USB Power Bank
52,257
632
34
Welcome to my instructable!
Today i will show you how I made USB Power Bank.
It holds anywhere to 7000-16000mAh ,which depends on batteries you'r using. Capacity for C type batteries
This small device can be used to power any small gadget which use 5v USB input like those small rc quad copters and rc cars.
Module i'm using is USB step-up booster ,which boosts anywhere form 0.9V ~ 5V and can output stable 5V dc voltage. This will not charge your phone! For that application please use different kind of module.
Anyway back to project!
Supplies:
Step 1: Parts
Step 2: Preparing Parts and Project Box
I started by modifying battery holder and project box to fit each other.
Then i placed parts in project box and arranged them in order which they fit best.
Step 3: Soldering
Soldering is pretty straight foward.
Just solder positive to positive and negative to negative ,just remember to add switch between one of those wires so you can turn power bank on and off.
Step 4: All Done
After soldering all parts together you can put in batteries and close project box and your done!
This is how my project turned out , I'm pretty happy with result and it definitely dose what it's made for.
I hope you'r will as well!
Thanks for reading my instructable!
    • Woodworking Contest
      Woodworking Contest
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    34 Discussions
    DanielB770
    1 year ago
    would I be able to use a double a battery pack instead?
    KlarikaC
    3 years ago
    I have a 10,400mah in the first place I full charged my power bank, after 3days when I plan to used it my power bank isnt turning on.. the lights dead.. I try all the possibilities and way but I failed
    Nmoleo­KlarikaC
    Reply 2 years ago
    You can't chargen D batteries, you probably destroyed them...
    Mediadaha
    2 years ago
    wow,, i like this article.
    www.pinglagu.wapka.mobi
    Syashp
    3 years ago
    I have A power bank of Mi 10400mah it doesn't in working condition.But I have 2 batteries of 2500mah how can i use it.
    FanisSDIYByKev
    Reply 4 years ago on Introduction
    No !!! Rasberry pi needs min 1000 - max 2000 mA to work fine !this psu give 600mA . Maybe works but not as could
    WhiteRenardFanisS
    Reply 3 years ago
    I use a 850mA usb charger for my RPi and it works fine with a wireless keyboard connected and ethernet port.
    Aron Rc RC
    4 years ago
    Hey dude,
    I made it ,it fives good result,
    but,
    I can,t charge my phone.
    !!!!!!!!!! what is the reason !!!!!!!!!.
    It should. If it spits out 5V. Most phone chargers are 5V @ 500mA. The boost regulator says 600mA and it has a performance of approx 80 - 85%.
    There's of course the problem of batteries but from what I gather from this:
    http://en.wikipedia.org/wiki/C_battery
    These batteries are capable to spit out enough current to drive the boost regulator at it's 600mA peak. So it should work with most if not all normal phones. In case of an iPhone and other such Satanist worship artifacts, I think they don't care for standards much (or they break them intentionally to sell you more stuff) so I can't guarantee.
    Found this. https://www.instructables.com/id/Modify-a-cheap-USB...
    Apple is pure evil. Customers should not put up with this nonsense. Anyway, if you want an apple thing, add these resistors and you're good to go.
    PS: Add how much battery power you want, provided you keep the voltage below 5. A boost regulator only drives voltage up. You could literally provide your phone with juice for a month or so if you plan a long trip or something.
    I did try out it on my Iphone 5c or as you may recognise as Satanist worship artifact xD and Nokia Lumia 520 And believe it or not they did not charge.
    On Iphone it didn't work cause of those resistors you mentioned earlier or as I call their function - providing data signals, but i see no reason why it didn't work on my sisters Lumia ,But that may be because i used used batteries for this project.
    I don't get why people these days care that much about other's stuff. At least I go for most appealing design which is closer to my taste.
    Anyways thanks for your comment ,it really made my day, at least that par about ,,In case of an iPhone and other such Satanist worship artifacts''
    I apologize. I have a weird sense of humor. I too own a mac and an iPhone. It's just that they don't adhere to standards that annoys me.
    brzi420DIYByKev
    Lumia (and most of the non-apple prdoucts) might charge if you just put a 47ohm resistor between USB data pins
    DIYByKevmanxm
    But did you know that iphone dose not charge by only 5v input?
    It needs resistance at data ports too, without them it wont charge
    zappenfusen
    Encouraging to know the stuff on E-bay is not all highly suspect.
