Turn an Exercise Bike Into an Energy Bike
235,781
340
125
Why pedal a stationary exercise bike for exercise? Put all that sweat equity to good use while getting into shape. Turn you exercise bike into a power generator to run lights, a TV, stereo, blender, etc. Recharge a 12V battery or drive appliances directly. This is an excellent educational tool for science and technology classes. There are several options for how you design and build it. I'll show you how to build this one and point out other options along the way.
Here's a list of parts you'll need to get started:
- exercise bike, with cast iron flywheel or rubber tire type
- DC motor or generator with magnets, 12Vdc or 120Vdc recommended
- 1/2" plywood, 3/4" will also work
- 6' - 2"x 4" pine lumber
- 4' link belt (or fan belt)
- 1/4" Lag bolts
- assorted screws
- 3/4" water pipe and end caps
- screw band
- wire DC volt meter
- DC amp meter
- 14 ga. wire
- 2' of 1-1/2" PVC pipe
- 1-1/2" sheave (pulley)
Tools you'll need:
- jig saw
- hand saw or chop saw
- router (optional)
- drill and bits
- hacksaw
- file
- wire cutters and strippers
- screw driver
- socket set and ratchet
- carbide cutter
- vise grips
Supplies:
Step 1: Prepping the Exercise Bike
I prefer to use Tunturi or Vitamaster exercise bikes for conversion. They are well built with a heavy flywheel and good bearings. The frame is solid, but the handlebars may wobble a bit on some models
Start prepping you exercise bike for conversion by removing unnecessary equipment. Most exercise bikes have either brake pads or a web strap that rides on the perimeter of the flywheel. This one has a watt meter hooked to the drag brakes.
On this model, you'll also need to remove the rubber banding from the perimeter of the flywheel.
Step 2: Turn a Groove on the Flywheel
The flywheel needs a groove to receive a drive belt. Some models have a wide shallow groove, others have a narrow, deep groove. The easy way to do this is clamp a carbide-tipped square shank cutting tool in a pair of vise grips and hold it securely against a base with the tip against the fly wheel.
Have someone pedal the exercise bike while you gradually turn the metal groove to the desired width and depth. This can take a little while, especially if your human motor is out of shape. Take your time and take light cuts.
An approximate width and depth as shown in the second picture will work adequately. Test fit your belt periodically to ensure you are getting an appropriate fit.
I like to use a link belt available from numerous sources, one of them being Woodcraft.comWoodcraft.com. It's easy to add or remove links to get just the length you want.
Step 3: Creating a Base for the Generator
There are many ways to mount the generator. I created a base and an adjustable cradle for the generator.
Cut a piece of 1/2" birch plywood large enough to hold the generator cradle reach the frame of the exercise bike on each side of the flywheel. Drill a hole for a 5/16" T-nut which will be used to fasten the cradle. Cut and screw 2x4's to the base on the underside the plywood.
Attach 2x4 boards to the bottom of the base using glue and screws. Lag bolt the cross piece 2x4 to the ends of the other 2x4's at the front of the base.
The two long boards need to have the ends cut to match the angle of the exercise bike frame. I chose to use a U-bolt to attach the base to the frame by drilling a series of small holes to create a slot for the U-bolt tang. An easier way would be to drill a 1/4" hole through the frame and into end of the 2x4's. You could use a lag bolt or a machine bolt into a cross dowel nut.
I chose to attach wheels to facilitate rolling the energy bike around. Because I used 1-1/8" x4 boards rather than 2x4's, I needed to add wood to support the wheels as shown in the picture.
Two of the boards need slots cut in them for the pipe section. You can drill and jigsaw slots or use a router for this task.
Step 4: Making the Generator Cradle
Cut two pieces of 1/2" plywood to fit the diameter of your generator. Cut slots in the cradle base by drilling a series of small holes close together. An 1/8" router bit could also be used to cut a slot.
Glue and screw the two sides to the cradle base.
