Two Point Door Lock
About: radom diy projects
lets make a strong two point lock
we need
  • 3d printer
  • epoxic glue
  • instant glue
  • 3mm shaft
  • 12mm shaft
  • geared motor
  • 2 releys
  • 2 terminal switches
  • dc to dc step down converter (if needed to slow down the motor)
  • input signal (i use motorbike alarm system (because of the control's code))
Supplies:
Step 1: Printed Parts
print the .stl file
you may modify the motor's holder
Step 2: Instant Glue 1
glue the 3mm shaft for the central gear
Step 3: Instant Glue 2
  • glue the lock's holders if needed
  • press it well
Step 4: Mark the Shafts
mark the shafts to glue them with the 3d printed parts
Step 5: Strong Hold
  • cut a little the 12mm shafts for a strong holding
  • glue with the epoxy shaft and 3d printed parts
Step 6: Assembe
  • add the 12mm shafts on the lock-door
  • assemble all the parts
Step 7: Make H-bridge With Terminal Swiches
make a simple h-bridge with 2 relays
that must have
  • 2 inputs for relays
  • 2 inputs for terminal switches
  • dc input
  • output to motor
Step 8:
add the motor and conect the wires
Step 9: Lock-unlock Distance
add the terminal switches like the pics (i use instant glue)
glue them at the corect point for the lock-unlock distance
Step 10: Thanks and Good Luck!
if it broken good luck!!
you must always have a plan b to get in
if you like it, subscribe here and at my youtube channel to help me grow the channel!! :)
off grid crafts
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Arduino Contest 2019
