UVIL: Backlit Blacklight Nightlight (or SteamPunk Indicator Lamp)
24,814
205
22
About: The pre-neopostmodern electro-Amish man using sense and caution when voiding any warranty.
How to put together an eerily glowing neo-retropostmodern ultraviolet indicator lamp.
This shows the construction of the first two that I made as a way to evaluate the PCB etching process outlined in another Instructable. My idea is to use these as indicator lamps in some other projects.
My son insisted that I enter it into the LED contest because he wants a TV-B-Gone kit, so be sure to vote it up if you like it. (Click the + icon at the top of this page)
You should open this pre-requisite Instructable in a new tab or window: https://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/
It is the method used to do the etching in this instructable and has the added bonus of giving the PCB's a nice green tint.
Eventually I will make stained wood and brushed aluminum enclosures for these. I also plan to make use of these as indicators on some projects. (They are actually quite significantly brighter than they appear in the pictures)
Step 1: Gather Materials
Aside from the etching materials (which are listed in the separate Instructable noted) you will only need:
  • Ultraviolet LED's - I got 200 for $10 on eBay. I think cool backlight effects could be made with any LED combination you like, my preference just happens to be UV.
  • Fluorescent acrylic - McMaster carries this, as do alot of industrial supply houses. I got mine for $0.99 in the form of a tacky cutting board from a thrift store. Again, green is my preference, but the material comes in a couple of fluorescent colors. I think that maybe I'd like to try red, too.
  • Standoffs - I used #8 threaded couplers
Step 2: Layout the Top Board
You will be etching two boards. One will be the front/top (whatever you want to display) and the other will be the back/bottom, holding the batteries and UV LED's.
You can be pretty free laying out the top, just be sure to stay far enough back from the edges to clear your stand-offs and Remember to reverse your image for etching!
Step 3: Etch the Top Board / Layout the Bottom Board
After etching the top board using the process outlined at https://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/ you will need another board to hold the LED's and batteries. The second board needs to be the same size as the first.
You will need to decide:
1.) How many UV LED's you want to use
2.) Where to place the LED's
3.) How to supply the power to the LED's
I took a little 1-LED coin-cell flashlight and replaced the white LED with a UV LED. This allowed me to shine from behind the board to see what different placements would look like. Bending the LED's over (rather than have them aimed at 90 degrees to the board) gives more coverage.
Once you have decided where to placed the LED's you need to decide where to place the battery (or power wires). You can get PCB-mount coin-cell holders - I cut a piece of battery contact from and old lamp, bent it, and riveted it to the board for one contact. The other contact is just a large pad on the board.
If you wonder why there are so many parallel traces on mine, it is because I wanted to see how well traces of different widths would come out of the etch.
Step 4: Etch & Solder the Bottom Board / Cut Acrylic
After etching the bottom board and fixing the components in place you need to cut out the acrylic to size. Be sure to cut out for your standoffs, too.
This doesn't have to be pretty since it's only purpose is to diffuse and fluoresce in the background. In fact, I scuffed it up with some 100 grit sand paper to help diffusion.
Step 5: Assemble / Gape and Genuflect
All three layers are now done - time to make a big green sandwich. Assembly is straight forward: Top layer on top, acrylic under that, PCB next.
A picture of my first UVIL assembly is below.
Also is a (wiggled, blurry) picture of the Olivian UVIL backside showing the roller limit switch I added so that you can turn it off just by laying it down. I wanted to use a tadly mercury switch but didn't have one on hand. Incidentally, The Olivian UVIL bottom PCB also used a sharpie pen as resist (rather than toner transfer)
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    22 Discussions
    RedBinaryLinuxH4x0r
    Reply 11 years ago on Introduction
    The first board only took maybe 30 minutes. However, The etchant seemed to dilute quickly and each additional etch took much longer. The last board I etched took more than 12 hours. The longer the etch, the more the toner seemed to suffer. I may attribute some of this to the temperature of my basement, though. I need to try some temperature-controlled tests. I may also attribute some of this to my using 2-oz double-sided blanks, so I need to get some 1/2-ox stock.
    I prefer to use sponge method of etching. Dip soft sponge into etchant and rub board. This process is very fast. Nice job though.
    Years later ... I finally started playing with the sponge method earlier this year. You are quite correct! I also started using the stronger Hydrogen Peroxide that I can get from a beauty supply chain, too. Etching takes under 60 seconds in most cases now and uses about a shot glass of etchant!
    T-Hawke
    8 years ago on Introduction
    Great Job! 4 years and still a very cool project. Well done!! Have you thought of using a caged ball instead of your roller switch? Looks great now just thought it might add even a little more "punk". Great Job!!!!!!
    RedBinaryT-Hawke
    Thanks for the kind words! I ended up replacing the limit switch with a mercury switch from an old thermostat.
    kc5qnk
    10 years ago on Introduction
    Way cool! I'm going to make a "call sign" sign for my ham shack... 73, Rusty KC5QNK
    Dissension
    This is a very cool project. I think I may attempt it. I must say though this is instructable is really not detailed enough for a complete electronics newb like myself. Actually it wasn't until I saw Randomskk's project that I realized this is not a big lamp and its actually very small lol. Randomskk's has a little more to it as far as some of the details. I dont know. I just found it a little easier to follow. I really appreciate both of you for doing this so I wont be as lost. Thanks and keep up the good work.
    poeticoddity
    I've been wanting to make a lamp like, this, but wasn't really certain how best to go about it. This is quite helpful, and you did a really good job. My only worry is that you've got UV LEDs pointed out the sides of the lamp, and UV radiation is bad for skin and even worse for eyes, so it might be best try to find a way to put edges on any with UV LEDs. Awesome tutorial, though.
    igorgama
    This looks amazing, but I'm having a really hard time finding some of the materials (the fluorescent acrylic and the etching board). Can you give some more specific details and maybe some links to where I might get them. I don't mind paying more than you did. (I know I'll have to) Oh, and if you have any links to more basic tutorials or instructables on etching, printed circuit boards and circuits I would greatly appreciate it. I'm getting really interested in these subjects, but it's hard to find more basic stuff about them. Anyway, thanks for any help you can provide.
    RedBinaryigorgama
    You can get the acrylic from McMaster if you don't feel like digging - I've never bought it from there, but I do know they carry it. I see alot at thrift stores an you can find clipboards to cut up at Wal-Mart, Target, OfficeMax, and the like.
    Someone else had sent me a msg asking about getting started with etching so I looked around for some web pages that I thought would be useful:
    Here's what I found:
    http://www.headwize.com/projects/garbz2_prj.php
    http://myweb.cableone.net/wheedal/pcb.htm * I had never read this one before - it's a little more technical way of doing the printout, but I think it may be a better way.
    http://www.solarbotics.net/library/techniques/buildpcb_trnsfr.html
    igorgamaRedBinary
    Thanks a lot, they even ship internationally! The guides will be very helpful too.