Step 5: Assemble the Parts
Attach the base to the exercise bike frame. If you attached wheels, make sure the base is level when attached to the frame.
Attach the generator cradle to the base. Insert a hard sheet of plastic such as Plexiglass or clear acetate between the base and the cradle. This will help the cradle slide easier for adjustment. Lay the generator in the cradle and insert the 1"x8" pipe section through the base. Insert the 18" pipe strap through the slots, around the pipe and around the generator. Tighten the strap to hold the generator to the cradle. Insert a 5/16" by 1" T-bolt through the slot into the T-nut.
You may find you need to cut a piece of angle iron or strap and attach it between the base and the axle for the flywheel to make the assembly more rigid. (See the second picture).
Place the link belt around the flywheel and around the 1-1/2" pulley on the generator. Add or remove links as necessary to get the length correct. Slide the cradle assembly back until the belt is tight. If you reach the end of the adjustment slot, take another link out of the belt.
Attach the 12V power jack (a regular out let is recommended if using a 120V generator). Radio ShackRadio Shack catalog # 270-1556 is shown in the picture.
Step 6: Build a Meter and Light Display
This display has 3 switched light sockets, a switched outlet, and two meters. It is 24" tall, 8" wide, and 5" deep. Use 1/4" birch plywood to build the box with 3/4" x 3/4" pine for the internal frame. Drill holes for the sockets, switches, and meters.
I used 3/4" x 5" pine for the top and bottom with holes drilled for a 1-1/2" PVC pipe. After installing and wiring the meters, switches and sockets, install the pipe. After the pipe is in place, the top piece of 1/4" plywood is installed. Drill a 1-3/8" hole in the bottom plywood and attach. This will hold the PVC pipe captive.
Step 7: Start Pedaling Power!
With the meter display plugged in, starting to pedal should start to deflect the volt meter. If the meter moves the wrong way (negative), reverse the leads connecting the generator to the 12V socket. Screw in an incandescent and a compact fluorescent.
If you're using a 12V generator, you'll need to use 12V rated bulbs. These are available at most RV centers. If you use a 120V generator, you'll need to use resistive loads or appliances with magnets in the motors. Many compact fluorescents will work on 120Vdc, but not all.
If you find that you have to pedal to slow or too fast to get the desired voltage, change the size of the pulley on the generator. A larger pulley will turn the generator more slowly and generate a lower voltage for a given pedal speed.
I added a smaller handlebar for smaller kids. An 8-year-old on frost sugar pops can crank out an amazing amount of energy, over 200 Watts!
Have fun pedaling different DC appliances. Read a book with pedal-powered lights. Hook a 12V TV to the Energy Bike. Make your kids pedal if they want to watch TV. They can rest during the commercials. If you have a laser engraver, make a side plate with a picture of an Energy Bike cranking out lighting bolts!
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    125 Discussions
    AlexanderC153
    3 months ago
    Ok who wants to partner with me and open a gym that generates power?! Or has that already been done?
    SkyeE5
    4 months ago
    Hello, I think it would be great to start some kind of co operative that helps set people up who are down and out with the ability to improve their situation through generating electricity via exercise.
    What do you think?
    Skye in Australia
    wingsingerSkyeE5
    Reply 4 months ago
    At 100-150 Watts/hr, it would take 6-10 hours to generate 1 kWh. The average home uses 20-30 kWh/day.
    It would be beneficial in 3rd world countries where a cyclist could recharge a cell phone or battery for LED lights.
    SkyeE5wingsinger
    Reply 4 months ago
    Hi Wingsinger, if you were looking at powering some basic items rather than the average household use it could be considerably less. Such as charging a phone or computer, boiling a jug or recharging an appliance such as a fan. It could be useful for people wanting to go off-grid or for those who are unable to access power for some reason. My neighbour’s power was cut because she couldn’t afford to replace a pole. She is now living without power ongoing.
    christian2gothic
    7 years ago on Step 7
    I absolutely love your project. it's close to something i'm hoping to achieve. Do you know enough about electricity wiring in a home to know how to wire a source of power to your home to run your electricity meter backwards safely?
    wingsingerchristian2gothic
    Reply 4 months ago
    Thanks! The power put out by a human isn’t very much compared to the amount we use daily. It takes 10 hours of cycling to generate 1 kWh; a home typically uses 20-30 kWh/day.
