Viking Weave Necklace and Bracelet
105,449
427
15
About: Hi, I'm Craig. I live in the UK.
Similar to French knitting this is a surprisingly easy way to make woven wire cord for bracelets and necklaces!
I was looking for something interesting to make for my better half as a Christmas present and I stumbled across this very old method of wire weaving:
http://en.wikipedia.org/wiki/Lucet
http://www.waynesthisandthat.com/knittingnancys.html
A quick search gave many tutorials, the following was great:
http://www.youtube.com/watch?v=_Ynf5jjpL1U&feature=results_video&playnext=1&list=PLEF355CEE40339342
It would make an excellent valentines gift!
Supplies:
Step 1: Tools and Materials
Tools:
  • Mandrel
    • Something tubular and sturdy to weave around.
    • I used a 10mm drill bit.
  • Pulling board
    • This is a board with sequentially smaller holes drilled through.
    • I used 11mm-7mm holes in a pine off cut.
  • Pliers
  • Safety glasses
    • Flicking around the pointy end of a length of wire will end in tears (or ocular tears). They can be picked up for not a lot, I prefer the lighter ones: Amazon link
Materials:
  • Wire
    • The weave in the front picture uses 20Ga. It was something similar to: Amazon link
    • For a first go try copper wire as it's often inexpensive.
    • Silver and gold coated copper provide an excellent combination of looks, bendyness and price. Amazon link
  • Jump rings
    • Can be made with the same wire as the weave
  • Clasps
Step 2: Starting the Weave
Starting loops
  • Take a length of spare wire approximately 300mm long.
  • Bend it into a four leaf clover shape.
  • Wrap the ends together.
  • Bend the leaves around your mandrel.
Your starting loops need to be secure enough to align the first couple of rows and are used to pull the finished weave through the sizing block. Once your weave is finished you will need to unwind these loops.
Step 3: Weaving
Weaving
  • Bend your weaving wire 90o about 25mm from the end.
  • Hook this though one of your starting loops from back to front (see picture).
  • Take the other end of your weaving wire and loop from back to front on the next starting loop (see picture).
  • Don't worry too much about the tension, just keep the loops running parallel down the mandrel.
  • Continue until you run out of wire.
Step 4: Joining
Joining a new length of wire into the weave
  • As you can't weave the wire on a spool and lengths several meters long are difficult to handle you'll need to join two or more lengths.
  • Thread the loose end of the original wire back up inside the weave, it may be easier to remove the wire from the mandrel.
  • Hook the new length around the above loop, similar to starting the weave.
  • I've used copper wire for the new length in the photos to make it easier to follow.
Step 5: Sizing
Sizing
Before the weave is finished it's drawn through a series of holes, this evens out the weave and sets the outer diameter. As a consequence the length of the weave changes.
Starting with the largest hole pull the weave through a couple of times, then decrease in size until the desired diameter is reached.
As a rough guide a weave pulled through holes down to 8mm diameter has 7 rows in 50mm when using 0.9mm thick wire, thus if you wanted a 200mm bracelet you'd need about 28 rows woven before drawing the weave.
Step 6: Finishing the Ends
Finishing the ends
Once the starting loops are carefully unwound from the weave these top loops can be joined with a ring failry easily. The loops at the bottom end are a little more tricky, look for the points at which the wire crosses itself, the lowest point of each loop, and thread a ring through all four.
Step 7: Using for Jewellery
Using the weave for jewellery
Necklace:
€‹I bought two snake weave bracelets, connect one of the jump rings on the weave to the loopy end of one of the bracelets. I removed the clasp from the second bracelet and join the other end of the weave with the jump ring.
Bracelet:
I used a wrapped extended loop to get the bracelet sizing perfect and used a clasp. The extended loop is heavier than the weave which means it doesn't spin round all the time.
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    15 Discussions
    CarolynnP
    4 months ago
    I have been interested in Viking weave jewelry for about a year but never saw any instructions until now. I love the clean, repetitive lines of the work and I am sure I can learn several different stitches when I have learned the basics. I had thought it was done with either knitting needles or as a macrame cousin. Instead, it seems to be a form of netting. I love finding a new adult (not kitschy) craft to add to my repertoire and your instructions are pretty clear. The only thing I may have trouble finding or making is the sizing board. Maybe one of my brothers or my sister (she likes using machine tools) will have a drill with different sized bits and if so, I'll get a foot or so of 2"x4" wood and have at it. I'll finally get to have some Viking weave jewelry! Thank you so much for your clear instructions with very helpful pictures.
    cbm104CarolynnP
    Reply 12 days ago
    Hi CarolynnP, Thanks! Sorry for the delayed response, if you had no luck getting holes drilled do you have a spaghetti measurer? I've just had a quick look, all the ones I see are a little big but it depends on what you are aiming for?
    cneibarger
    3 years ago
    I have just started working with wire and needed something unique to hang my handmade wire pendants from, other than a simple chain. This is absolutely perfect!! Easy to follow, so thanks for the great idible!!!!
    Guzberi
    4 years ago
    Great job, thanks for this.
    I know where I have some copper wire to try this out ?
    One question if I can,
    Right at the start, a section of the wire is left inside the weave, Is it worth forming a loop on the pointed end of the wire to stop it from poking through the weave when the piece is finished, or, does this just not happen?
    cbm104Guzberi
    Reply 4 years ago on Introduction
    Hi,
    Good idea, it wouldn't hurt to bend the end over, I don't think that bit has poked through yet but if something can go wrong it probably will eventually :)
    rose_adamaj
    4 years ago
    Can't believe it took me so long to see this ible, better late than never! I can't wait to try this - and if my nieces don't already know about this, they will be very excited as well. Thank you, your pictures & instructions are excellent.
    Catia66
    5 years ago on Introduction
    Thanks for helping me, I was just looking for it!
    spellwing777
    6 years ago on Step 2
    Would a bead cap, instead of the cap here work? I've got a few that are just simple clover shapes here; but they have a really nice stamped texture on them.
    cbm104spellwing777
    Reply 6 years ago on Step 2
    Ah, yes they would work great! It would give the first end a nice finish. I hadn't seen them before, thanks!
    raviolikid
    7 years ago on Step 7
    This looks like an interesting craft! I'll give it a try sometime. Thanks for the good directions!
