Up-cycle News Paper to Plant Pot to Grow Tomato
39,410
210
25
About: My Name is Daniel Aeschlimann. During the day I am a Mechanical Engineer. During the evenings I tinker with witn my 3D-Printer, my CNC router and with Arduino. Some projects i record on video and upload them...
We are waiting for the coming season, the spring.
I want to grow some tomato on my balcony. So i seed many different tomato sort. All of them sprout and I have to prick them into a pot.
Because i had not enough small plant pots i made some of old newspaper.
How i did it, you can see in this instructable or in the video, where i explain it in German. https://youtu.be/ihZBykvZeqA
Step 1: Cut the Newspaper to the Right Size
The size you need depend on the size of the pot you want to make.
I just cut one page of the newspaper height-wise in half.
You want to have a sheet long enough to fit at least 5 times the diameter of the pot. The height has to be approx. twice the height of the pot.
The fastest way for me was to fold the newspaper and use a knife for cutting the paper.
Step 2: Prefold the Rim
Later we want to fold the rim inside. This is much easier when we prefold it.
Fold 1-2cm on the long side. Reopen the fold.
Step 3: Wrap the Newspaper Around a Thing
I use a jam jar to wrap the newspaper.
With the Thing you use, you decide witch diameter you pot will have.
In my case the jar has a diameter of 7cm.
Step 4: Build the Bottom of the Pot
To build the bottom i simple fold four times the shell to the middle.
It is important to have the jar still inside the paper. It helps to fold the bottom.
The folds don't have to be perfect. But if the shell is to long it is difficult to fold it. (As soon the paper is wet, the bottom will be perfect flat, even if there are some wrinkles.)
With two finger i sculp the edge of the bottom.
Step 5: Remove the Jar and Fold the Rim
Now we can pull out the jar.
When we fold the prefolded part of the shell to the inside to sculpt the rim, the pod gains stability.
Step 6: Fill the Pot With Soil
Now you can fill the pot with Soil
I used quite dry soil. So i saturate the pots some hours with water before i went to the next step.
Step 7: Prick Your Seedling Into the Pot
Finally plant you seedling into the pot.
Don't forget to water them frequently!
Have fun!
If you have more than one sort of plants you have to go to the next step.
Step 8: Label the Pots the The Name of the Plant
With my 3D-Printer i make a sign to label the Pots.
If you want to adjust the size you can edit the fusion 360 file http://a360.co/2nSY1Ot
The *.stl file is attached, or on thingiverse: http://www.thingiverse.com/thing:2155271
Or i can print some for you: https://ewap.ch/produkt/pflanzenschilder/
  • Organization Contest
  • Weaving Challenge
    Weaving Challenge
  • Trash to Treasure
    Trash to Treasure
25 Discussions
MiljaH
2 years ago
Hmm. Similar label stands using recycled material rather than 3D-printing would be fabulous. I guess I must start searching for a suitable material...
shmariaMiljaH
Reply 1 year ago
permanent marker on an ice cream stick?
MiljaHshmaria
Reply 1 year ago
Wooden sticks tend to get mold in the moist soil. (At least here 100% of ice cream sticks are wooden.)
I do have plastic sticks for the purpose, but I really meant a label stand that isn't a stick but rather folds around the edge of the pot.
shmariashmaria
Reply 1 year ago
Even used plastic spoons will work - you just have to write really small
mxx
2 years ago
Great instructable! Cheap and fast. And another reason why we should save the newspaper industry.
AlanS14
2 years ago
I remember my Grandfather doing that many years ago (50+). Brings back memories of his tomatoes, and his crysanthimums ......
faniefaze.
2 years ago
Cool, now where do one get German newspapers ;-)
AllisonL29
2 years ago
Would this be good to start sunflowers??? My class is growing sunflowers for the Global Project. We are only tracking growth for a month, before school is out for summer. Any advice is welcome!
lomo85AllisonL29
Reply 2 years ago
Why not? One month after seeding the plant has grown enough to be planted outside.
temperamental
2 years ago
great project for the kids...beats the brain dead video games.
Moschtertaart
2 years ago
Hi lomo85, Good job ! Please attach the fusion 360 file to your Instructable.
lomo85Moschtertaart
Reply 2 years ago
Sure, here is the link: http://a360.co/2nSY1Ot
Moschtertaartlomo85
Reply 2 years ago
Many thanks, I need to adapt the diameter to the jam jar I want to use.
ericCycles
2 years ago
For small seedlings, I used to do this. I now use transparent plastic cups with some little holes punched in the bottom. They don't sag and tear when they get wet, and you see if the seedling is becoming rootbound.
lomo85ericCycles
Reply 2 years ago
Thank you for your tip. I will check if i get some rootbound before planting them in a big pot.
SusanP90
2 years ago
On the plus side you can later plant them in the ground.
Thanks for sharing :)
lomo85SusanP90
Reply 2 years ago
Yes, this is one of the main advantage. The Time you need to fold the pots you save wile planting them later.
robotobor
2 years ago
Love your work! I have done this, also used empty paper towel rolls, empty TP rolls, and finally my favorite, garden fabric (folded similar to your design, with a bit of hot glue). You might like the "air pruning" method with your tomatoes. google it, seriously worth the time. Promotes huge, health roots. Best of luck!
lomo85robotobor
Reply 2 years ago
Thank you for the "air pruning" tip!
I planed to put them in a standard pot, but maybe i have to build something air pruning like...
joe.lyddon.7
2 years ago
Why not GLUE the label to the Newspaper?
... and save all that time?
Nice way to fold the POT!
I also like using the tubes from paper towel & toilet paper rolls...
Thank you!
Dunka...
