Ultimate April Fools Virus
If you want a harmless yet hilarious virus to seriously freak out your friends at work, school or at home. KEEP ON READING! This Instructable will also give you some basic batch file knowledge so you can start creating your own awesome 'Viruses' from scratch!
What you need for this Instructable
- A computer
- Memory stick (not mandatory but a good idea)
- A little bit of time
- Friends, Family, Co-workers or somebody to totally freak out!
Feel free to comment once your done, thanks!
Supplies:
Step 1: Where to Create Your Devious 'Virus'
Goto notepad. All Windows computers come with this simple yet usefull program. Hold down the 'windows run key + r' and then type notepad or go through your start menu. (start - all programs - accesories - notepad)
Step 2: The Batch File
Now type the following into notepad EXACTLY HOW YOU SEE IT! (What's better is just to copy and paste. . .)
@echo off
echo WINDOWS HAS DETECTED A VIRUS, WOULD YOU LIKE TO TERMINATE?
echo -
echo PROCEED WITH VIRUS TERMINATION(Y/N)
set/p "cho=>"
if %cho%==Y goto forward
if %cho%==y goto forward
if %cho%==n goto Shutdown1
if %cho%==N goto Shutdown1
:forward
echo VIRUS HAS BEEN DELETED
Pause
echo PLEASE ALLOW WINDOWS TO PREFORM A SAFETY CHECK
Pause
echo SYSTEM CHECK
echo HARD DRIVE - FAILED
echo -
echo RAM - FAILED
echo -
echo DISK DRIVE - FAILED
echo -
echo CONNECTION - FAILED
echo -
echo WINDOWS SUGGESTS YOU DELETE ALL FILES TO RESUME(Y/N)
set/p "cho=>"
if %cho%==Y goto Sucess
if %cho%==y goto Sucess
if %cho%==n goto Shutdown2
if %cho%==N goto Shutdown2
:Sucess
echo WINDOWS HAS DELETED ALL FILES
echo -
Pause
echo SYSTEM CHECK
echo -
echo RAM - FAILED
echo -
echo -
echo -
echo WINDOWS IS SHUTTING DOWN IN 20 SECONDS TO PROTECT FROM DAMAGE
goto Shutdown3
:Shutdown3
shutdown -r -t 20 -c "APRIL FOOLS! HAHAHAHAHAHA"
:Shutdown1
shutdown -s -f -t 60 -c "Windows is shutting down to prevent any further damage"
:Shutdown2
Step 3: Explanation
Ok for those of you who are skeptics or unsure about this, I'll explain what it does:
@echo off ------> Hides the code, looks more professional
echo WINDOWS HAS DETECTED A VIRUS, WOULD YOU LIKE TO TERMINATE? -----> writes this on screen
echo -
echo PROCEED WITH VIRUS TERMINATION(Y/N) \
set/p "cho=>" \
if %cho%==Y goto forward }--------> Gives the victim the choice whether or not to proceed with the choice "Yes" or "No"
if %cho%==y goto forward /
if %cho%==n goto Shutdown1 /
if %cho%==N goto Shutdown1 /
:forward
echo VIRUS HAS BEEN DELETED --------> same thing for the rest, writes this onscreen
Pause ---------> tells victim to press any key to continue
Pause
echo SYSTEM CHECK
echo -
echo RAM - FAILED
echo -
echo -
echo -
echo WINDOWS SUGGESTS YOU DELETE ALL FILES TO RESUME(Y/N) -------> same thing as above, gives a choice again
set/p "cho=>"
:Sucess
echo -
Pause
echo SYSTEM CHECK
echo -
echo RAM - FAILED
echo -
echo -
echo -
goto Shutdown3
:Shutdown3
shutdown -r -t 20 -c "APRIL FOOLS! HAHAHAHAHAHA" -----------> restarts victims computer in 20 seconds and writes "April Fools! HAHAHAHAHAHA
:Shutdown1
shutdown -s -f -t 20 -c "Windows is shutting down to prevent any further damage" ---------> shuts down victim's computer and writes "Windows is shutting down to prevent any further damage"
:Shutdown2
shutdown -s -f -t 20 -c "Windows is shutting down to prevent any further damage" ----------> same as above
Step 4: Save Your Devious File As a Batch File
Ok so now you want to get your 'Virus' up and running right? Well it won't do anything as a plain .txt file (text file for those who didn't kno...) Ok so save this as something your victim will click on thinking its something normal so System Check.bat notice the .bat at the end! YOU MUST HAVE THIS TO RUN IT SUCCESSFULLY! I would save it to desktop so its visible and easy to find.
