Ultimate Road Trip Car Conversion (Honda Fit)
180,476
754
55
About: I love to make anything I can!
When my wife and I found out that we had two months to take the cross-country road trip of our dreams, I immediately knew that I was going to transform my ordinary Honda Fit into the ultimate road-tripping machine. One of my keys to a great road trip is flexibility, so I wanted the flexibility to sleep in the car in parking lots, rest stops, or the wilderness. I knew this would come in handy after a late night drive, when its raining and I don't want to set up a tent, or other unforeseen circumstances.
I had slept in my Fit before, but I knew that with two people and all of our gear; I would need to build an integrated storage/sleeping unit. The idea was simple, build a platform to sleep on with enough room for all of the things we need underneath. The Honda Fit combines great gas mileage (39 mpg) and unexpected roominess making it a great car for my wife and I on our road trip. However, the principles in this Instructable could be applied to any hatchback, SUV, or van.
What you’ll need:
Road-trip worthy vehicle, plywood (3/4 and ½ inch, 1 sheet of each 4x8 ft), 2 inch wood screws, wood glue, hot glue gun, large sheet of cardboard, box cutter, 7-8 ft of continuous hinges (piano hinges), jig saw, drill, mosquito type netting, old sheet, and magnets.
(optional: table saw, miter saw, orbital sander)
Those are 72" Thermarests in the photo. Also, the weight of all the wood is less than the weight of the seats I removed!
Step 1: Plan Ahead
Before you start anything, you need to look at your car and decide how things would best fit. For my Honda Fit, I decided that I would use the height of the wheel wells in the rear as the level of our sleeping platform. The Honda Fit also has seats that fold flat in the back which I was able to remove to create some large space for storage. I also pushed the two front seats all the way forward and measured the length of the cabin at the proposed platform level. It measured just over 6 feet, which is exactly my height. With these details in mind, I began building the frame of our sleeping platform.
Step 2: Building the Frame
First, I built a T-shaped spine that divided the cabin in two with the top of the T being at the platform level. I used 2 inch screws and wood glue to secure the T shape. For my frame I used ¾” plywood, because I knew it would be sturdy, and I had it on hand. My spine member rested along the floor near the rear of the cabin and had a foot extending down to the floor of the removed seat wells. The top of the T spanned from the rear of the cabin to as far forward in between the front seats as possible without making driving uncomfortable. For me this meant being able to shift into 4th gear without my elbow hitting the spine.
To support the spine, I made two ¾ ” plywood cross members. For ease of removing the platform to access the spare tire and for storage after our trip, I didn’t want to screw or glue the cross members to the spine. Instead, I made ¾” slots in the bottom of the spine and the top of the cross members, so that they slide together at a 90 degree angle. I also cut notches in the cross members so that the top of the cross member would be level with the top of the T-spine. I chose the location of the cross members based on how I wanted to split the storage space in the rear of the cabin. The width of the cross members was determined by the width of the cabin at those points. I added notches in the cross members and two cross bars to give the whole frame some rigidity. Then I moved my attention to the platform.
Addition: I ended up cutting large chunks out of the long "T-spine" to save on weight. 3/4" Plywood is very strong, so I didn't need that much material.
Step 3: Building the Sleeping Platform
I wanted the sleeping platform to follow the contours of the cabin walls, so I started by prototyping the platform with cardboard. I put the seats in their full forward position and cut out two six feet long pieces of cardboard. I placed them over my frame and used a box cutter to rough out the cabin profile. For my platform, I used ½” plywood in order to minimize weight while retaining strength. Using my cardboard patterns, I traced the platform shapes onto the plywood and used a jigsaw to cut them out. I then placed them in the car to ensure the correct fit.
Step 4: Folding the Platform
Obviously, you can’t drive with the seats pushed all the way to the front of the car, so the platform needs to fold back into the cabin. Using the cardboard, I found the location that I could fold the plywood back without hitting the sidewall or the ceiling. For me, this was about 1/3 back from the front of the platform. I drew a line where I wanted the hinge, and I cut the plywood with a jigsaw. Using the continuous hinges is easy. Line up the two pieces together, center the hinge over the two pieces, and screw in the screws that come with the hinges. I also used these hinges to create a hatch to access the storage space between the cross members. I drew out the shape I wanted for my hatch making sure that there would be support underneath for the hatch (enclosed as well as for the remaining platform). At the hinge of the hatch, I cut the platform across entirely, so that the front could also hinge upward. In my Honda Fit, this would allow me to easily fit and remove a large storage bin underneath the platform. I used a jigsaw to cut out the hatch and an oblong hole to use as a handle. After sanding all the edges, I laid the pieces all together, and screwed in the continuous hinge in the two places shown in the picture. This all resulted in my platform being divided into three foldable sections connected by the hinges. I laid the platform on top of the frame and made sure that all of the hinges worked properly and the wood was properly cut.
