Use Raspberry Pi 3 As Router
43,006
98
28
About: Check out my YouTube channel, for similar projects.
According to Wikipedia, a router is a networking device that forwards data packets between computer networks. If we tear-down a wireless router, we will probably find an application specific processor that handles data packets and an RF segment that handles wireless connectivity.
You know what else has a processor and an RF segment.
THAT'S RIGHT a raspberry pi model 3. So in this miniProject, we will convert a raspberry pi to act as a router.
Step 1: Video
Take a look at video for quick comprehensive guide in 3 mins.
Step 2: Boot-up Raspberry Pi.
First step is to get your raspberry pi up and running. Official getting started guide on Raspberry pi website is best resource for this.
Here is the link.
Go to next step once you have your raspberry pi up and running.
Step 3: Upgrading Raspberry Pi
First we will update package list available from repositories using
sudo apt-get update
Once done, we can install these latest packages using
sudo apt-get upgrade
This might take a while depending on your internet connection speed.
Step 4: Installing Hostadp and Bridge-utils
Once raspberry pi is upgraded.
we need to install a user space background process called hostapd, used for wireless access points and authentication servers. We will also need a package called bridge-utils to manage bridge devices.
sudo apt-get install hostapd bridge-utils
We need to turn off some of the new services that we just installed do it using
sudo systemctl stop hostapd
Debug- Some times raspbian will display message saying hostapd and bridge-utils not found for install command. Do not worry. Run 'sudo apt-get update' once more and it should get resolved.
Step 5: Disable DHCP Config for Wlan0 and Eth0
Now, we set dhcp background process not to automatically configure wlan0 and eth0 interfaces. We do this by putting following two lines
denyinterfaces wlan0
denyinterfaces eth0
at the end of /etc/dhcpcd.conf file, open it using.
sudo nano /etc/dhcpcd.conf
Step 6: Creating Bridge Br0
Next, we create a bridge br0 using brctl command which is an Ethernet bridge administrator
sudo brctl addbr br0
and using
sudo brctl addif br0 eth0
command we add eth0 as one of the ports for bridge br0.
Step 7: Edit /etc/network/interfaces
Now open up a file called interfaces in /etc/network directory
sudo nano /etc/network/interfaces
and add these five lines.
allow-hotplug wlan0
iface wlan0 inet manual
auto br0
iface br0 inet dhcp
bridge_ports eth0 wlan0
First line starts wlan0 interface on a hotplug event. Second line creates a network interface without an IP address which is normally done for bridge elements. Third line starts br0 interface on boot up. Forth line helps in automatic assignment of IP address to br0 interface using DHCP server and finally fifth line connects eth0 interface with wlan0. Save this file and close it.
Step 8: Edit /etc/hostapd/hostapd.conf
Next, we will configure our wireless access point, we can do this using a file called hostapd.conf in /etc/hostapd folder. Open it up
sudo nano /etc/hostapd/hostapd.conf
and paste these lines.
interface=wlan0
bridge=br0
ssid=miniProjects
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=subscribe
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
Value assigned to ssid is the name that access point will use to broadcast its existence. Last five lines are focused on authentication and security of access point. Value of wpa_passsphrase is used as login password which is subscribe in our case. This is a link to document, where you can find definition of each variable that we have used here.
Step 9: Final Edit /etc/default/hostapd
Finally, open up hostapd file in /etc/default directory
sudo nano /etc/default/hostapd
uncomment DAEMON_CONF line and provide path to file we just created.
DAEMON_CONF="/etc/hostapd/hostapd.conf"
This completes setup for raspberry pi to act as router.
Step 10: Done
Now, power-on your raspberry pi with Ethernet cable connected.
You should see raspberry pi broadcasting ssid and access internet.
Thanks for reading.
Let me know if you face any issue while creating your own router.
Please vote for this instructable, if you liked it.
    • Tape Contest
      Tape Contest
    • Remix Contest
      Remix Contest
    • Pie Contest
      Pie Contest
    28 Discussions
    mannumx01
    19 days ago
    all very well until you get to the topic of internet access. If you do not correct the DNSs you will never have Internet access.. keep in main.
    BenHarp
    Question 4 weeks ago on Step 10
    I lose connection to the internet when I plug in the ethernet cable. What should I do?
    janbenes
    Hello! I am able to run AP. I would like to know how to find the IP address of AP, so I can ssh to it. Also how do I know IP addresses of other device connected via WiFi to Raspberry AP? DHCP leased addresses? Thanks, Jan
    Jacobs02
    4 weeks ago
    Ist a WLAN-Bridge not a Router...
    JayeshS3
    Tip 6 months ago
    I had a problem with the command
    - sudo brctl addbr br0
    It returned the error
    - sudo brctl addbr br0 add bridge failed: package not installed
    To avoid fix this issue I reinstalled raspian and I did a reboot after step 4
    Hopefully this helps somebody avoid the issue I faced :)
    skischlumpfJayeshS3
    Reply 5 weeks ago
    I had the same problem running the raspbian jessie image. After flashing raspbian stretch, the issue was solved!
    andr3w2
    Question 6 weeks ago
    Hi guys, can anyone help me?...I m becoming crazy!!!
    I first followed the steps to configure the PI3 as an access point (there are a series of extra commands...) and then the procedure above.
    In the end, however, I can not navigate.