Step 5: DONE!
Now your done, go freak out people. Be wise with this though, you don't want to get into some serious trouble because somebody takes it seriously. . .Anyways and with this you should probably be able to mimic my "Virus" and create your own. Upload it onto a memory stick or send it through e-mail and get this around to your next April Fool's victim :P
Feel free to comment, thanks!
  • Woodworking Contest
    Woodworking Contest
  • Gardening Contest
    Gardening Contest
37 Discussions
AmoghA1
4 years ago on Introduction
thank you, when i read it, my mouth was open for about 30 seconds. amazing!
but the only problem is that i couldnt run it.
but I MADE IT!!!!!!!
GoWolves11AmoghA1
Reply 1 year ago
To disguise it as another file(movie, video, music, pic, etc) so your victims click on it, name it with a .bat extension and create a shortcut. Then right click the shortcut and go to properties. Then from there disguise it.
20charlie02
3 years ago on Step 2
That's really good! I made one just like it by myself and my brother totally freaked out when he went to open internet explorer XD.
nemanja2k8
10 years ago on Step 5
yo, nice job. I've wrote some similar batch!!! but I made an Autorun.ini on USB flash drive that automaticly start the batch. it costed me 30 minutes or so, but my friends face.... PRICELESS!!!!!!! :))))
TheodorosN1erikals
Reply 3 years ago on Introduction
You can just get the Autorun.ini from a CD that has it and change the path, or search the internet for how can you do that.
haha ya for someone who's just plain paranoid or doesn't know much about computers, there reactions are always priceless and hilarious :P
deval90
9 years ago on Step 5
hi, okay u have created the code but after i send it to someone, how can they stop it?? like after second shutdown, will the computer be back to normal or keep shutting down forever??
TheodorosN1deval90
It should be fine as long as they accept to delete their files, but if anything bad happens, you can open Run (Win + R), type in quickly "shutdown -a" (without the ") and hit Enter or click OK. That will only work while it's shutting down, but it should stop the fake virus from shutting down the computer.
actually no. it only fools your friends so that you can laugh to your death! ( actually not that you will die!).
No, you're good. It just says that to make the victim think that it did that.
Copy and paste this into Notepad:
@echo off
@echo Hello! This is a simple batch program!
pause
OK, now that you did that, save it to your Desktop as "Test.BAT" and make it so it says "All Files" on the second choice. Leave the third choice as is, then click Save and close it. Open up the file and here's what you'll see (without the quotes):
"Hello! This is a simple batch program!
Press any key to continue..."
And after you press a key, it'll close. You can replace "Hello! This is a simple batch program!" with something else, like, "WARNING: YOUR COMPUTER HAS DETECTED A FATAL VIRUS!!!!!"
The @echo reads the text after it (if it's on the same line) and commands the computer to display that text.
The @echo off commands the computer to hide the @echo command to make it look more professional.
The pause command tells the computer to display "Press any key to continue..." and will command the computer to execute the next command after a key has been pressed. Or, if there's nothing after it, the window closes.
chamster
8 years ago on Step 5
How do u send it to people on email so that it actually activates when they look at it?
mnovelli2chamster
Reply 6 years ago on Introduction
You can put it in a zipped folder named as something urgent, when they open it, BOOM