Step 5: Final Supports
The last thing that the platform needed to be structurally sound, were supports directly behind the seats in the front part of the platform. For these, I simply measured the height from the floor of the vehicle to the bottom of the platform right behind the front hinge and right behind the seat. Then using ½” plywood, I cut out a U-shaped support with the legs being those lengths. I put them in their place and checked to make sure the platform was level and adequately supported throughout the cabin.
Step 6: Locking Things in Place
To keep the platform and frame from sliding around in transit (and scuffing the cabin walls), I used small pieces of ¾” plywood, set the platform in the location I wanted, and hot glued the small pieces to the underside of the platform surrounding the frame supports. For the U-shaped supports, I used longer pieces of the ¾” plywood. These keep the platform from sliding relative to the frame and keep the U-shaped supports in the correct location.
I'll add pictures of these tabs at a later date to make it more clear.
Step 7: Ventilation and Privacy
To offer airflow while sleeping in the vehicle, I wanted to be able to keep the windows down without letting bugs in. So, I got some netting from an old tent and sewed window sleeves. With the car door open, I folded a large piece of netting over the top of the door covering the open window. I roughly cut the shape of the window and then sewed the sides up to finish off the sleeve. I was able to sew the netting with a conventional sewing machine. By putting the sleeve over the door and putting a magnet strip across the bottom of the outside, the windows were sealed off from bugs.
To provide privacy, I traced the shapes of my car windows on an old sheet, cut out the shapes, and hot glued magnets along the edges. These magnets hold the window shades around the inside of the window on the metal door frame.
Bonus: To enable us to keep the side windows open if it was raining, I used old milk containers, duct tape, and sheet plastic to make a little rain cover over the door frame. The corners of the milk containers simply close in the door frame and hold the plastic out over the open window a few inches.
Step 8: Conclusion
At the time of publication, we had begun in North Carolina, camped in the Badlands National Park (SD) and were headed to Glacier National Park (MT). We love the car, the 39 MPG, and the sleeping platform. Having separated storage areas has been wonderful to keep things neat throughout the road trip. We use the back compartments for shoes and "garage items" (camping stove, fuel, soaps, cleaning supplies), the hatches in the middle for our clothes, and the large storage areas where the seats used to be for gear and food.
Happy road tripping! I'll update more photos as the trip continues!
Outside Contest
Runner Up in the
Outside Contest
Car and Motorcycle Contest
Second Prize in the
Travel Tips Contest
First Prize in the
Travel Tips Contest
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
55 Discussions
AndreiF28
Question 3 months ago on Step 2
Do you think it would've worked with 1/2" plywood? Details on my build: I will use Baltic Birch(Russian Birch). I wanna make fully enclosed boxes/compartments/divisions, like a chest fouton with multiple lids. Below the opening edge inside there would be a supporting rim (3" of ply or so, screwed every 4-6") so the lid falls flush with the mouth of the compartment and rests on the supporting rim screwed inside of the box walls. My panels/openings would be 24"x36" at most. I'm thinking both 1/2" for the walls and the lids. The Baltic Birch seems to be the strongest plywood available from what I read.
1 answer
JMYillaAndreiF28
Reply 2 months ago
Yeah, I think if you used Baltic Birch and your compartments/divsions supported the top well, then 1/2" would be fine.
Zesty Italian.
Question 6 months ago on Introduction
"The Honda Fit also has seats that fold flat in the back which I was able to remove to create some large space for storage."
Thanks for the posting! I have a 1st Gen Fit and I'm interested in doing something like this. I'm wondering how much trouble is it to deal with any idiot lights that come up after removing the backseats?
1 answer
JMYillaZesty Italian.
Reply 6 months ago
There weren't any idiot lights when I removed mine! Just a few bolts off and its done, pretty quick.
sthornhill
6 months ago
Great Instructable. I have a 2008 Honda fit, I think your is the same mode. This is a great quick get up and go for quick camping or boondocking.
