Use an Arduino With an N64 Controller
81,644
139
107
There are tutorials out there for using an NES controller with an Arduino, but using the more complicated N64 controller and its analog joystick has a definite appeal. If you have an Arduino around and don't want to buy an Adaptoid, this instructable will make it possible to play emulated games in Project 64 with your Ardunio and an N64 controller.
Is this hard? / Will it damage my stuff?
This will not modify your controller in any way, and the wiring is extremely simple, so if you do everything carefully there should be no risk to your controller, and you can unhook it at any time to use with a N64 console.
What you will need:
Arduino - $30
Processing 1.0 - free
Arduino Software - free
3 pieces of wire - free (I hope)
USB cable
Step 1: Wiring the Controller
The first thing you need to do is connect your Arduino to the controller
The controller only uses three leads: +3.3V, signal, and ground.
Looking directly at the plug, ground is farthest left, signal is in the middle, and +3.3V is on the right. Using the wire, connect ground and +3.3V to the respective pins on the Arduino, and connect the signal lead to the Digital 2 pin on the Ardunio.
NOTE: If you have other code on your Arduino, you should disconnect the controller and upload the new code from the next page to the Arduino before powering it up with the controller attached.
Connect the Arduino
Connect the USB cable and the Arduino will have power.
Step 2: Unpack and Run the Code
This code was written by me, with parts of the N64_Arduino file based on assembly code written by Andrew Brown.
ZIP Archives:
The two Zip files below contain the code needed to run the Arduino and then to interpret the data it sends to the computer. The N64_Arduino file needs to be compiled in the Arduino IDE, and the N64_Controller runs in Processing 1.0.
N64_Arduino
This PDE file should upload to your Arduino and run without a hitch if you have everything connected properly. It simply queries the N64 controller for data on the buttons and Analog stick and sends it back to the computer over the serial port. It is easy enough to modify, for example, you could use the methods from this file to query a controller and use the data to run an Arduino robot instead of transmitting it back to the computer.
N64_Controller
This is a Processing 1.0 project that takes the data transmitted by the Arduino and converts it into keyboard presses that you can map to an emulator like Project 64. You might need to change the line String portName = Serial.list()[1];to match the your Arduino, it should be either Serial.list()[0]; Serial.list()[1]; or Serial.list()[2];
EDIT: Add
"import java.awt.Robot;"
"import java.awt.AWTException;"
"import java.awt.event.InputEvent;"
to the code if you are using Processing 1.1
N64_Controller_mouse
This is the same as N64_Controller, except that the analog stick controls your mouse, not the arrow keys. A and B are right and left click, respectively. To activate the mouse, press the start button on your controller.
Step 3: Set Up Project 64
Before you can use the controller, the Arduino needs to be connected and running the code you downloaded in the last step, and Processing 1.0 needs to be open with the N64_Controller program running.
Test it out in Notepad, pressing the A button should type an A, B should type a B, etc.
So now you have a working controller (hopefully) and you want to play some games.
Downl0ad PJ 64
http://www.pj64-emu.com/downloads/
Set Key Mappings
Start PJ 64 and open the settings menu first (Ctrl+T). Change the input controller to N-Rage's direct input. Open the "Configure Controller Plugin" menu and set the mappings using the controller.
Start Playing!
You should be all set to go now! Download some ROMs and start enjoying your homebrew N64 adapter.
Step 4: Arduino Code in Depth
The N64 Protocol
The bits sent to and from the N64 controller on the one wire interface are encoded in 4 µs wide pulses. A '0' is 3 µs low and 1 µs high. A '1' is 1 µs low and 3 µs high.
The Arduino code in the methods N64_send or N64_receive use very carefully timed assembly code written by Andrew Brown to bit-bang the data line to communicate with the controller. nop blocks are used to wait the appropriate amounts of µs before polling the line of sending data.
On startup, 0x00 is sent to the controller, and then after that the only command used is 0x01 to query for the controller's status.
Data Encoding
When the data is received after a 0x01, it arrives as 16 bits of button information and 16 bits of analog joystick information. The data would look like 44000000000000400044440044000444.
The format of the bits is: A, B, Z, Start, Dup, Ddown, Dleft, Dright, 0, 0, L, R, Cup, Cdown, Cleft, Cright + 16 bits of analog stick position.
The method translate_raw_data() goes through the 32 bits, inserting them into the struct N64_status. The first 16 bits are simple 1 or 0, but the last 16 are translated into an integer approximately in the range (-80, 80) by
    for (i=0; i<8; i++) {
        N64_status.stick_x |= N64_raw_dump[16+i] ? (0x80 >> i) : 0;
After the data is in this simple form, it is easy to do whatever you want with it. In this case, it is simply sent over the serial port in the loop() method as a string of binary data with two integers for the x and y values.
The data sent over the serial port might look like: 0400000000000400 63 -67 which would mean that two buttons were pressed and the control stick was at 63,-67.
Step 5: References
Andrew Brown's project to create a gamecube to N64 adapter with the Arduino was invaluable while coding for this project: http://www.cs.duke.edu/~brownan/n642gc.html
Helpful schematics can be found here: http://www.raphnet.net/electronique/gc_n64_usb/index_en.php
Information on the N64 controllers proprietary protocol can be found here: http://www.mixdown.ca/n64dev/
  • Pie Contest
    Pie Contest
  • Paper Contest
    Paper Contest
  • Remix Contest
    Remix Contest
107 Discussions
xenoinc
6 years ago on Introduction
Great post!
