Unicorn Barf
178,818
708
84
About: I'm just a lady who likes making stuff. I got my degree in engineering but also enjoy cooking, sewing, knitting, gardening and backpacking, among other things.
Ever since I found out that you can buy cereal marshmallowsin bulkon the internet, I have been dreaming about making cereal marshmallow marshmallow treats. Similar to rice cereal treats, but with only the best part of any cereal- the cereal marshmallows! They have affectionately become known as "unicorn barf" around these parts, for obvious reasons, but what is a bad day for a unicorn is a delicious day for everyone else! They are super simple to make and look really pretty!
Step 1: Ingredients
For this recipe I used:
2 cups of marshmallows
2 1/2 cups of cereal marshmallows
1/4 cup butter for the treats, plus extra for greasing everything
You will also need a sharp knife, a sauce pan, a spatula and a baking tray or glass tray.
This recipe made 15 small pieces of unicorn barf but of course you can make more or less depending on how much you want, just keep the ingredients proportional.
Step 2: Melt Down Your Marshmallows
Before you do anything else, butter up everything you are going to use for this recipe. This will keep it from getting as sticky from the melted marshmallows. Butter up your baking sheet or glass tray beforehand. Don't skimp on the butter. Butter your hands if you want to use them for mixing. Trust me, you'll thank me later!
Melt the 1/4 cup of butter in the sauce pan over low heat, and add the two cups of regular marshmallows and stir constantly until the marshmallows are completely melted. I found this goes faster if you chop up your marshmallows before you add them to the butter. Keep stirring until the marshmallows are completely dissolved and combined with the butter and have a smooth consistency.
Step 3: Add Cereal Marshmallows
This step you have to move fast.
When your plain marshmallows and butter are combined and have a smooth texture, take them off the heat and add your cereal marshmallows. Stir them together quickly with your spatula until the cereal marshmallows are evenly coated, but not too much that the melted marshmallows start to dissolve your cereal marshmallows! It's an art. When the cereal marshmallows are thoroughly coated, spread the mixture onto your buttered baking tray or glass tray in a roughly rectangular shape about an inch thick. It will probably stick together fairly well. The shape doesn't matter too much since you are going to cut it up later, but it's helpful if it has relatively even thickness.
Step 4: Put It in the Fridge and Wait!
This is the hardest part. Put it in the fridge and wait for about 20 minutes. This is the perfect time to wash out the pan before the marshmallow starts to solidify in it. I found that using very hot water is the best way to get the sticky marshmallow goo out of the pan.
Step 5: Cut, Serve, and Enjoy!
I cut this batch into a rectangle because the cute sides look really pretty with all the different colors of cereal marshmallows. I cut the rectangle into 15 pieces that were about 1.5 inches square. These things are so sweet, that's probably going to be all you want!
3 People Made This Project!
  • Jewelry Challenge
    Jewelry Challenge
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
84 Discussions
Ethan1023
1 year ago
Not to be a critic, but your response was grammatically incorrect.
Ethan1023
2 years ago
Did you know that Unicorns eat rainbows and poop butterflies?
DanielleK17
3 years ago
I recently made a post on The Fairytale Traveler about rainbow recipes and featured this recipe - just wanted to make sure you're ok with my using a photo and linking back to this Instructable. This recipe is all kinds of awesome and can't wait to make it :)
grannyjones
3 years ago on Introduction
Do not even consider using vegetarian "marshmallows" for this. Nasty, NASTY stuff!
carol.mcmunn
4 years ago on Step 5
These are amazingly easy to make, and so much fun to serve and eat. The name is priceless, and they're always a hit! I used mini marshmallows to save time on cutting the larger ones ahead of time (yes, I'm lazy) - worked like a charm!
irishparrothead
4 years ago
What about mini marshmallows or marshmallow fluff? Would those work in place of chopped up regular marshmallows?
Mini marshmallows would definitely work! I'm not sure about marshmallow fluff, but it seems like it should work. You could experiment a little bit and see how that works :)
