Using MT8870 DTMF Decoder With Arduino
43,786
27
12
DTMF DECODERS Are used to detect DTMF TONES Genrated by mobile phone DTMF Keypad.
In this project we are going to decode the DTMF Tones into 4bit Output and this output is given to the arduino which detects the keypress and displays it on LCD
Supplies:
Step 1: Components Used
The components that I have used are easily available locally in most of the cities or you can also buy it online
Step 2: Circuit Diagram
Use the above Circuit Diagram and build the circuit.You can change it according to your need
Step 3: Giving DTMF Input to Circuit
The input is given by a mobile phone with a 3.5mm jack which provides the DTMF signals to MT8870 decoder
Step 4: Programming the Arduino
I used USBasp to program arduino u directly program it using usb it is better to use usbasp if you are building the circuit on breadboard
Step 5: Arduino Code
Use the code to program arduino
it uses hex codes for numbers pressed on dialpad of mobile
The Hex Codes For Keypress Are As Follows
1 = 0x01
2 = 0x02
3 = 0x03
4 = 0x04
5 = 0x05
6 = 0x06
7 = 0x07
8 = 0x08
9 = 0x09
0 = 0x0A
# = 0x0C
Step 6: Getting Output on LCD
The decoded key shown on a LCD Module In this picture the # key is pressed on mobile phone and it is also shown on LCD Module
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    12 Discussions
    tanu shradhali
    Question 1 year ago on Introduction
    if we wanna to interface to dtmf and arduino .so will be the requremeny libraries
    ovidiu_seran
    1 year ago
    Hello,
    Very nice project. But I would like to ask if it is possible to add a sequence at startup, where you should "login" first then give commands to the arduino.
    This way will be safer in use this project!
    Thanks a lot.
    GuidoSan
    2 years ago
    My bad - theres a perfect image in the zipped files I just wasn't smart enough to look.
    GuidoSan
    2 years ago
    Is it possible to get a clearer image of the circuit layout. I can't quite read it but i really want to build it.
    Thanks
    vedprakashv
    3 years ago on Introduction
    hello sir plz tell me what type arduino use and what the process to burn the program in it.
    CircuitToday
    3 years ago
    it available in Arduino IDE to Compile .
    CircuitToday
    3 years ago
    Pin is function for Atmel microcontroller which reads the state of a specific pin
    C Means The PortC Of Microcontroller
    its the analog input port of Arduino the function pin reads the state of portC or Analog port
    rsrini7
    Can u pls guide me what is PINC and the program is compiling with this. In Which module the PINC variable available ?
    CircuitToday
    4 years ago
    If You Like My Projects
    Like My Facebook Page
    CircuitToday