With the new version of Arduion-1.0 i did have to include the "import" stuff & as well take care of RXTX-2.2pre1 / RXTX-2.2pre2 (see below)
Minor Issue:
Has anyone made a patch yet for the controller's sensitivity? With a lot of games this is a HUGE problem.
Overall, great job throwing together the documentation
Fix the RXTX errors:
http://rxtx.qbang.org/wiki/index.php/Download
Currently they are only offering "RxTx-2.2 pre2". So this should help you out.
just pull back the latest RxTx 2.2 preview version & you should be good
ZiggyH
1 year ago on Step 5
Can you help me get this to work with switch?
cobrajet302gt
1 year ago
I can't get this working, im using an arduino mega 2560 with uploaded , pin 2, 3.3v and gnd. I added import java.awt.Robot;
import java.awt.event.KeyEvent;
I had to change my serial.list()[1] to 0 for coms port 3
i am not getting any output from the program from ether controller
SilasC3
2 years ago
I know this is an old project, but it is still awesome. Tried it out with processing 2.2.1 which seems to work fine. Just include the import already listed in the description and this import java.awt.event.KeyEvent; --- So total additional import is
kokolasticot
2 years ago
Thank you for this instructable, I'm finally able to play again majora's mask as it should! (after some adjustment now that it is version 3 of processing :) )
Tgizzo
3 years ago on Step 2
hello, and Great instructable! very easy to follow. however, i have one question. i get an error that says
Error, disabling serialEvent() for COM3
null
any help? it is greatly appreciated, and keep up the good work!
MrattS
3 years ago
Hi, I'm trying to get this to run on Ubuntu 14.04.
I seem to only be able to get processing 3 to run natively and I'm running processing 1.5.1 out of WINE.
When I try to run the processing code I get this error message and I have no idea how to make heads or tails of it, any help with getting this up and running would be really appreciated! I mean to link it up to pure data and play some music with my controller! (also just Jet Force Gemini)
MrattSMrattS
Reply 3 years ago
woops, forgot to include the error message- here's some info
Error inside Serial.<init>0
(with the line N64 Connection = new Serial(this, portName, 115200) highlighted)
the whole error message is much longer and I'll type it up soon- can't seem to copy paste...
MrattSMrattS
Reply 3 years ago
i suppose I'll type the whole thing up if you let me know if you can help.
The first line is:
gnu.io.PortInUseException; Unkonwn Application
DiamondDrake
3 years ago
I have actually built on of the v-usb based adapters from raphnet.net I part of the way though porting his implementation into something more arduino friendly. I saw this link and spent a little time today to see how well it works. The code isn't very pretty but it does work. I modified it to read 2 n64 controllers at the same time and created a HID usb descriptor for v-usb for it to show up as 2 gamepads. No host software needed. Just a note, 2 of your links from above are dead.
Hopefully I can find the time to spin off a continuing instructable that shows how much more power you can get out of this set up.
Thanks for sharing
nfarrow
3 years ago on Introduction
Has anyone got this to work with a RetroPie? http://blog.petrockblock.com/retropie/
WilliamW24
3 years ago
Im trying to use custom pads that send keypresses like the makey makey to control it.
how do i do it plz help been stuck on this for weeks
Maxaxle
5 years ago on Step 2
Having inserted the three import lines, I'm having an issue running the the two Processing files, both coming up with this issue:
"Cannot find anything named "KeyEvent.VK_UP"
on this line:
"VKey.keyPress(KeyEvent.VK_UP);// DUp"
Any ideas?
DONPATCHMaxaxle
Reply 3 years ago on Step 2
You need to add this"import java.awt.event.KeyEvent;"
Jdbye
5 years ago on Introduction
I've been trying to get Controller Pak support working, but it seems the timing of the sending/polling isn't accurate enough as getting the controller status and button state works fine (verified this by logging the data) but the mempak refuses to work. I don't know assembly so I can't convert the entire code to it, does anyone have any suggestions for optimizing my code and making timing more accurate?
Arduino code can be found here: https://dl.dropboxusercontent.com/u/8225581/N64_Arduino.rar
Project64 plugin source: https://dl.dropboxusercontent.com/u/8225581/ArduiN64.rar
lolpaper21Jdbye
Reply 4 years ago on Introduction
Hey I recently got ahold of your code (I don't know if you're even still on that project, its been about 10 months.) What COM port is your program searching for? Because My UNO is on COM3 and it says Failed to open com port
Jdbyelolpaper21
Just saw your reply, in that code it uses COM4 but you can change it in Controller.cpp near the top at #define comPort. I never added a config window to allow changing the COM port since having it hardcoded worked fine for my own personal use and I was more interested in getting controller paks working. Still not sure why the Memory Pak doesn't work, it seems to transfer data fine but struggles with the 32-byte data packets and the data gets corrupted. Might be a timing issue. It's a pity since the only adapter that works with paks to my knowledge is the Adaptoid and those are not easy to get anymore. Would be nice to have full pak support, add USB HID and maybe do a production run of some boards if people are interested.
