Unnecessarily Ornate Dremel Bit Caddy
This caddy displays Dremel bits while reducing the risk of damage by keeping them in individual holders.  It includes a drawer and a compartment to store additional accessories.
This project is a great way to use up random wood scraps.  Caddy includes cherry, walnut, purple heartwood, padduck, sapele and bloodwood.
Plus, it has sparkles...
Supplies:
Step 1: Materials
Materials
Top Shelf
1 - 3/4" wood 4.5 inches by 3.5 inches
1 - 1/4" wood 4.5 inches by 3.5 inches
Middle Compartment
2 - 1/4" wood 2 inches high by 3.5 inches wide (Mitre cut 45 degrees)
2 - 1/8" wood 1" high by 3.5 wide (Mitre cut 45 degrees)
Base
1 - 3/4" wood 4.5" by 3.5"
1 - 1/4" wood 4.5" by 3.5"
1 - 1/2" wood 4.5" by 3.5"
2 - 1/8" wood 1" by 3.5" (Mitre one end 45 degrees)
1 - 1/8" wood 1" by 4.5" (Mitre cut 45 degrees)
Drawer
2 - 1/8" wood 3 inches long 1.25 high (Mitre cut 45 degrees)
2 - 1/8" wood 3.5 inches long and 1.25 high (Mitre cut 45 degrees)
1 - 1/8" wood - 3.5" x 3.25"
Dowels
2 - 3/4" - 10" long
1 - 1/4" - 8" long (Mitre cut 30 degree angle on each end)
3 - 1/8" - 6" long
Veneer - Small piece cherry and walnut
16 - Swarovski crystals
Wood Glue
Crazy Glue
Shellac/Denatured Alcohol
Tools
Dremel
Dremel Bits
  • Cutter 125
  • Cutter 194
  • Sanding Drum 407
  • Grinding Stone 84922
  • Drill Bit Set  628-01
Mitre Saw (not pictured)
Drill and Hole saw attachment
Pencil
Scissors
Paint brush
Measuring Tape
Hole Punch
Clamps
Tweezers
Step 2: Drill Holes in Dowels
The dowels will be glued into the base and support the upper shelf with 1/4" dowel between them.  The top three dowels secure the shelf (you really only need one but I like how it looks with three).
Drill 1/8" holes in both dowels at 3", 8". 8.5"
Drill 1/4" holes in both dowels at 9"
Step 3: Mark/Drill Holes
Pencil a grid pattern across both shelves.
On bottom shelf trace 3/4" hole on right and left for dowels.
On bottom piece of compartment trace 3/4" hole on only the right side (so that shelf can swing open to reveal compartment).  Cut out the left hand corner in a 1" square.
Drill out holes for bits.  Drill all the way through the wood.  In the next step a bottom piece is glued on.  This makes it easy to make all the holes the same depth.
Drill out holes for the dowels with a 3/4" hole saw
Drill holes for bits - Customize to fit your collection (add sizes)
Step 4: Construct Base, Drawer and Middle Compartment
After the bit holes are drilled, glue on the 1/4" bottom piece and clamp until dried.
Use hole saw to drill hole for the dowel and sand if necessary.
Glue up base and clamp.
Glue drawer.
Step 5: Shellac
Shellac all pieces prior to adding inlay and crystals.
Step 6: Glue Inlays
Glue veneer circles and crystals around shelves.
Step 7: Assembly
Glue 1/8" dowel between large dowels
Affix large dowels to base.
Place compartment over dowels
Place shelf over dowel
Glue in top dowels
Enjoy your well organized Dremel bits!
First Prize in the
What Can You Do with a Dremel Tool?
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    3 Discussions
    burnerjack01
    7 years ago on Introduction
    Very nice, indeed! I like the hint of Japanese influence. Utility with style. I don't think that's overly ornate at all, merely shows you as one who cares enough to go beyond "bland box syndrome". Good job.
    babyruthless
    8 years ago on Introduction
    Now I want to go out and buy a few dozen new bits just to justify building me one of these! Very cool!
