"Union Jack" Palette Table
51,850
1,154
47
About: A factory where geek stuff are made every day - creative gym where you have our space, tools and knowledge at your disposal. Let's create together!
I present you my first custom order palette build finished just a few days ago. A girl wanted to surprise her boyfriend for his thirtieth birthday so she asked me to do this cool Union Jack alike table she saw somewhere on the web but out of palettes and with glass on top. Here's what I manage to do in approx. 30 working hours...
Step 1: Tools and Materials
Although this project consumed significant amount of working hours (for sanding as always with palettes) it's really very simple and strait forward to do. Here's what you'll need...
Tools
- electrical sander(s)
- drill
- paint brush
- sand paper
Materials
- 2 x wooden standard size palettes (in EU its 120 x 80 x 14.5 cm)
- about 1.5l of paint (1l black + 0.25l red + 0.25 white)
- 4 bolts with nuts
- 4 standard furniture wheels (I recycled mine from an old office chair)
- some masking tape
Step 2: Paint and Assembly
So the first thing you should do is drill 4 holes in place where you would like to connect two palettes. You'll have to do this on the 2 bottom boards of the top palette and on the 2 top boards of the bottom palette. So, measure some fixed distance from the edge of the top palette (18 cm worked for me), drill the holes there then align the two palettes to best-fit each other, mark the places on the bottom palette (just nudge the pen trough the drilled top palette holes), take it apart, drill holes on the bottom palette. this way you will have nice fit of the palettes with holes drilled on right places (this is all because palettes often miss the dimensions, sometime more than 5 mm).
After you paint both palettes in black it is time for masking tape and Union Jack flag layout. I didn't use exact flag layout because it was easier to do like this and it's was not so important. Have patience and press the masking tape really god or paint will go under it - this happened to me but was not so important also.
Paint the white parts 2 times, then put another mask for red and paint 2 times and you are ready for assembly.
Of course, you need to screw in the wheels first - just drill 4 holes on the bottom palette and screw or glue the wheels in (depending on the wheels type you have).
Step 3: The Final Result
And that's it - you are ready to pimp up your living room with this awesome contemporary recycled table...Align the palettes, fasten them together (do not forget to paint bolts and nuts to black or red) and voila!
Of course, the good thing would be to add some table glass on top but if you don't mind this holes you can go al naturel :) You can modify the build by adding some lights under the top palette or by creating some storage boxes - it's up to you.
Enjoy and geek on!
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    47 Discussions
    spatial guy
    6 months ago on Step 3
    G’day, I really liked your project, caught my eye straight away. I love the Nintendo one too!!
    If I could make one quick suggestion, if you continue the vertical red stripe All the way through so you have a Red Cross + in the centre it will pull your table into focus.
    (Also, did you notice the optical illusion you created with your painted lines, it makes the gaps in your table top planks look bowed outward on either side. Works if you draw the same pattern on paper with two lines through it - cool) )
    phenry5
    5 years ago
    Thanks for a great idea. This project was a good one. My personalized Blue marlin design.
    14, 4:42 PM.jpg
    phenry5
    5 years ago
    This is my pallet table. Not finished yet but an alternate design idea.
    14, 4:28 PM.jpg
    psauvignac
    5 years ago on Introduction
    Thank you for your great idea !
    I'm moving to my new apartment so instead of buy one desk, and 2 tables, I rather made them with your instructable.
    Here is jamaica's flag and union jack and switzerland are coming ;)
    I also bought 3 glasses to put on the top but it's too bad that it's so expensive (approx 280 euros :/ )
    OMG the Jamaica's one is amazing - can I share this one on FB page? Now when I see it I will do one for myself...
    sure, no problem ! But if you can wait for tomorrow, i'll send you a photo with the full project, not like this one in my garage ;)
    gr8! I'll wait for better pic...tnx a lot! p.s. you can add your "credits stamp" on the pic itself or you can post the pic on the FB page (https://www.facebook.com/G33Kdesigners) directly so I can share...
    Moki1992
    5 years ago
    Genijalno! Svaka cast. Jedino me zanima ovaj dio "take it apart"... kaj se tocno skida sa palete?
