Upgraded Couch Legs
859
12
My friend told me how he had bought a couch and the legs were made of cheap plastic. Soon they were breaking (lay off the burgers Keith!) We can do better than that! I was able to make replacement legs for about $14.00 with simple parts from Home Depot.
Supplies:
Step 1: What's Needed?
I needed a few things:
  • Measurements off the old legs :8 inches tall and they tapered two inches in diameter down to an inch and 3/4 diameter. One inch of 5/16 threaded rod rises from the top to screw into the sofa.
  • A 2 inch diameter x 48 inch dowel for the new legs
  • threaded 5/16 rod
  • 5/16 t-nuts
  • pencil
  • hacksaw to cut the threaded rod
  • drill press to drill centers (you could get away with a drill)
  • sander
Step 2: Cut to Length
I cut the 2 inch dowel into 8 inch lengths.
Step 3: Drill the Centers
I then found the centers of each dowel and drilled a 5/16 hole into each dowel as deep as I could go using the drill press.
Step 4: Add the T-nuts
I took the t-nut and hammered into place. into each hole.
Step 5: Taper the Leg
I flipped the leg over and then drew a circle to mark how I wanted the taper to finish. I took the dowel to the sander and took my time eating away at the dowel. A sanding wheel made short work of this, but many different methods can get this same result.
Step 6: Round the Edges
After I reached my bottom diameter, I rounded the edges by hand. to give things a clean look. I wasn't perfect with this, because it will be against the floor.
Step 7: Add Threaded Rod
I placed the threaded rod in my vise and cut it into 4 inch pieces. I then threaded these into each leg. The thread in about 3 inches leaving 1 inch rising out of the leg.
To finish these, I'm going to let my friend pick his stain color and then they should simply screw into place. The solid wood will last much longer than the hollow plastic, and depending on the finish he picks, could change the look of the couch!
Step 8: Finished Legs.
Finished legs! Ready for stain.
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    2 Discussions
    markmuilwijk
    1 year ago
    looks Nice! Did you fill up the space between the threaded rods and the wood inside the legs?
    Snackattackermarkmuilwijk
    Reply 1 year ago
    I didn't. The hole isn't much bigger in diameter than the rod. I threaded them down and they fit snug.
