Unlock Zip Ties
20,000
87
4
Zip ties are awesome. They can hold wires together, create a makeshift zipper pull, and are good at strapping small things together. The only downside is they can only be used once, until now. If you don`t know how to unlock a zip tie, the only way to get them off of what they are attached to is to cut them. This makes them seem like they are one time use, but they are not. Unlock them. They can be used again and again.
This is a video that covers how to unlock zip ties. For more detailed information, go through the photos on each step of this instructable.
Step 1: Gather Supplies
You will need:
Zip Ties
Small pointy object (needle or safety pin)
Step 2: Find the Lock
Find the small ratchet pin. It is located inside the box at the top of the zip tie. You can see it tagged in the picture.
Step 3: Stick the Pin In
All you need to do to release the ratchet is shove the needle between the locking pin and the long end of the tie. Push it in far enough that the lock releases.
Step 4: Pull
With the needle still in the mechanism, pull the end out. It is as easy as that. Zip ties that have been opened then used again will be weaker than brand new ones, but they still are very hard to release on their own.
Zip Tie Challenge
Runner Up in the
Zip Tie Challenge
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    4 Discussions
    Roentgenium111
    3 years ago
    I forgot how but I was able to unlock zip ties by hand with out tools.
    Cekpi7Roentgenium111
    Reply 3 years ago
    you can use end of ziptie to push instead of needle
    nanaverm
    3 years ago
    Never knew they could be opened and reused - thanks!
    _soapy_
    3 years ago
    Even better is to put a small hook on the end, & use that to pull the rachet part.