    I don't know where anybody got the idea that this would be wired into the house wiring. Also unless you have your kid peddling while you are trying to do the wiring you will not be working with live wires. However I highly recommend for safety that some kind of a box enclosure that can be secured so that small children or pets cannot cone in contact with turning belts and pulleys or electric components. If you use a 12v generator like the author I would suggest installing a cigarette lighter style outlet so as to accommodate the many 12v appliances that come with cigarette plug. I would use a car voltage regulator and a couple deep cycle batteries so that one wouldn't have to peddle the exact speed to maintain 12 volts. If you installed a 12v to 120v ac power inverter you will have some emergency power during a power outage that could power a couple lamps and your TV or computer. A 400w to 800w inverter can be had fore about $25- $50
    Deleciachristian2gothic
    Reply 7 years ago on Step 7
    You really need to consult an electrician in your area to do this. If not done properly you can backfeed to the power company and do some serious damage. I've been in the electrical business for many years so I know this can be dangerous.
    lucekchristian2gothic
    For something like this it's not worth the effort. That said it's tricky wiring doing what you want. Dangerous too as unless you call you're electric company you'll be working with live wires.
    wingsingerlucek
    Reply 4 months ago
    I’ve done that, but it’s more of a workout than I wanted!
    PhotoMaster
    I made something similar to that, to help a friend lose weight. Mine didn't generate the power, but used a headligh generator to switch a solonoid I hooked into his TV. Yours is quite clearly better and much more versatile! Great work!!
    wingsingerPhotoMaster
    Reply 4 months ago
    Thanks! Using an energy bike to power a relay and switch TV power on is a nice idea. I’ve used mine to run a small TV, but it can be quite a workout. I used a high quality DC servo motor to maximize mechanical-to-electrical conversion efficiency.
    PraV1
    4 years ago on Introduction
    I want to make it sir , but i am not aware of electrical terms ......
    How much energy does this cycle can produce if i use this for 1 hour /10
    hours continously....I am planning to make a cycle where the energy
    generated is stored in battery..... How to store this energy and reuse
    it ? Does this serves the purposes of daily needs of house ?
    wingsingerPraV1
    Reply 4 months ago
    You can only generate about 100 Watts/hr. 10 hours of cycling would give you 1 kWh. The average home uses about 20-30 kWh/day. It’s more practical for energy education and charging small battery systems in remote areas.
    wingsingerUrgreatness
    Reply 4 months ago
    I salvaged parts from a recycler, so I spent less than $30. The exercise bike was found on the curb.
    oxidosis
    10 months ago
    Is there a way to hook it up to my house? So I can put electricity back into the grid, if I want, or use the energy to power whatever is presently running in my home?
    wingsingeroxidosis
    Reply 4 months ago
    You would need an inverter that could match the grid frequency, but you would only be able to generate 1kWh every 6-10 hours.
    Big up for the design. Although I'm not a gym-goer, I have been entertaining the idea of setting up a 'generator gym', in which each device generates power. One way to go about it would be to set up universal power connectors as outputs of each piece of equipment, thereby allowing members to come in, work out, and charge their mobile phone at the same time. Another way would be to have all the units connected up to the gym's (low-voltage DC) electricity system, with a battery (linked to the grid via a transformer) to accumulate generated power and supply consistent voltage to the gym. In this case members would come in, work out and collect energy credits. Each member would own a card, which would have to be inserted into a machine before use to record the amount of electricity generated, thereby earning them tradeable credits and/or a reduced membership bill. Does anyone think this is a realistic/workable idea or would the equipment dwarf the forseeable profits? Does one of these already exist? Would the generated electricity be worth all the hassle and cost?
