I found these over sized erasers at the dollar store and bought a couple. I initially planned to use them for making custom rubber stamps but then I quickly realized I could use them as soft jaws for my vice. This is a very simple build that will net me a lot of use. I already had the neodymium magnets and epoxy on hand so I only spent the $2 for the erasers. I believe magnets can be purchased for about $3-4 in the hardware store. I plan to use this for my knife making. I also think they will come in handy when working with wood, since I don't have a proper woodworking bench I can use these to hold the wood with out marring the surface. I hope some of you all find this quick build helpful.
Step 1:
These erasers were flexible which I hope meant would allow them to contour to the shape of whatever clamp in them.
Step 2:
The first thing I did was to square them off. So I marked the length of my vice jaws and used my band saw to cut the excess off the erasers.
Step 3:
Next I marked the locations of the magnets. I made sure that the magnets would align with the flat portion of the inside of the vice jaws. I used the magnets as templates to mark the position of the holes. Then I took the erasers to my drill press and drilled two holes. I made sure the holes were roughly the width and depth of the magnets. This is a good opportunity to use the depth stop on the drill press.
Top tip: Use a scrap piece of the eraser you just cut to do a practice hole to check the depth before drilling the actual holes.
Step 4:
After drilling all the holes I mixed up some 5 minute epoxy and glued the magnets in place. Do not use acetone to clean the residual epoxy it may eat away at the eraser.
I let the epoxy cure for a couple of hours.
Step 5:
I tested the soft jaws and was surprised how well they worked. They gripped the knife blade well with no issues and no marring. This is a very simple but very useful build. I hope you all find this helpful.
15 Discussions
4 months ago on Step 5
Great idea! I would have stopped at just thinking of the erasers, but the magnets add a lot to it.
Reply 4 months ago
And the neat thing is when the erasers wear out I reuse the magnets.
4 months ago
Nice instructable. Thanks for sharing!
Reply 4 months ago
Thank you!
4 months ago
Great thought, thank you for a great simple idea. Good job!!!
Reply 4 months ago
Thanks they have already come in very handy for my knife making. Its makes the final clean up on the scales a lot less stressful.
4 months ago
Very cool. I love projects like this. Super fast and easy to use.
Reply 4 months ago
Thanks this is one of those quick win type of projects that you can use almost right away.
4 months ago on Introduction
Practical idea and nicely done video, inspiring
Reply 4 months ago
Thank you!
4 months ago
Good idea. I think I will just glue on the flat flexible refrigerator magnets on the back side so there would be no bulges in the erasers.
4 months ago
I am a silversmith and often I want to hold pieces of metal very firmly in the vise. Instead of erasers I use soft mahogany wood which compresses slightly and provides the holding power I need without marring/bending the surface of the silver. I did use magnetic plastic sheet glued to the back side of the wood for holding the wood jaws in place. When the present jaws become too used, I will make new ones using the magnet idea here. Cross pollination.
Reply 4 months ago
Yes! I love it when ideas are repurposed.
4 months ago
This is a really good idea. I need to make a pair of these!
Reply 4 months ago
Thanks, I bought a few extra erasers so when these get trashed I can remove and reuse the magnets on the new ones.
