Variable Frequency Arduino Generator
12,805
58
7
About: Just do things, electronics, woodwork, etc.
Hello everyone, this is project How-ToDo. Since some of you asked to show in detail my variable frequency arduino generator for high voltage power supply, here it is.
Step 1: Circuit
The circuit is very simple, Arduino nano, I2C OLED display 128 to 68 pixels, 3 transistors and three buttons, two of buttons are responsible for frequency adjustment, and the third button turns ON the output signal. It's would be good to add an optical isolation or driver with GDT but I don't have components for that. Primary coil on the transformer contain 5-10 turns with 14 gauge wire, but 20 AWG wire should be enough. Also for this circuit it is necessary to make a gap between the halves of the ferrite core, I simply put a layer of paper tape.
Step 2: Firmware
The frequency is adjustable from 30Hz to 1MHz, and since its based on built-in PWM, the higher the frequency - the greater the steps, at the end it amounts to tens of kHz, but for my purposes in the range of up to 100 kHz it's good enough.
Before uploading Firmware you need to connect these libraries:
Bounce2
FrequencyTimer2
Adafruit_SSD1306
I also added power from the battery, it's some sort of power isolation, but it's going to work fine just with LM7805.
Actually there is not much to talk about, hope you like it, see you soon!
Find me on social media:
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    7 Discussions
    MoizR4
    Question 6 months ago
    From what pins I will get the frequency output?
    rajivdeo
    Question 1 year ago
    I only compiled the code for Nano. I get following -
    Sketch uses 16320 bytes (53%) of program storage space. Maximum is 30720 bytes.
    Global variables use 1607 bytes (78%) of dynamic memory, leaving 441 bytes for local variables. Maximum is 2048 bytes.
    Low memory available, stability problems may occur.
    Before uploading the code, I would like to know - Will this code have real stability problems?
    MatijaL5
    Question 1 year ago on Step 2
    Sorry, l'm looking forward to make this generator but l'm having problems with the code (Adafruit_SSD1306 library). Could you please Help me somehow?
    1 answer
    tirteosMatijaL5
    Answer 1 year ago
    Height incorrect, please fix Adafruit_SSD1306.h!???
    In Adafruit_SSD1306.h
    1. uncomment #define SSD1306_128_64
    2. comment #define SSD1306_128_32
    3. comment #define SSD1306_96_16
    In the example ssd1306_128x64_i2c
    4. add #define SSD1306_LCDHEIGHT 64
    on top of
    #if (SSD1306_LCDHEIGHT != 64)
    #error("Height incorrect, please fix Adafruit_SSD1306.h!");
    #endif
    tirteos
    the frequency can start from 1Hz???
    NickM312
    1 year ago
    Fantastic project!
    Could this be used as a variable frequency generator in my project?
    I need to build an inverter from 12v DC input and to output 200v AC with variable frequency between 500Hz and 3kHz upto 3amps.
    This will drive an electrolumiscent panel.
    Would love to hear your input...
    electronic_artist_
    1 year ago
    great instructable . i had watched the transformer video i liked your build. awesome.