Keep up the good work!
DaleS74
Question 8 months ago on Step 8
1) Are the PDF plans scaled dimensional drawings that include the measurements for the contoured cutouts around the wheel wells, etc.?
2) Must the rear seats be removed for the frame to fit?
3) What year is your Fit?
truckerkathy
9 months ago on Step 2
Was glad to hear how you did the windows with netting. Was thinking about doing the same thing. Hadn't thought about the magnets. Looking forward to hearing more.
PatriqH
Question 9 months ago on Step 6
Did you (or anyone who's tried this) ever get a chance to take photos to better explain step 6? I'm having trouble understanding exactly what you did here.
arcee2010
Tip 1 year ago on Step 5
Add 2 - 1x1 rail under the platform so one can slide the support thru it. You can make 2 sections to accommodate the folding part. this way you'll always know where it goes.
Alaskan Bev
1 year ago
Excellent ideas, great creativity and innovation! Great DIY ideas! Since my husband hates camping and our kids are grown, if I'm camping I'm either with my Boy Scouts and we're in tents, or else I'm back in the woods somewhere in my own tent or sleeping in the back of my Jeep (which can also be "intense" - sorry, couldn't resist...). I am 5' 1.5" so sleeping on the flattened seats is fine, and my gear can take up the other half. Driving a lot of bumpy back roads, the old driving-laundry trick works very well: throw laundry in a 5-gal bucket with some water and a few drops of dfetergent, snap on the lid, drive on, rinse things out at night and hang to dry. Clean and neat as can be! Camp on!
f1dd13r
2 years ago
Great instructable. We are thinking of doing something similar but a different model of car. I guess if there was only one of you travelling, you would have even more than 6 feet of sleeping space as you could sleep diagonally.
VictoriaB57
2 years ago
Hi this looks awesome!
My partner and I are looking at doing a similar sort of thing! However we have a Renault Modus 2005 (Not the grand Modus) Which is quite a bit smaller than your car. We were looking at selling it and getting a new car to do this but we love our Modus and insurance is cheap/it's cheap to run. We've both laid out in the car and with the front seats pushed all the way to the front and leaning in towards the front we can actually stretch out straight (I'm 5ft6 and my boyfriend 5ft7 so not really tall) With about an inch to spare so we're thinking of actually just keeping our car and looking to build something bespoke to fit it (I think the rear seats can be taken out) as buying something larger in our budget would probs cost a fortune with insurance (Due to the car being a lot older and fuel costs). The only problem is, to get the leg room our front seats need to be pushed and leaning over forwards so our base height will have to be at the point on the front seat that our legs are able to stretch fully out if that makes sense, and the legs of the base will have to be quite a way back compared to the top of the base with the remaining wood from the legs onwards hinged to fold back when we drive. (I hope this makes sense haha). Do you think this is doable? Do you think a design similar to yours would work but a bit smaller and with the legs further back at one end? Sorry about all these questions we've not done anything like this before so any help would be appreciated haha :-). We do have a friend whoi is into woodwork and carpentry though so hoping to rope him in to help us! :-)
Great job though!!!
JMYillaVictoriaB57
Reply 2 years ago
Hi! I think I understand the problem you are talking about. You need some new supports to undergird the "fold-out" section of the platform. If you look at Step 5 on my instructable, it shows how we made legs that slot into the bottom of the platform to support it. You are right that it is an important step! Good Luck!
CarolineM59
2 years ago
Hello,
I was wondering if you could send me the PDF files on who to creat this?
I going on a road trip with my Fit this summer around the State, and this car plan conversion seems dreamy :)
Caroline M.
JoeyF7
3 years ago
Big question. I have a Honda Fit - the EXACT same model as yours. Your design is amazing! Im also 6ft and would love to duplicate what you have created! Do you have the specific measurements for your frame? The pictures are very useful, measurments would be very appreciated if you have them. Thank you!
JMYillaJoeyF7
Reply 3 years ago
Hey Joey,
I don't have any measurements on hand, when i made it i just measured as i went. If you live on the east coast I'll sell you my whole rig though. I'm finished with it for now.
JMYillaArmyguy94
Reply 3 years ago
I would probably like to charge $300, which would include the grey pads that lay overtop of the wood. (not the thermarests, but the foam/rubber sheets underneath it.
