Vergo Lux
1,040
9
About: I love Making/creating things, and I am very exited about the growing maker community.
This is a tilt light, which works by flipping the jar over to turn it on.
I hope you enjoy this instructable.
Step 1: Supplies
Today, I will be making a vergo lux, or a tilt light. this is a very simple project, with no soldering involved.
For this project you will need:
Small breadboard
Tilt ball switch
Medium sized binder clip
Electrical tape
Wire
led (I used a RBG led, but i think you can use others)
double sided tape
coin cell
battery jar that can fit the breadboard
Step 2: Making the Vergo Lux
Take the breadboard and stick it onto the lid of the jar.
Cut two wires about 4 cm, and attach them to the battery.
Put the battery and wires in the binder clip.
Remove the two clips from binder clip by pushing the two ends and pulling.
Insert the two wires three holes away from each other.
Place tilt switch with one lead in front of the - lead of the battery and the other next to the first tilt switch lead.
Place the positive end of the led in front of the + lead of the battery, and the - lead in front of the tilt switch lead.
That's it! Your done! If you did everything correctly, then if you flip it the light should turn on. I hope you liked this instructable!
  • Classroom Science Contest
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
