USB Made From Recycled Wood
21,089
183
This instructable shows how to convert a common usb to a beautiful one. Changing the plastic or metalic cover to wood.
Step 1:
Materials
1.- Rotary tool with accessories for sanding and cutting.
2- White glue
3.- USB
4.- Silicone, to fill the USB body
5.- Recycled wood, in this case I take a piece from an old pallet
6.- Two clamps to fix the wood while gluing
7.- A pencil and a rule
8.- Sandpaper, to finish the project.
Step 2: Cutting the Wood
First we lowered a little the wood for the rotary tool can easily cut wood.
Remember to make all cuts with maximum precision, this reduces the probability of complete failure or long sanding
Step 3: Cutting the Cap and the Body
The middle one small piece will close the body while usb usb to subject the the wood.
Step 4: Piercing the Wood
Issues to take in consideration
The hole of the body contain the usb only and we will fill with silicone to secure only a little more. This hole is not visible.
In this case, as the USB cap is quite large cut.
Usb plate is a little wider than the metal part. When making the hole small piece should make some small guides on the sides for the board to enter but not exit ahead.
Once satisfied that the small piece usb and fit properly seal the remaining gap between them with hot glue. (The hot glue is not applied in the photo)
Step 5: Assembling
Use clamps to secure the union of the two parts after applying white glue.
This will ensure that both parts are firmly attached and after sanding the piece will be well hidden union.
Soon I'll finish this instructable showing how to make the cap and the final sanding. Meanwhile you can see a finished item at :
http://www.etsy.com/listing/126081198/usb-recycled-wood
It's my first (but not the last) instructable, please contact me for any inconvenience or improvement.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    3 Discussions
