Twine Ball Lamp Shades
18,271
630
15
About: follow me on instagram @dbey_b www.danielakucher.com
Spring has sprung! Revamp your outdoor decor with these DIY twine lamp shades. Transforms your traditional christmas lights into ambient spring and summer lights.
Supplies:
Step 1: Gather Your Materials
Cotton twine
Mod Podge
balloons
plastic wrap
spray paint (I used Krylon Metallic Gold)
paint brush or foam brush
christmas lights
Step 2: Wrap, Wind, Wait.
Next, you will inflate the balloons to your desired size.
Wrap each balloon in plastic wrap.
Wind the twine around each balloon and over the plastic wrap. (Don't worry about cleaning up the ends, you can trim them after drying.)
Use a paint brush or foam brush to paint the Mod Podge over the twine. Be generous! The more Mod Podge, the stiffer the shades with dry.
Now you must wait for the Mod Podge to dry. I suggest waiting overnight to achieve the best results.
Step 3: Pop and Paint!
After your Mod Podge dries, you will pop each ballon and pull out the balloon and plastic wrap from the interior.
I suggest first pushing into the balloon at the openings to pull the plastic wrap away from the twine. The Mod Podge might dry and adhere to the plastic wrap.
Afterwards, spray the twine shades with your selected spray paint.
Step 4: Almost Done!
Once your lamp shades are done drying, you can string them onto the christmas lights.
Find the larger gaps in the twine and stuff several light bulbs into each lamp shade. Continue this process, stringing the lamp shades along the lights.
You can choose how to use them. Lined in a row, placed in a bowl, or strung across a balcony.
Step 5: ​Now That Your Christmas Lights Can Be Used All Year Round, Enjoy!
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
  • Woodworking Contest
    Woodworking Contest
15 Discussions
mommywoman
4 years ago
If you use LED lights and the wires are in good condition you shouldn't have to worry about fire hazards. LED lights stay cool so not likely to start a fire. Regular Christmas lights like the ones being phased out get very hot. I think those minis call for C7 and C9 bulbs. I'd definitely stay away from those inside on these balls. You figure the hotter burning C7, C9 even though rated for indoor and outdoor should be ok outside cause everyone uses those on bushes and the heat doesn't ever seem to be an issue.
SweetSecrets
5 years ago on Introduction
OooooOOOoooo I like these. I might just try them out. Great design, good idea!
dbeylinakosteej
Reply 5 years ago on Introduction
I haven't had any trouble with these shades for a full year. I would recommend only using these outdoors where the air is cooler, and over-heating is less likely. Your largest safety concern is replacing any string of lights with worn or broken cords or loose bulb connections.
sunshiine
I love your design. Thanks so much for sharing your hard work and do have a safe and happy spring!
sunshiine
Thanks! not that tricky at all. Definitely let them dry completely and you can use scissors to try to cut away any plastic wrap that my solidify from the Mod Podge.
tpatten-scheinost
5 years ago
this is a great tutorial and a very clever design. thank you.
susanjerrell
5 years ago
On my um to do list. So pretty.