    GEEK factoryMoki1992
    Reply 5 years ago on Introduction
    Tnx...ma to je u fazi kada bušiš rupe za šarafe - da zategneš palete skupa - jer teško je pogoditi točno mjesto. Znači prvo izbušiš sa donje strane gornje palete, onda ih privremeno obje spojiš skupa i poravanaš kako najbolje paše. Kroz rupe olovkom označiš lokacije na donjoj paleti, pa ih onda rastaviš i izbušiš donju...
    abrown39
    great idea man and cool ible, I did notice on error, the horizontal on the cross that makes up the "jack" shouldnt have white lines going all the way across, it should 90* as it meets the vertical, and that vertical is supposed to be the same thickness as the horizontal stripe, so it should be a red cross bordered with white, thats just one thing I noticed, And im an American. other than that great job. One thing i thought might help was buy better wood like for decking or something and make your own pallets that way you wont have to try to fix a sloppily put together pallet with the cheapest wood possible, you will start with quality material so the sanding and prep time should be alot faster, that way you really dont spend as much time on it. If you did that I bet you could still make some decent money at 150 Euro, and deliver it faster, you would probably have to make one that way to nail a price down, but If I could order a custom table like that for around 100-150 plus the glass, or a sheet of plexiglass that is really cheap, that would be great. Maybe even make a few templates and sell a "custom" production piece and then charge more for custom ordered patterns. and if you used plexiglass you could ship it complete, just remember to use a masonry drillbit if your going to drill through plexiglass, a regular wood bit will shatter/crack plexiglass
    GEEK factoryabrown39
    Mate tnx for the all inputs - it helps a lot...like I mentioned above, I gave a lot of thinking on this subject and the only smart thing I could think of is just combine both. There are two major issues when sanding a palette: one is a fact that there is a lot of hard reach places where you must hand sand instead with the sander. OK, I could take a palette apart but here we come to the second problem - this is not so easy as it sounds. Original EU palettes are nailed together with those special "screwed" nails and when you try to remove planks they crack easily...
    abrown39abrown39
    I realize using new wood kinda defeats the purpose of re using a pallet, but if your selling them, what is more important recycling a pallet and spending 30 hrs sanding, or just starting with more expensive good wood, and sanding for a few hours? I personally would go with a home made pallet from better wood that way there are no knots to fall out or split boards, or waterlogged 4x4's, I just looked real quick and 2 12ft sections of nice pine decking 1x6's would be about $20 US 2 12ft sections of nice pine 1x4's would be about $12, thats enough for 1 pallet if you make it from scratch reusing 4x4's, and then the 4x4's who cares really about that just tear a pallet down and steal those, Or just replace the top panels only and you could still reuse most of the pallet and end up with a great surface quickly for about $15 USD, Since you would use 1 12ft section of 1x6 and 1x4 to replace the top boards. so add lets say 8 hours of labor on top of that at what $10 an hour thats 95$ in material and labor plus a 10$ sheet of 4x6ft plexiglass and your looking at 105-115$ in material and labor so a $150 price tag would give you 35$ in pure profit and then 10$ an hour for labor. Just a thought hope that helps
    deddog
    To smooth a rough pallet quickly try going over it with a blowtorch before sanding, it burns off all the rough edges.
    Ps: I'm 53, English and I only recently found out that the term "jack" is only [supposed to be] used when the flag is flown on a ship!
    Blacksedan47
    5 years ago on Step 3
    Nice job, I applaud you for using used wood. People will spend extra money to buy things made from repurposed material. Plus that pallet may have history. No telling where it been in its life.
    I agree - that's why I tend to do everything using used wood - recycling is one of 3 principles I run this small geek business of mine - other two are personalization and modularity...
    I put a lot of thinking in this new vs used materials, just like @abrown39 suggested, but for me it's not the same, repurposing and recycling something has more sense, especially in this time we live in...
    But far from that I wont use new material if needed...especially if new materials relate to some cutting edge and eco friendly technology...
    kirnex
    VERY cool. Looks great! Thanks for sharing.
    8steve88
    Damn right some of us Brits get ornery when it comes to the Union Jack, the term used before P.C. conspired to ruin this country.
    How many North Americans would like to see "Old Glary" with the Union canton stretched to eight stripes or shrunk to six stripes.
    A nations flag is important to that nation so it's only common courtesy to get it right.
    Saying that it is a cool use of pallets, I'm a joiner by trade so know how much effort is involved in getting a good finish. You might want to look at a product called Sanding Sealer, it goes on thick and dries fast, if you are over-painting with an opaque paint is can cut the time to a smooth surface dramatically.
