Upgrade Small Linen Closet in Bathroom to Include Hamper
1,619
20
The purpose of this project was to take a miniscule linen closet, and utilize the space above it, which was wasted. It also gave us a home for a hamper, away from our clean clothes in the closet.
The project used basic tools and took only two days to complete.
- 3/4 inch birch plywood
-1/2 inch birch plywood
- 1x2 poplar
- crown molding
- 3 sets of hinges
- cabinet door hardware
Supplies:
Step 1: Demo
To begin we removed the old closet door, then demoed the door trim. Next I demoed the existing fixed shelving. I cut the top of the closet higher into the unused space. I went up to a height of 96 inches from the floor.
Step 2: Build a Box
Next I built a plywood box out of 3/4 birch plywood. I built this 24 x 24 x 96. I built a floor for the box about 4 inches up from the floor and then a divider shelf about 40 inches from the floor, to separate the linen closet from the hamper space.
Step 3: Trim the Box and Build Doors
I trimmed the box after sliding into place. The trim was 1x2 poplar strips which I used pocket holes to secure to the box. I added a bar below the divider shefl as seen in the pic, so that a pull open hamper door could be built.
I did use a router to build rail and style doors, but these could also be built using flat panels and trimmed with panel trim. I mounted the three doors with hinges.
Step 4: Paint and Finish
Next I added the upper trim, which was made of a thin crown molding. The trim turned back on itself and terminated against the wall. I then filled any voids where the face frame met the drywall with mud and sanded smooth. We then filled any cracks with caulk and painted.
Step 5: The Final Touches
The final steps were to add hardware. This gave the new linen closet a very high end look compared to what we had before, and it was a much better use of the space.
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    bfarm
    1 year ago
    Really great looking built in!
