Vertical Corner Garden Out of Pallets
22,247
385
13
This project was inspired by a video that Steve Ramsey posted on his youtube channel, Woodworking for Mere Mortals.
It is a simple project, which uses simple tools. All you'll need is a jigsaw, a drill and a pallet.
Portuguese version abailable at www.foradoescritorio.com.br
Step 1: Select Your Wood
Choose two larger pieces from the base of the pallet to be used as the frame of our vertical garden and gather enough boards to fill the back of it.
Doesnt matter if the wood is dry or wet, you can use both of them.
Step 2: Trace Lines to Cut
Find the angle that you want for your garden and place the boards under the wood that you're going to use as frame.
With a pen or pencil trace the outline of the frame.
Step 3: Cut the Back to Shape
Cut all the pieces of the back panel with a jigsaw following the lines that you traced before.
Remember to keep the boards on its order, so it's easier to put everything togheter in the end.
Step 4: Screwing the Back Panel
Place the first and last pieces of the back panel to get the frame on the exact size that you traced your lines before.
Start screwing from top to bottom.
Use 4 screws for each piece, one on each corner.
There's no real need for wood glue, but you can use it if you want.
Step 5: Mounting the Shelfs
Cut a few pieces from another large wood of the pallet base. They don't need to be exact measured. Roughly 2cm each.
Step 6: Fill With Dirt and Plants
Cut a few boards to fit in as shelfs, again, nothing exaclty measured.
That's it!
Now that your vertical planter is done, fill the shelfs with dirt and start planting your flowers!
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    13 Discussions
    ccroft1
    4 years ago
    Voted and favorited. Making one for maybe some strawberries or mint.
    clazman
    5 years ago on Introduction
    Simpler yet, why not use a (manual) hand saw and a (manual) screwdriver?
    No electrical power source required as well as a cardiovascular and muscular workout
    fabelizerclazman
    Reply 5 years ago on Introduction
    You can hurt your wrist, elbow, and shoulder screwing in that many screws! Somethings just make sense, and a battery powered screwdriver is one of them!
    The handsaw is a great workout for a small project! I highly agree with that for this project. great fun when it's cool outside!
    You can irrigate these things with a bucket of water and an "airlift pump" (Just 1/4 inch tubes joined together. Air comes from an aquarium bubble pump. Smallest bubble pump could run 3 of these planters. The air pump could be on a timer to water every hour or two.
    soul_eater
    I was planing to do this project from wwmm i saw it past week yours look nice
    HPandLOTR
    i watched the steve ramsey vid of this a few days ago :) this is such a good idea :)
    lilchumy
    5 years ago
    Yeah I just saw this on Steve ramsy
