainbow gradients are the more useful of the two indicators. Watch for when the colors nearly stop moving to know when the string is in tune. One direction of movement indicates sharp, and the other indicates flat.
  3. Unmute one of the other strings on the same note (if applicable) and tune it to the first string, the same way you did in step 3. Do the same for the 3rd string, if there is one.
  4. Repeat for each note on the piano.
Step 8: Check Intervals
When you are done tuning, you can play various intervals on different parts of the piano, such as octaves, fifths, fourths, and thirds. They will not be completely free of beating (especially the thirds), but the beating should be relatively constant as you move up and down the piano in small steps.
If you notice any notes that sound off during this process, you can adjust them by ear, tuning one string first, and then the other two strings to the first. Some notes could have returned to being out of tune due to your hammer technique, or there could be imperfections in the tuning produced by Entropy.
At this point you should be able to tell whether your tuning made an improvement or not. Hopefully it did!
Step 9: Check the Tuning After a Couple of Days
As mentioned earlier, piano strings tend to go back to how they were if proper hammer technique is not used. This is something that will take practice. It is a good idea to check your tuning after a day or two to see if any of the strings have gone flat again, to get feedback on how well you are using the tuning hammer, and to correct any needed notes.
Step 10: Play Your Tuned Piano
Now that your piano is tuned, take full advantage of it by playing it often and basking in the abundant harmonicity!
    • Arduino Contest 2019
    • Fat Challenge
      Fat Challenge
    • Gardening Contest
      Gardening Contest
    12 Discussions
    ShanePhoner
    15 days ago
    it is possible to tune your own piano using instructions like these but always be aware that if you have an old piano or one that you got for free like a hand-me-down, a lot of the times the wires are going to be old and have been resting out of tune for awhile. pianos hold an enormous amount of tension and when the piano has been resting at a certain tension for a long time, it is impossible for it to be tuned in just one session. the wires need to be stretched over and over again to over multiple tuning sessions. otherwise, as soon as you are done the piano will fall out of tune almost immediately. if you want to tune your piano to A-440 (which is the standard) you really want someone who knows what they are doing. often times piano tuners can come and give you an appraisal on just how damaged or far gone your piano has gotten and how much it would cost to fix for a very cheap price (20-30 bucks). thankfully most tuning technicians are just friendly musicians and aren't looking to try and up-sale you.
    Elinae8
    8 months ago
    This is quite a complecated guide to tune a piano at the same time not everyone has the capability to do this I suggest just to have a piano tuner to tune your piano.
    Peace,play, enjoy your music
    photomike65
    10 months ago
    Thanks for this, I got my piano for free like many others. I certainly didn't want to spend money on someone to tune an old, free piano and my one needed doing badly. I did mine using this guide 2 months ago and it still sounds good. maybe when I spend serious money on a good piano I'll get someone professional to do it but for now this will do me, well done.
    rossthebuilder
    2 years ago
    I am a piano tuner, and I have to at least mention that beginners should only try on old pianos they don't care about destroying. without proper knowledge of how to set the notes, the piano will fall out of tune very quickly. it takes many many tunings before you will be good enough to tune a piano.
    ErichN5rossthebuilder
    Reply 1 year ago
    I think destroying is a bit of a strong word. I would think the worst that could happen is breaking a string or stripping a pin. Being out of tune is a temporary and fixable condition. But I would agree that beginners may not want to start on a really nice piano.
    If you have any suggestions on how to properly set the notes beyond my basic explanation, I would welcome improving the article.
    diytaikoErichN5
    Reply 11 months ago
    I am a piano technician, but I only tune aurally. Since you seem to have success in tuning your own piano, you might wonder why some of us keep advising against DIY tuning. Our career is to take good care of these instruments, experience matters and the range of knowledge is more than a DIY guide. You welcome suggestions on setting pins, I don't even know where to start because there are many aspects to consider.
    Hammer technique and stability (setting pins) require a lot of practice (ideally with feedback from mentors). Technicians spend years tuning hundreds and thousands of piano to obtain these skills, so it is really hard to imagine tuning a piano with just a short guide. It is certain that, beginner tuning would not hold tuning for long. Depending on how one uses the tuning lever, one might strip the pins rapidly, or damage the pinblock. Then the piano would really not hold a tuning, even with proper technique. I suppose this is a way to "destroy" a piano. Some people use tools other than tuning levers to turn the tuning pins, this risks damaging the tuning pin surfaces and might prevent the piano from proper tuning.
    I understand that most people want to save the tuning cost, but the price to repair unnecessary damages is often way higher than a few quality tuning service.
    manalhassan
    11 months ago
    I think this is the future for pc software which will be replaced with hardware piano.
    Thanks
    Blivitdave
    Question 1 year ago on Step 5
    I'm having trouble getting samples of good quality. Im using a condenser microphone through an audio interface into my pc. I have tried 10 times and nothing seems to work. Any advice?
    1 answer
    ErichN5Blivitdave
    Answer 1 year ago
    In my experience with Entropy, it is okay if not all the notes have a green quality indicator. Some will be better than others; in particular the upper range tends to be much worse.
    If you're having trouble getting it to recognize the pitches correctly, there is a way to manually tell the program which key you are recording. Another potential problem could be background noise. If people are talking or making noise nearby, the program will struggle to identify the keys played and you may lose some accuracy.
    I may be able to give you more specific help if you can tell me more detail about what behavior you're seeing in the program.
    I am not affiliated with the developers of Entropy, so you may also want to check out their help and documentation here: http://piano-tuner.org/help-and-documentation.
    pianoman68
    1 year ago
    I'm also a piano tuner. I wanted to comment that I've tried several different types of tuning software including Entropy, Cybertuner, Verituner, TuneLab, and Easy Piano Tuner. They all have their pros and cons, but Entropy was by far the most difficult to use and produced the least desirable tunings. For people wanting to experiment with tuning their own pianos I would recommend using Easy Piano Tuner as the best combination of inexpensiveness ($20US) and ease of use.
    RyanG223
    2 years ago
    hehe. I'm a piano tuner as well. Though I prefer using Reyburn Cyber Tuner over Entropy. It costs over $1000.00 but it's a true gold standard piano tuning software app. It beats listening for beats!
    Nice. Sure beats paying someone to come out and tune the piano.