    Indeed if in the first case I saw blinking the two arrows and recognized the interfaces now instead the two arrows of the connection are barred, with dhcpcd lost and no wireless interface.
    I have re-checked everything, I can make further changes only on hostapd.conf, but I left the standard values on non-personal parameters.
    dreedx2
    Question 7 weeks ago
    I've had my pirouter running for a few months. My isp router is on the 2nd floor and now I have a strong signal downstairs. I would like to get more signal in my back yard... My questions are: 1 Can you recommend a hi-gain usb antenna compatible with RPi for this project. 2 Can I edit my existing Setup for what I presume would be a change from Wlan0 to Wlan1? Or do I need to redo my original setup substituting Wlan0 for Wlan1 at each step? Thanks for the original project and any help you can add for my update.
    JasonB586
    7 weeks ago
    the instructions are great, except for one significant item. What you have described is NOT a Router, it's a Bridge. It would be great if you could change the title, just in case people follow your instructions expecting to end up with a Router, and then get confused, or even locked out of their Pi because it's a Bridge. Perhaps 9 out of 10 people don't care because both a Bridge and a Router will do the same job of connecting WiFi to Ethernet. However, some of us specifically want to create 2 discrete subnets, and following your instructions would make that very difficult to achieve.
    enpboss
    2 months ago
    I have made it, Wi-Fi is working fine, but locally while trying to install some updates (apt-get update ) no internet access ,i have tried with browser also
    Rohan_V
    Question 3 months ago
    Is there a way to make it portable or does it always have to be plugged into ethernet?
    toshiePovilasJ2
    Answer 3 months ago
    On the device (router, server, etc) you plug in to eth0.
    (This is *bridge*, not router, setup tutorial regardless what the article's title says).
    kenxshiba
    Question 3 months ago on Step 10
    Can this Instructable work with 1 dongle instead of an ethernet cable? I'm trying to make a Pi Laptop by using a tablet with VNC and connect the tablet to the Pi and use it as a display (I got the tablet for $40).
    dingusdongus
    Question 4 months ago on Step 10
    Cool instructable, I set everything up and triple checked in case I had any mistakes. It does not work for me, and I was hoping you could point out if I did anything wrong. I put the ethernet cable in and every thing, reset the pi. It shows up on my phone as a connection point, but it tells me I put in the wrong password. I know I'm putting in the right password, I've tried many times. Is there any way to fix this?
    MatthewD250
    4 months ago
    This is awesome, but I was wondering about things: 1.What is the boot up time 2. Instead of re-reouting the data packets, could the input data into audio output? Application would be to stream audio, specially airplay. No single device exist to accomplish this, aside from expensive head units.
    I have been hitting a brick wall wall for the past 2 years in finding a device I can airplay to without using a wifi network or using my phone as a hotspot (kills my battery especially when streaming music). Another huge plus is that there exist quite a few high quality raz pi audio components to get high quality sound.
    I would think the hardest part would just be redirecting input into the open source software, Shairport Sync. If your interested a posted a tutorial for creating ras-pi airplay receiver.
    https://pimylifeup.com/raspberry-pi-airplay-receiv...
    I'm not sure if one raspberry pi could handle both processes, but if two were needed I suppose I would want to port the wifi pi output via eithernet to the audio processor pi.
    ThomasdudeMatthewD250
    Reply 4 months ago
    Hello MatthewD250,
    Bootup time is extremely short. This is part of the basic Linux-settings after all, so it should boot about as fast as linux itself does.
    As far as streaming audio goes - these would still be data packets, right? It would still use TCP/IP to transfer those packets using this setup...
    I'd check if Shairport Sync has some kind of listener you can direct the input towards - that might encode the output in the correct way somehow.
    Let me know if you find something, it sounds really cool if you could pull it off!
    R G L Goldberg
    Question 5 months ago on Step 10
    This looks interesting but I have 3 questions. First, will this work with a Raspberry Pi 2? Second, what sort of load does this place on the CPU in the Raspberry Pi (I currently use it as an ancestry database for my wife)? Third, can I specify the source for the DNS?
    The last question is because my ISP force-feeds their DNS to their customers though the routers they provide & I currently have all the computers in the house set to use OpenDNS so my ISP is not always looking over our shoulder.
    1 answer
    ThomasdudeR G L Goldberg
    Answer 4 months ago
    Hello R G L,
    1. If you have a wifi-adapter for your RPi2, it should. Setup might be a bit more complicated though.
    2. Near nothing - or at least very little, unless you connect a bunch of devices on it at the same time (in the order of tens of devices).
    3. No. Your DNS-requests would be forwarded to your current router. There might be a linux-package you could install to avoid this (such as OpenDNS), but I'm not sure on that.
    Hope that helps!
    julyjim
    7 months ago
    Does this setup implies that I could connect Ethernet cable from my PC direct to RPi?
    Bypassing my current router.
    If so how would I get to Internet from either "client" ?
    Utilising my current router wireless hardware ?
    Or is this "bridge" really connecting RPi eth0 to RPi wlan0 keeping current Ethernet connection from Rpi to my router ? Hopefully not messing access to RPi via ssh.
    Since there is only one Ethernet connector on RPI - is this router primary intended to route wireless traffic? ( I do not fancy USB dongles overloading the RPi USB power bus )
    Would network bonding accomplish same ?
