Virtually Invisible Wood Putty for Any Species of Wood - Free!
18,700
51
13
About: Vietnam era veteran (USAF), former air traffic controller, former entrepreneur, former clergy, former chauffeur. Currently retired and busier than ever. Devoted husband to an extremely talented wife and fat...
OK, I confess - I'm a perfectionist. If you don't believe me just ask my wife. To me, there are few things worse than completing a wood project and having gaps in joints or noticeable circles where a hole was filled with wood putty. The colors never seem to quite match and - even if they do - the commercial wood putties don't seem to take a stain or finish the way they claim to. There is a simple and essentially free solution however - make your own wood putty as needed and specifically for the wood you are using. Here's how.
Supplies:
Step 1: Kick Up a Little Dust
You'll need a scrap piece of the wood you want to repair. For the example shown I'm using walnut. You'll also need a scroll saw, a fine-toothed Japanese style saw, a sander, or some other method of producing very fine sawdust. For my example I used a scroll saw. Clean the table of the saw so there is no dust on it. Then cut several strips of wood - it's the sawdust that's important here - not the wood (see Figure 1). Be sure to turn your air jet (if your saw has one) away from your work so you're not blowing the dust away as you create it. Once you have a satisfactory little pile of sawdust, scrape it all together with a piece of paper (Figure 2) and funnel it into an old prescription bottle or something like that (Figure 3). Label the bottle with the species of wood. Helpful note: When I'm working with a particular species of wood I do this as a routine. I've built up a little library of prescription bottles with labels on them - walnut, bloodwood, cherry, etc. Then I just pull out the bottle I need at any given time.
Step 2: Mix Your Putty
In Figure 4 you'll notice the gaps along the joint where I've glued two pieces of walnut together. This is what we're going to fix. Pour out a little pile of the sawdust onto an expendable surface such as a piece of paper. Use a toothpick or slender scrap of wood to form a hole in the center like a volcano (you do this because when you add the glue it tends to roll right off the sawdust).
Step 3: Mix Your Putty Continued
Squeeze a little carpenter's glue into the caldera (aren't we using fancy words?) of the volcano (as in Figure 5) and use the toothpick to mix it with your sawdust until your mixture is about half glue and half wood (Figure 6). Mix and squish until you can no longer see the glue separately from the sawdust. You can pour the remaining loose sawdust back into your bottle for future use.
Step 4: Applying the Putty
Work the glue/sawdust mixture into the flaw you want to repair. Mound it over the top a bit to allow for shrinkage as the glue dries. Figure 7 is from another repair on the same wood.
Step 5: Sand and Finish
Once the glue has dried, sand the repaired piece smooth - and there you have it. Can you see the repair in Figure 8? Hard to spot, isn't it? And even harder after a finish of Danish Oil is applied (Figure 9). And please bear in mind that these photographs are all extreme closeups. Since this repair is about half wood, it will take stain and finish just like the surrounding wood. If you want to prove to everyone that you're truly OCD, you can do the sawdust collection process while you're working on any given project - the color of any species of wood will vary from one board to another, and by using sawdust from the piece you're actually building, the color of the sawdust you're using for the repair will exactly match the wood.
Thanks for taking a look at my Instructable. I hope it's been helpful, and
Peace,
Radical Geezer
  • Party Challenge
    Party Challenge
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
13 Discussions
Jobar007
3 years ago
Personally, I always use the saw dust from sanding the board. I'm like you in the regard to perfection. That's why I don't store any saw dust. The difference between different boards of the same species is too great for my OCD nature.
AA040371Jobar007
Reply 1 year ago
ermmm...I think you mean CDO, Jobar007 (THE WAY THE LETTERS ARE ORDERED IN THE ALPHABET!!!!!!!)
Jobar007AA040371
Reply 1 year ago
OCD is in order based on the shape of the letter with the most curves to the least curves. At least, that's what I tell myself so I can sleep at night... ;)
rwilliams22
3 years ago
This is a good tip, but I can suggest a modification which may improve it. Wood glue resists certain finishes. If you mix the fine sawdust half-and-half with flour (not self-rising flour), and add a bit of water, you have a mixture that will take a stain or varnish as well as the surrounding wood.
I learned this from a friend who built boats, and he used a mixture of sawdust and flour to rub down the boats before varnishing. After rubbing with the mixture, he would remove the dust with a wet rag. Any of the mixture that was embedded in a crack would then be glued in place. In case of a small leak, the flour and water mixture would swell up, sealing the spot.
Radical Geezerrwilliams22
Reply 3 years ago
Sawdust and flour? Now that's an intriguing idea - I'm going to have to try it. My guess is that it would also produce a great color match even on lighter woods. I'm glad I started this conversation - I'm learning as much as I'm sharing. I'm also thinking that if you're working with smaller projects rather than something as big as a boat and you want to wind up with a really smooth surface, you'd want to make a paste with the flour and sawdust by mixing in a bit of water before you applied it, over-fill, let dry, then sand smooth. The only problem I can see is if you're making something that's not going to have any finish at all...just natural raw wood. In that case a sawdust/flour fix probably wouldn't hold up over time. But a truly outstanding outside-the-box idea - Thanks!
Wood Chuck
3 years ago
I have used this method for years and yes it works very well. Another alternative is to use thin CA glue (superglue). I also find the white glue instead of yellow glue doesn't leave the dark glue mark. Thanks for posting
oldcarnutjag
3 years ago
thank you I now have a use for old film cans.
JACK G
3 years ago
Jack
Filling cracks with a glue and saw dust mixture is not successfull when light coloured woods are used.The glue leaves a darker line. I use a light clear glue used for repairing veneer is a closer match when finshing.
sixsmith
3 years ago
if I'm using a power sander to finish my projects I like to clean out the dust collector bag before I switch to 220, then I use that collected saw dust in the same manner as you, though, I personally find epoxy a bit easier to work with compared to wood glue, but it does cost quite a bit more.
chrisagnewsixsmith
Reply 3 years ago
this is my exact method, works well. right out of the sander and mix with a little epoxy. if i am getting really serious, can add trans tint to the epoxy to darken it a little
chrisagnewsixsmith
Reply 3 years ago
Radical Geezersixsmith
Reply 3 years ago
That's an excellent idea for collecting sawdust. I would worry a bit about the quick dry time of epoxy and whether it would take stain as well, but it's certainly an idea that deserves consideration. Thanks!
sixsmithRadical Geezer
Reply 3 years ago
Epoxies come in all sorts of cure times, I am generally good with the 15 minute time, unless I've got a lot to do. the only thing is epoxy is pretty hard so I always scrape the joint while it's wet with a razor blade so the epoxy is dead level with the rest of the wood.
