Variable Bench Power Supply
60,360
561
50
This is a simple adjustable bench power supply I built to help me in my instructables. 8 )
Some time ago I build another using a computer (ATX) power supply, but this kind of solution provides fixed values: 3.3, 5 and 12 volts. This is the less expensive solution you will find (just if you have an ATX as spare), and is useful if you will work just with these values, but this is not my case.
This project works with around 0.8V-29.4V ~ 5A.
Let’s do this…
Supplies:
Step 1: Materials
Here is a list of materials I used for this project:
Ebay:
- 1 x LTC 3780: http://www.ebay.com/itm/LTC3780-DC-5V-32V-to-1V-3...
Price: US $14.20
- 1 x 12V 5A Power Supply: http://www.ebay.com/itm/12-24V-Universal-2-3-5-10...
Price: US $9.40 (if you decide to go with 12V 2A 24W price is US $ 4.89)
- 1 x Voltage/Current Display: http://www.ebay.com/itm/DC-100V-10A-Voltmeter-Amm...
Price: US $ 3.99
- 1 x 500kΩ Potentiometer: http://www.ebay.com/itm/Cosmos-Tocos-Potentiomete...
Price: US $ 2.49
- 2 x Binding post: http://www.ebay.com/itm/10-PCS-4mm-Banana-socket-...
Price: US $ 0.38
- 1 x AC Switch: http://www.ebay.com/itm/New-Heavy-Duty-2-Pin-Car-...
Price: US $ 0.99
Of course you will need cables, weld iron, AC plug, Heat Shrink Tubing or isolate tape and miscellaneous that all Maker has.... ;
Step 2: CASE
If you have a plastic or metal case to use, it’s up to you. I prefer use wood and build it by my own.
I will not enter in details regarding the case dimensions because I believe that it is not important, and the size will be different if you decide to use different components. So, find a case that fits your project and let’s go!!
As you can see I decided to use a PC cooler fan just because I had one, but it is not necessary. It is so cheap that I recommend using. I used black paint in the wood (fan entrance) to provide a better finishing. Using a drill (8mm) I opened 5 holes to the air exhaust.
I am a Maker, so I have lots of electronic parts that I use in my project. I like to use metal 5mm LED Mount Bezel Holder as the cable holder in the case, it gives a professional touch in the project…. 8 )
Step 3: CIRCUIT
You just need to wire the components as showed in the electric diagram. Piece of cake.... ;
Some people are afraid with no protection of the original circuit, so I decided to improve the safety adding one fuse and grounding the circuit. Safety First!!!
Step 4: Wiring Everithing...
To install the potentiometer to control the voltage output you will need to remove the original mini potentiometer welded in the LTC board. Just use the soldering iron to remove this item and weld the cables as showed in the diagram.
Step 5: Testing
All cables connected its time to test the PS.
Bingo!! First project without any problems!!!!
Step 6: Knob.... ?
When I was concluding he project I noticed that I did not have a potentiometer knob! No problem, that’s the reason God gave us creativity…. 8 )
Using wine cork, a beer bottle cap and super glue I improvised one knob (MacGyver is my master…. Hahahaha)
Step 7: Final Touches
With everything inside the case, I applied a finishing to protect the wood case (wax) .
It is possible to install another potentiometer to control the current too, but to me this is not necessary.
Just it!!!!
See you soon!
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
50 Discussions
laoadam
5 months ago
Nice job.
can just use a ATX power supply as dc input?
laoadam
5 months ago
Hi,
do you have a video to show the adjusting? I just wonder if the V and I following vary when change either one?
JonneS1
Question 1 year ago on Step 3
I wired according to this diagram but for some reason i don't get any voltage coming out of the blue wire of the display so the positive post doesn't give anything out. Is there any common reasons why that's happening?
GabrielB147
Question 1 year ago on Step 2
What are the recommended measurements for the box?
BADyoyo2
2 years ago
What AWG wire should I use for this project as I have no idea if my 16 gauge spool would work.
Mayur BK
2 years ago
what is the minimum output current ?
neblin7
2 years ago
Question. So, as I turn the knob, the pot, the display will slowly rise in both voltage and amps until I get the desired amount? Since voltage and resistance are directly proportional, those numbers ( V and R) will always be related since 12 Volts = 1 Ampere? I'm still learning on my own and don't want to toast any tests I decide to try. Thanks! =)
leomirandaneblin7
Reply 2 years ago
In the way I wired you just control the voltage (0,8 to 29,4 Volts is the range I have). Just select the desired voltage and when you connect the load, the actual current will be displayed.
neblin7
2 years ago
One more question. What's the lowest voltage that I can dial in with this power supply? Thanks.
MMKareszneblin7
Reply 2 years ago
According to LTC3780 psu, 5V.
luismoro
2 years ago
Muito legal o projeto!
E a knob com a tampa da Invicta ficou bem diferente! Hahahaha
deluges
2 years ago
Grat project ! I especially like the safety lion :)
bl10
2 years ago
I see your fan for cooling but I only see one vent in the box. The box should have two vents if heat is a concern.
B.
